Question about Garden
Snowblower transmission/friction wheel issue? I have a TroyBilt two stage snowblower with 8.5 HP Tecumseh engine. It is about 4-5 years old. It starts without a problem and all reverse and forward gears work. This year I noticed that it was not throwing the snow very far and I had many more jams/clogs on the second stage that is supposed to throw the snow. When trying to blow larger amounts of snow I noticed it does not rev/gear down like other snowblowers on my block I've observed. I've read that snowblowers don't have a transmission but a friction wheel. Would issues with a friction wheel cause this behavior? If so what should I look for when I attempt to open it?
  • 70 Answers
SOURCE: snowblower manual
Not sure if your looking for a parts manual or a user manual but if you go here you can find the parts manual:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=536.885921
Posted on Dec 22, 2008
  • 42 Answers
SOURCE: connecting throttle linkage on brigs & stratton snowblower
here is a site that may help you. I hope so, these things can be a real pain in the neck. let me know if you need any more help, I would be glad to help you.
http://wssemw.arinet.com/scripts/EmpartISAPI.dll?MF&app=EWSS&session=9ea7684f-6a4b-45b9-89c9-d4a5ad4e20da&cat=27&TF=epcFrame&assem=62752&highlightNode=No&selAssem=123060&mdDescrip=130232-0676-99
Posted on Mar 12, 2009
harlan301
  • 205 Answers
SOURCE: how do I change ariens snowblower belts
on some blowers you have to remove the front auger sya in order to change the belt. it a pain. look down from the top to see if you have room to slid the belts throw, if not remove the front auger
Posted on Oct 12, 2009
jdlipscomb41
  • 157 Answers
SOURCE: i was given a craftsman 9 hp snowblower i believe
if the holes in the frame will match the holes in the engine and nothing is in the way and shaft is the same it should work and definantly will work with some modification
Posted on Oct 26, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a 1984 ariens snowblower with a Tecumseh and no spark
Electronic Ignition was introduced on many engines about that time frame. I would need to have model and type numbers from the engine to fully determine that question. However, have spark is still the issue. If the unit has a switch installed on the operator's console, it should be disconnected at the engine so that any safety switches are not masking or causing a problem that is not engine related.
Let's investigate a few basics first.
a) How have you determined that there is no spark?
b) Have you used a type of spark tester?
c) What is the condition of the plug. Brown or dark brown is OK. Black or silver is NOT Ok.
*If you do not have a spark tester,
a) remove the plug, and with it connected to the wire,
b) find a portion of metal around the cylinder that you can ground it on, and then pull the rope.
c) If the plug is black, you may see spark, but you should replace the plug.
*** PLEASE NOTE ; if there is excess fuel in the cylinder or on spark plug, it can catch fire, so be carefull to cover the hole with a heavy rag so that any fuel cannot be exposed to spark plug durning test !!!!
Get back with me on how this issue works out.
thanks, rwvanlue
Posted on Nov 13, 2009
My snowblower starts then stalls
Rob; 95% sure it is a carburetor issue, dirt clogging a port or jet,float sticking. I will post a few sights below to show how to clean carb.
How to Fix Snow Blower Carburetor
HOW TO Clean Rebuild Tecumseh Snowblower Carburetor PART 2 OF 4
how to rebuild snowblower carburetor
Jan 30, 2016 | Cars & Trucks
Troybilt snow thrower wheels lock up cannot push or pull. Model 5524. Whats up?
Sounds like friction disk is not retracting for pressure plate. Flip snowblower up on front end and take out 4 or 6 bolt out of cover plate. wheels will be in the air so try to turn wheels and look. Your fiction disk is the rubber wheel that moves with you gear shift lever. It should not be touching round metal plate unless your handle on bars is push down to in gage drive. Most snowblowers have a spring to pull metal plate back your probably broke or rusted off.
Feb 24, 2015 | Garden
How do I replace 590787 rewind starter on craftsman snowblower?
ARE YOU REPLACING WHOLE THING OR JUST THE ROPE?
if replacing whole thing just unbolt the 4 nuts
Oct 17, 2014 | Garden
My snowblower Yard Machines 26" 8HP started but
Clean the carburetor and check the intake manifold to the head for air leaks/bad gaskets.
Jan 13, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
