Question about Nelson Sprinkler: Traveling Tractor
Nelson springler leaks at bottom gearbox - Nelson Sprinkler: Traveling Tractor
  • 43,501 Answers
There is a seal by the push rod that stops the tractor that is leaking...
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Posted on May 19, 2011
Gearbox leak (drip) 3.0 tdci ford ranger 2011 high rider
most likely to be either rear crank seal or gearbox input shaft seal or bearing
Jan 17, 2018 | Ford Cars & Trucks
My 9 year old Nelson raintrain leaks (gushes) water out of transmission housing (at about a rate of 50%) Sprinkler will still operate but at a considerably reduced rate.
not knowing that model,, look for a gasket that can be replaced, if not, the case itself has probably cracked, a local welding shop may be able to repair the crack.
Jul 10, 2011 | Nelson Sprinkler: Traveling Tractor
Our raintrain has worked for years....but now it is leaking out of the bottom causing it to get stuck often......please help us!!!!
I think your valve is shot. There is a button underneath that is pushed up by the ramp. It then closes the valve. The valve is leaking and lowering your water pressure causing your sprinkler to get stuck.
You could replace the valve but that requires disassembly of the gear box. The gears inside may be worn too so, I am suggesting that you just replace the gear box. Replacing the gear box will give you all new moving (and sealing) parts. This web site has a box for about 1/2 to 1/4 the price of a new sprinkler.
http://www.sprinklersupplies4less.com/traveling-sprinklers-nelson-1865-replacement-parts-c-384_627.html
Jul 08, 2011 | Nelson Sprinkler: Traveling Tractor
Hi my nelson tractor leaks from bottom of gear box
heatman101
Apr 29, 2011 | Nelson Sprinkler: Traveling Tractor
Oil leaking from bottom of gearbox
if a manual gearbox ,then its fairly easy to repair without stripping box and thats to pump a grease gun full of LM grease into gearbox as the grease will settle in the bottom of the box stopping the oil leak but a auto box will require looking at
Mar 12, 2011 | Volkswagen Golf Cars & Trucks
NEED THE BOTTOM PART ON NELSON WALKING SPRINKLER. PART THAT HOLD AXEL IN PLACE AND THAT HOSE HOOKS ON TO
heatman101
Aug 21, 2010 | Nelson Sprinkler: Traveling Tractor
One of the gears are striped out on the inside of gearbox
heatman101
Aug 17, 2010 | Nelson Sprinkler: Traveling Tractor
My Whirlpool washer is leaking oil out of the bottom and onto the floor. Model# LHA5500WI. How can I fix this problem? It has a 1/2 hp motor, 1725 rpm, 1440 rpm, rubber mounted.
The leak would be from the gear box. The seals on the gearbox are worn out.
Best to get technician to remove gearbox, and have it reconditioned.
Regards
Ash
Oct 21, 2009 | Whirlpool Washing Machines
Vacuum reservior 1996 Jeep Grand Laredo
The vacuum res. is a black (can,football,round) shaped item. I do not remember if it is behind the bumper on the pass. side of car. It could also be under the hood on the pass. side. Pass. side under the hood are vacuum lines, follow them, one will go to the res.
Nov 02, 2008 | 1996 Jeep Grand Cherokee
Nelson Sprinkler:  Traveling Tractor Logo
315 people viewed this question
Top Nelson Garden Experts
Dennis
Mike Squire
Phil Walker
Phil Walker
Are you a Nelson Garden Expert? Answer questions, earn points and help others
