Question about Gemini Sound Products Napco Gemini Gem-rp8 Fixed Display Designer Keypad
I have a NAPCO GEM-RP8 and the door chime stopped working for when a door is open. Found the manual and it says to press function button then 5 to turn back on, but this did not work... any idea's? Is there a way to reset it? Thanks
2 Suggested Answers
  • 78 Answers
SOURCE: I have a Napco Gem-P800 Security System and the
First thing its not the resistor. The resistor is there only to make sure the siren wires are ok and not tampered with. Second found this in an install manual.
Bell Test
Enter this command to turn on the Bell, keypad
sounder and keypad LEDs for 2 seconds. The
battery is tested during a Bell Test, and automatically
every *24 hours to ensure proper battery
operation under load. The Alarm output
requires a battery in order to supply the specified
output. If the battery cannot sustain the load, a
low battery indication will be displayed. A battery
test is also performed on power-up after a 3
minute delay.
if the battery fails test replace it and try again.
Assuming no programming changes were made to the zone types that would diable the bell output. if this does not help, time for an upgrade. : ( GL
http://www.napcosecurity.com/images/panels/GEM-P800_WI850a_INST.pdf
Posted on Jul 27, 2011
Where can i find Heath zenith SL-6273 manual or how do i make the product play mp3
Most Heath Zenith product manuals are available here: https://www.heath-zenith.com/support/owners-manuals . Searching for the SL-6273 found two versions of the wireless MP3 door chime. The direct link to the manual for the SL-6273-00 is https://www.heath-zenith.com/system/spree/documents/attachments/000/000/839/original/205371-02A.pdf?1436551434 .
Put the batteries in the door chime. To transfer an MP3 to the door chime, connect it to a computer with a USB cable. Open the folder to view files and drag the new (short, <= 20 seconds long) tune into the folder. Eject the door chime (like any USB hard drive) and remove the USB cable from the door chime.
Next press the Tune button to cycle through the tunes on the door chime for the front door chime. Stop when the desired tune is played. That will be played any time the front chime is pressed. If you add the jumper to pin 8, the door chime will ding as that is the rear rear door sound. For the front door, make sure that the switches (1-7) on the push button match those for the door chime.
I hope this helps.
Jun 02, 2017 | Heath Zenith Home Security
How to change code user 1 on a gem-rp8
I am in the same boat. We bought a house with this system installed in it. How can we change the user 1 code?
Nov 10, 2013 | Gemini Sound Products Napco Gemini Gemrp8...
Courtesy Chime Chime Chime will not shut off. What do I have to do to troubleshoot the GEM Module and whatever is connected to/through it?
If the chime includes the cab light staying on as well:
There is a door switch in both the driver and passenger side doors that needs attention. I too had this problem. Solution: squirt wd40 onto the switch located near the door latch on both driver and passenger side.
Dec 26, 2012 | 1995 Ford Ranger Supercab
I have a 96 ranger and the ignition chime never shuts off. The only way to make it stop is to pull fuse #25 which is gem system and speedometer. What could the problem be? I'm thinking replacing the...
There are no codes for this. The issue may be that the gem is getting a driver door open signal or the gem itself is bad. I got a used gem at a salvage yard for $20 recently, but make sure its not the door switch first. You can pull the connector off the switch and use an ohmmeter to see if the wire is grounded. If it is, trace it to the gem to find where it is getting cut into.
Nov 14, 2017 | 1996 Ford Ranger SuperCab
I think i have a vista keypad. I dont have a manual that shows the keypad features. I like for the doors to chime when opened. They stopped chiming for some reason. can this be reset.
On a vista system, enter your 4 digit code and press the 9 button. The keypad should read: Disarmed Chime. The keypad should ding ding ding when a door is opened. To turn the chime off, enter you code and press the 9 button again.
Jun 18, 2011 | Honeywell 6160 Vista Custom Alpha Keypad
Key fob not working i have changed the battery
hi.
the fob probably needs to be rematched to the car again.
EASY>>>>>
Reprogramming an X-Type Key Fob.
Step 1
Open the
driver side door.
Step 2
Turn the ignition switch to the
'auxiliary' position, then turn the ignition switch to the 'ON' position and
back to the 'auxiliary' position four times. *This must be done fairly quickly.
If you have done it correctly, you will hear a chime come from the
GEM*
Step 3
Turn the ignition switch to 'OFF' position.
Step
Remove the key from the ignition.
Step 5
To program the
transmitter, press any key within ten seconds. **If it worked, you should hear
another chime come from the GEM**
Step 6
Close the door...YOU'RE
DONE!
I have done this on my dads x type. it does work. do not forget to have the drivers door open like i did.
Jun 09, 2011 | 2004 Jaguar X-Type
All windows will not work on my 2005 ford taurus
2002 taurus. don't have 2005. Sorry.
Could be your GEM module. Call your dealer and ask if your 2005 has GEM module. It's expensive so be sure it is problem first.
Dealer can test with NGS tool.
CAUTION: Once the new module is installed, it is necessary to download the module configuration information from the diagnostic tool equipment into the new module. For additional information, refer to Section 418-01 .
Principles of Operation
The generic electronic module (GEM) constantly monitors its subsystems for concerns. If a concern is found in one of the subsystems, the GEM will record the concern in the form of a diagnostic trouble code (DTC).
The ignition switch position is very important to the GEM functionality. Erratic or unexpected GEM functions can often be traced to problems with these ignition GEM inputs.
The GEM controls a variety of systems:
  • windshield wipers
  • courtesy lamps
  • warning chimes
  • keyless entry
  • interior and exterior lamps
  • power windows
  • parking brake actuator warning chime
Inspection and Verification
  1. Verify the customer concern by operating the system.
  1. Visually inspect for obvious signs of mechanical and electrical damage.
Visual Inspection Chart Electrical
  • Central junction box (CJB) fuse 216 (15A)
  • Damaged wiring harness
  • Loose or corroded connector(s)
  • Circuitry
  • Generic electronic module (GEM)
Mar 27, 2009 | 2005 Ford Taurus
Key on engine running trouble code 55
Warning Chime Systems The generic electronic module (GEM) will sound the following warnings:
  • key-in-ignition warning
  • safety belt warning
  • headlamp switch ON warning
  • door ajar warning
Headlamp Switch On Warning The generic electronic module (GEM) sounds when the driver door is opened while the headlamp switch (11654) is in the PARK or HEAD position, and continues to sound at a rate of 4 chimes per second until the headlamp switch is turned off or the driver door is closed.
  • When the headlamp switch is in the PARK or HEAD position, power is supplied through Circuit 293 (O/R) to the GEM.
  • When the driver door is open, the driver door open warning lamp switch (10B997)is closed and ground is supplied to the generic electronic module (GEM).
A delayed headlamps on repetitive chime will sound for a period of three seconds beginning twenty seconds after the key is turned to OFF, LOCK or ACC, the headlamp switch is in the PARK or HEAD position, and the driver door is closed. Delayed headlamps on is terminated by opening and closing the driver door again.
Door/Liftgate Ajar Warning The door/liftgate ajar warning functions as follows:
  • The generic electronic module (GEM) sounds a warning tone for one second when any vehicle door, liftgate window or the liftgate is ajar without any other door already open and the ignition switch is in the RUN position.
  • Power is then supplied through Circuit 627 (BK/O) to the door ajar warning indicator lamp which remains illuminated until all doors are closed or the ignition switch is no longer in the RUN position.
Key-in-Ignition Warning The generic electronic module (GEM) sounds when the LH front door is opened with the key in the ignition switch and continues to sound until the key is removed or the door is closed.
  • When the key is in the ignition switch, the ignition key warning switch terminal and wire (11A128) is closed and ground is supplied through Circuit 158 (BK/PK) to the generic electronic module (GEM).
  • When the LH front door is open, the LH front door open warning lamp switch (10B997) closes and ground is supplied through Circuit 57 (BK) to the generic electronic module (GEM).
Safety Belt Warning When the ignition switch is turned to RUN or START from the OFF or ACC position and remains in RUN or START, the chime will sound for six seconds or until the safety belt is buckled. The safety belt warning indicator lamp (10C859) will turn on for 60 seconds, or until the LH front safety belt is fastened. Both the chime and lamp activate at the same time. If the safety belt is buckled when the ignition key is turned to RUN or START from OFF or ACC, the lamp will prove out for two seconds, but chime will not be activated. Any time the key is changed to RUN from START while the safety belt warning indicator is activated, the safety belt warning indicator will remain activated until either the timing sequence has been executed, or the safety belt is buckled.
Feb 25, 2009 | 1999 Ford Taurus
Need programming instructions for RKE for 2000 Mazda 626
2000 Mazda 626
Note: Make SURE the battery is new.
Instructions for programming ONE keyless remote fob.
1. Open the driver’s door & leave open.
2. Insert the key in the ignition.
3. Turn the key to the on and off position 3 times.
4. Remove the key from the ignition.
5. After door open chime stops, press the door open button 3 times.
6. After chime, press any fob key twice.
7. After second chime, press any fob key twice again.
8. After third chime, press any fob key twice again.
9. Press the door open button once.
10. The car should give another acknowledgement chime.
11. Test key fob.
This DOES work. I just programmed mine successfully today, three hours ago.
Sep 03, 2008 | 2000 Mazda 626
2000 MERCURY SABLE
you need to have your GEM module reconfigured after battery disconnect. It controls many functions. It may have also been damaged during battery change due to a voltage spike. Dealer can test it. Call a dealer service dept and describe symptoms and see what they say.
Module Controlled Functions NOTE: Prior to removal of the generic electronic module (GEM), it is necessary to upload module configuration information to the scan tool. This information needs to be downloaded into the new module once installed. For additional information, refer to Section 418-01 .
NOTE: Electronic modules are sensitive to electrical charges. If exposed to these charges, damages may result.
The generic electronic module (GEM) is the only multi-function module on this vehicle.
The GEM constantly monitors its subsystems for concerns. If a concern is found in one of the subsystems, the GEM will record the concern in the form of a diagnostic trouble code (DTC).
The ignition switch position is very important to the GEM functionality Erratic or unexpected GEM functions can often be traced to problems with these GEM inputs.
  • instrument cluster warning indication and chimes
  • interior courtesy lamp control
  • automatic headlamp control
  • daytime running lamps (DRL)
  • wiper and washer (front only)
  • heated rear window
  • one-touch down power window
  • delayed accessory
  • power door locks (including SMART, autolocking and luggage compartment lid release)
  • remote keyless entry
  • perimeter anti-theft
The ignition switch position is very important to the GEM functionality. Erratic or unexpected GEM functions can often be traced to problems with these GEM inputs.
Aug 20, 2008 | 2000 Mercury Sable
Gemini Sound Products Napco Gemini Gem-rp8 Fixed Display Designer Keypad Logo
304 people viewed this question
Top Gemini Sound Products Home Security Experts
Lawrence Oravetz
Are you a Gemini Sound Products Home Security Expert? Answer questions, earn points and help others
