Question about Keurig Platinum B70 Coffee Maker
The red rubber O ring on the upper needle keeps falling out
The detergent latch on my Whirlpool Quiet Parter III dishwasher keeps falling out. Not the lid...just the little gray latch with the red rubber ring.
I would replace the dispenser. It is made out of plastic and only holds so long. If you provide with me with the model #, I will supply you with a part # to purchase.
Mar 12, 2014 | Dishwashers
Needle keeps falling out of Pfaff Creativ 2170
change ur needle bar and also check needle size before insert in it.
Sep 14, 2008 | PfaFF Sewing Machines
Tip
Saeco Italia automatic espresso coffee machine Grinder Cleaning Instructions
Saeco Italia Grinder Cleaning Instructions
Removal
Step-1: Remove beans that are in the bean hopper without spilling them inside. (Use Vacuum).
Step-2: Remove the beans container by removing 3 phillips head screws. Remove the rubber gasket from below the hopper. At this stage the upper burr will be visible.
Step-3: Rotate counter-clockwise the outer ring of the grinder assembly (the ring has gears half way around), until the red mark is at the 9 o’clock position, looking at it from the front of the machine.
Step-4: Lift the upper burr by using the fins that are on top. Press lightly on the doser adjustment gear, to clear it from the dose adjustment gear.
Cleaning-
At this stage, the grinding chamber will be exposed. Clean out any crushed coffee in the grinder chamber and the burrs. Use Vacuum and cleaning brush.
To Re-Assemble
Step-1: With the red mark on the outer ring still at the 9 o’clock position, replace the upper burr back into the grinder. Make sure that the red line (on the upper burr) is at the 3 o’clock position. This position will align the other tabs as well. During re-installation, press slightly on the doser adjustment gear so the upper burr will clear it as it is placed back in.
Step-2: With the Upper burr in place, rotate the outer ring clockwise until it stops. The two red marks should be aligned at the 3 o’clock position underneath the doser adjustment gear.
Step-3: Replace the soft rubber gasket back on the upper burr. Use the fins to align it properly.
Step-4: Slide the doser adjustment gear toward the front of the machine until it stops.
Step-5: Before replacing the bean hopper, rotate the grinder adjustment wheel to Zero (0), and the doser adjustment wheel to Minus symbol (-). Place the bean hopper into position on the machine, slightly adjusting each adjustment wheel as you are placing it down in the machine. Once in place, fasten the bean container with the 3 screws. Test each adjustment wheel through the full range of motion. The grinder knob rotates from 0 to 18 and back, and doser knob from Minus (-) to Plus (+) and back.
Now position the grinder adjustment knob at Eight (8) and the doser adjustment knob to the halfway point between the Plus (+) and the Minus (-) marks. This will put the machine back to the factory setting.
When using for the first time after adjusting the grinder, it may take more than one grinding cycles to make the first cup of coffee.
on Aug 12, 2010 | Coffee Makers & Espresso Machines
I have a K10 mini cup keurig brewer. It worked fine until this morning. When I try to brew a cup, it comes out the top. It does with this with or without a k-cup in. I tried to clean out the needles...
First: You need to check a Upper Rubber Gasket (fits around the top puncture pin). If it missing you will have leakage because here's no seal to protect leakage. You can buy it online or call Keurig Customer Service (if you still have warranty)
Second: Upper Rubber Gasket not making a seal with the K-Cup or Reusable Filter and the water and/or coffee grounds leak out. To fix it simply move Upper Rubber Gasket 1/4" down. This should close the gap between K-Cup and upper needle.
Oct 27, 2013 | Keurig Coffee Makers & Espresso Machines
Keurig leaking from bottom
Check the Upper Rubber Gasket (fits around the top puncture pin). If it missing you will have leakage because here's no seal to protect leakage. You can buy it online or call Keurig Customer Service (if you still have warranty)
OR:
Oct 07, 2013 | Coffee Makers & Espresso Machines
the best thing would be to take the machine to a sewing machine shop & have them check to see what's wrong with the needle holder, cause if there's a something broken it will have to be replaced
May 29, 2012 | Singer 7444 Mechanical Sewing Machine
The thermostat will not stay in place no rim to stop it from falling in side engine housing i have the rubber that ataches on part but theirs nothing to stop it from falling in side first i've ever saw...
Buy a can of permatex gasket adhesive. Spray dome onto the gasket, thermostat housing and thermostat (make sure only to apply to where the gasket contacts the thermostat) and let it set up. It acts as a contact cement and will make it much easier to install your thermostat.
Mar 08, 2011 | Buick Century Cars & Trucks
How do i oil my bernina 801?
There are two key points I suggest customers can do themselves to help lengthen the life of their machine. One is your hook and the other is the needle bar...
Hook - Open your bobbin door, removee the bobbin case/bobbin. On the upper left corner there is a small latch, push in the latch and your shuttle race ring will fall down forward. You can now remove your stainless steel hook. You need to keep this hook clean and the lip it fits back into clean and void of lint and debris. On the back of this hook or the "lip" that the hook fits back into apply a small amount of hook/sewing machine oil.
Needle Bar - Open up your head cover, the needle and needle bar clamp is attached to a long stainless steel rod that travels vertically inside your head. All sewing machines have a needle bar that looks like this. This bar travels thru two brackets attached to the frame of the machine. Rotate your handwheel and clean the needle bar well of debris. Rotate the handwheel so that the needlebar is in it's highest point and apply a small amount of oil to the upper and lower bracket of the frame, rotate the handwheel so the needlebar slides back down and therefore lubricating it and the inside of the brackets.
Hook oil or sewing machine oil is relatively inexpensive from all quilt, sewing machine, repair shops. Be sure to take your machine in a minimum of every three years for proper cleaning and lubricating of all the other parts (This is of course for average home sewing machine use 8hours a week)
Dec 02, 2008 | Bernina Artista 180
Brother 1034D
I had the same problem with the blue thread- it would sew and inch then pop- mine worked wihtout breaking after I re threaded in this order: green, blue, red then yellow
Jun 08, 2008 | Brother 1034D Mechanical Sewing Machine
Keurig Platinum B70 Coffee Maker Logo
53 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
