Question about Peg Perego My First Craftsman Tractor Ride-on
I need to get the wheels for the tractor - Peg Perego My First Craftsman Tractor Ride-on
  • vickydeonari May 19, 2011
    how can i get the wheels
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Do you still need the wheels i can order you some
Posted on May 14, 2012
Front wheel alignment
Wheels are to straigten. Best to replace.
Jun 11, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I am working on cub cadet lawn tractor lt 1050. how do i remove and replace the rear axel?
Hello.
SOLUTION ON How to Remove Lawn Tractor Wheels.
Owning a lawn tractor to take care of the grass and yardwork is convenient until the tires need repairing. It is inevitable that sooneror later the tires will go flat and need replacing. You can replace the tiresonce you know how to remove the wheels on your lawn tractor. Unlike automotivewheels which have several lug nuts, the lawn tractor tire requires only theremoval of a retaining ring to release the wheel from the axle.Front Wheels
  • 1 Park the lawn tractor on a level surface. It is better to park the lawn tractor on the driveway or solid shop floor rather than the lawn. Place a floor jack under the front frame and jack the mower up until the front tires are six inches off of the ground.
  • 2 Place jack stands under the frame on each side of the jack and lower the jack until the frame is sitting on the jack stands. If the mower is on the lawn, place a piece of plywood under the jack stands to avoid sinking the jack stands into the lawn.
  • 3 Pop the axle cover off of the center of the wheel. You can pry the cover off with a small flathead screwdriver or grab the cover with a pair of pliers and twist the cover off of the axle.
  • 4 Pull the retaining ring from the axle with a pair of needle nose pliers. Grab the ring from the closed side and pull the ring straight from the side of the axle. If necessary, use a flathead screwdriver to aid in spreading the open part of the ring so the ring will slide off of the axle.
  • 5 Slide the two washers off of the axle and then pull the wheel off of the axle.
Toolsneeded to solve the problem below. Floor jack,Pair of jack stands ,Small flathead screwdriver ,Needle nosepliers ,Vice grips
THEN SOLUTION ON How to REPLACE Lawn Tractor Wheels.
Thanks
Sep 15, 2011 | Garden
My lawn tractor pulls to the right when driving can i fix this?
The Toe In/Toe Out will have to be adjusted (if the steering rods to each front wheel have sleeves), just like on a car.
Toe-in is the operating angle of front wheels on a riding tractor. If the front edge of the wheels point inward, towards each other, then the wheels have toe-in. If the front wheels point outward, the unit has toe-out (or negative toe-in). Adjustment of toe-in is necessary to maintain proper steering control.
Unlike automobiles, our tractors have pre-set camber and caster settings. Therefore no camber or caster adjustment is necessary.
Acceptable toe-in adjustment range for all of our lawn & garden tractors is anywhere between 1/16"-5/16". With 1/8" serving as the optimal range.
Detailed toe-in adjustment procedures for the various models of tractors are reviewed in the "Adjustments" section of the Operators Manual for the tractor.
If tires are not toed-in properly after adjustment, it is likely that other part(s) need service or adjustment. axles, wheel bushings, control arms and other steering components may be worn or damaged and will need inspection. Service these items as needed.
You haven't stated your make and model, so I can't send you the manual with the exact procedure for your machine.
Jun 12, 2011 | Garden
I need to locate a owners manual for a wheel horse 1978 312-8 tractor
I have found this older printed manual of a Wheel Horse lawn tractor for sale on the internet.
http://www.atomicmall.com/view.php?id=705372
I have NOT located the manual for your exact model yet.
How do you fix the front wheel alignment on a 48 inch lawn tractor by Craftman. The wheels are turned to the outside. Theres no bent rods or anything. Whenthe wheels go one way in the frony. you mow the...
make sure tie rod between wheels is straight. if bent will cause wheels to turn outward. take tie rod loose at each wheel, straighten rod reinstall wheels should be straight.
Aug 21, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I just changed the rear tires and now, coincidently, I have no drive from the engine to the tractor. It looks as if the clutch is not engaging. Also, the foot brake has just slopped around for some time...
I am assuming that you are working on a lawn tractor.If so then one of you rear wheels is now missing the wood-ruff key(square key-stock that goes between the wheel and the axle),and now the easiest wheel to turn is the one with no load so your axle on that side is just spinning inside the wheel.The brake rod needs to come off and the end turned in a couple of turns to fix your other problem.
Aug 06, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Aug 22, 2009 | Garden
The steering wheel on my toro lawn tractor is loose - teeth won't engage. It doesn't look like the teeth are broken - can I loosen the plate on the tractor that is attached to the wheels and adjust to fit...
no; you'll need a new steering shaft and a steric gear.( i just did this on mine) this will be your best result.as they wear @ the same time both need to be replaced.hope this helps
Jul 27, 2009 | Garden
Rear wheels locked
To move tractor you can remove one of the back wheels and remove key in shaft then replace wheel you should be able to move it .
May 06, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Peg Perego My First Craftsman Tractor Ride-on Logo
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
