Question about Car Audio & Video
I can't get any radio reception.. Do i need to hook up the power antenna wire on a 2006 ford fusion?
  • 39 Answers
If you have the model with the antenna that extends itself as opposed to the stationary ones, then you might have to. we're having the same problem with my friends neon, but we cant figure out which wire to connect it to.
if you get a wiring diagram for the car, it might come up as "power antenna/amp" or something of the like. with ford, i believe its a white wire, but i could be mistaken.
Posted on Aug 15, 2008
HI I HAVE A 2006 ford radio 6E5T-18C815-AL wont power on
YES THE ANTENA NEEDS TO BE PLUGGED IN FOR THE RADIO TO WORK.. AND CHECK ALL WIRING.. AND FUSES.
Dec 10, 2014 | 2006 Ford Fusion
Poor radio reception
check your antenna wire to see if it came unplugged from back of radio
May 18, 2013 | 2002 Ford Crown Victoria
I have a old pioneer stereo double cassette deck reciever model # RX-Z15, i dont understand the bal/unbal fm antenna hook ups cant get reception , need to know where to hook up the antenna or what kin
Buy a 300ohm FM Y antenna wire screw the spade ends into the balance hookup and fasten the Y section on your wall, "higher the better" this will improve reception. The antenna can be purchased at Radio Shack or Tv repair shop.
Apr 20, 2012 | Pioneer Audio Players & Recorders
Need factory stereo and speaker wiring diagram for '08 Ford Fusion
2008 Ford Fusion Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Green
Car Radio Ground Wire: Black/Blue
Car Stereo Antenna Trigger Wire: Purple/Black
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): White/Purple
Right Front Speaker Negative Wire (-): White/Orange
Left Rear Speaker Positive Wire (+): Brown/Green
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Blue
Feb 16, 2012 | 2006 Ford Fusion
Am fm reception bad
FM reception is weak
What to do
• Extend the power cord as much as possible. The FM antenna is in the power cord.
• Move the power cord to adjust the FM antenna
• If you still have problems with FM reception, you may need an external antenna.
* Call Bose®Customer Service to request one.
The external antenna on your radio is a coax (round) design It needs an adaptor and an antenna which are cheap.
Easy to make, radio shack "F" connector 90 degrees or straight, to 300 ohm wire connections. Attatch a 300 ohm flat ribbon antenna cable to those two screws and plug into radio and see how your reception is. You will need to position the antenna wires to get best reception. I have hid them in back of paintings and so on.
Cheapest solution next to putting an extension cord on radio power cord.
Jan 03, 2011 | Bose Wave Radio
I installed my Sony CDXGT250MP today and am able to listen to the cd played or Aux output but I have no radio reception?? I connected all of the wires and did have three left over in the wiring in the old...
The orange/black wire should be a dimmer, the blue wire should be power antenna, the Blue wire should only be hooked up if your antenna goes up when you turn the car on, also goes down when car is off. OR you could possibly have an aftermarket antenna that needs power to boost signal. There should be a thick black wire that is pluged in somewhere on the back of your radio.bassmekanic.gif
Nov 06, 2010 | Sony CDXGT250MP
Pioneer Avic D3 has poor fm reception when the car is on. It works fine when the car is off. Any ideas?
Your power antenna wire maybe hooked up to ignition. So when you turn off the car no more voltage is going to your antenna wire so your power antenna goes down causing a poor reception. You must hook up the blue wire on the radio harness to the power antenna wire.
Apr 10, 2010 | Pioneer AVIC-D3 Car DVD Player
Radio/tuner reception
You will need to buy a signal amplifier antenna. One that doe not have to be connected to the Clock/Radio. It will provide the amplified signal and the radio antenna (the a/c line cord and the back of the clock/radio) will be able to pick up the signal from the amplified antenna.[http://www.radiolabs.com/products/antennas/am-antenna.php] this web link will show you one type of these antenna's. Copy the web link and paste it into the address bar in your browser. It will take you to the website. There maybe other types of these antenna's but this one had the best price. Call the store and talk to them before you buy the antenna to make sure it will work in your situation. I hope this information helps you with your antenna problems.
Feb 21, 2009 | Emerson Smartset Clock Radio
No Subs in CD mode??
Ah, common problem. You hooked up the remote turn on wire for the amp to the power antenna wire (solid blue). Hook up the remote turn on wire for the amp to the blue wire with white stripe. The power antenna only provides power when the deck is in tuner mode for the power antenna to be extended, intuitively, and cuts power in any other mode, because certainly it's only needed for AM/FM reception.
Sep 28, 2006 | Sony CDX-M8815X CD/Receiver/MP3 System
Car Audio & Video Logo
119 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
