Question about HP DeskJet 1280 InkJet Printer
Power on problem
When I switch on the power button of Hp Deskjet 1280, it comes for a moment and goes off soon. What should I do to solve this?
  • 6 more comments
  • habtamubiaz Aug 22, 2008
    No. I have got the problem. This is not the solution.
    The rear switch was open. When I close it, it has come. So I have solved the problem.
    Anyway if there is such a problem with any other person, this may be helpful.
  • dancer716 Sep 08, 2008
    My HP Deskjet1220C has the same problem, which has been progressive. It used to turn on after I pushed the on button several times, then only after I pushed the middle button (paper-feed) at the same time, now it never goes on, even when I disconnect power, leaving switch on for 10 sec., etc. The light goes on for an instant, then off. All 3 lights will light up if I push their switch along with the power button, but no power. Is this an expensive repair bill?
  • Nilo Limsan Sep 17, 2008
    i have same problem with habatamubiaz, i tried to hold the power button in 10 seconds and it does not fix the problem, i somebody can help me please notify me.. thanks...
  • Ultan Oct 02, 2008
    Amazing - the same thing has happened to mine. I had a paper jam the day before but no obvious connection. The power supply, continuity etc has been checked and all are fine.
    Any help would be gratefully received.
    Thanks,
  • Ultan Oct 09, 2008
    I have concluded that the circuit board is dead. It costs more than a new printer to repair so I am going to throw it in the bin - not sure what to do with my spare printer cartridges as it is proving difficult to source a replacement 1280 - lesson learned - never stock up with consumables.
  • lux5 Nov 27, 2008
    Hi Team,
    I have HP OJ 4255 All in One printer,
    when I switch on the printer
    I get the ERROR Message " 0xf0af8005 "
    What would be the problem,
    Thanks
    Lux5
  • jooneo Jan 21, 2009
    My 1280 printer was working beautifully until this afternoon when I switched it on. The light came on briefly then went off and doesn't come back on again unless I unplug the power cord and press it again. The ink cartridge button comes on when pressed, but when I open the lid the ink cartridges normally move out of their dock and into the middle but they don't now. Needless to say I can't print from it and have tried moving the power supply to another socket and connecting it to another computer but still the power light only briefly comes on and I can't print.
    HELP please ..........
  • bettygargiul Feb 22, 2009
    I have the same problem with the power that switches on just for a few seconds and then its dead. I just tried to buy a new power cable as i thought that migth have been the problem but nothing...if anyone has found the solution to this please post it!!! would help all of us out...its very strange as i have this printer from 3 years...and it has always worked!!
I have had the same problem more than once, it is not broken! do not throw away or send it to someone to be fixed! I am guessing that everyone with this problem has had a paper jam which involves taking off the back panel. If this is the case then it is simply a case that it has not been put back properly. I thought for several attempts I had but it back properly, but there are 4 pins which come out the side when you turn the catch, unless these are fully extended it will not work. You will know when it works because turning the catch is smooth. So even if it seems that it is in if the printer still doesnt work try again.
Luckily I had the problem the first time 3 days before the warranty expired, so tech support told me to replace the cover and it worked first time. This time a year later I thought I was doing the right thing but didnt realise until many attempts later that the cover wasnt reconnected when i thought it was.
Posted on Nov 21, 2008
The problem is the rear door not "correctly" closed. Try to remove it and put again in place. I've got the same problem twice, and both times I was sure the door was closed, but when I double checked it wasn't.
Posted on Jan 13, 2009
Tried the 10 second press ... no joy
Posted on Sep 05, 2008
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Hmmm...sounds like there's a problem with the power supply perhaps.
unplug from wall outlet(not power strip)
press on button..plug back into wall directly..hold button for 10 seconds, and release.
see if that helps at all
Posted on Aug 20, 2008
1 want to hepl me about this problem
Posted on Oct 09, 2008
HP Deskjet 1280 Does not Switch On - only flashes the ON light for One second
you should reset the printer .
press resume button 3 second. release the resume button .May be your printer ready.
Feb 27, 2014 | HP DeskJet 1280 InkJet Printer
My HP 1280 Deskjet printer doesnt print any paper even the test page and the LED of the ink cartredge still falshing while i fill the ink cartredge and its not empty so what I can do plz help because my...
hello
the problem of your printer is the mechanical board try to switch off for the moment and turn back on, remove the plug form the wall outlet. leave it off for 5 minutes.
thanks
Feb 28, 2011 | HP DeskJet 1280 InkJet Printer
There is no power in hp deskjet 1280 printer
It is a problem with printer power card or other hardware problem.You can checked it by service center.
Jan 05, 2011 | HP DeskJet 1280 InkJet Printer
Does not switch on
My Hp Deskjet does not switch on. Once a press the power button the light remains on for about a second and thurns off . Is this a problem with the power supply what should i do plz help me
May 20, 2009 | HP DeskJet 1280 InkJet Printer
Print
hmmm..ok..power down completely..
unhook from computer
press button on power panel down..hold it for ten seconds, while plugging in power cable again..
system should go through start up sequence
then try a test page..
if not , time for factory service.
Aug 06, 2008 | HP DeskJet 1280 InkJet Printer
HP Deskjet 1280
I have found you need to be very accurate with the placement of the of the paper guide box and ensure it is completely locked in to ensure the printer will turn on.
This is the manual feed box at rear of the printer.
Cheers
Yoga2
Jun 16, 2008 | HP DeskJet 1280 InkJet Printer
My hp deskjet 1280 printer is not coming on
well..sometimes when a paper jam occurs, it shuts the whole system down..
you may wish to remove the s/w for that printer through control panel
go here for updates drivers
re install the s/w
run test page, calibrate and clean cycles.
Mar 27, 2008 | HP DeskJet 1280 InkJet Printer
Problems printing with HP Deskjet 1280
When I printed powerpoint documents on a hp deskjet 1280 it failed to print lines. I found that this problem could be solved by changing the transparency attribute of the line to 50%. The transparency attribute of a line or shape can be found by clicking on the sequence format/shape-outline/more-outline-colours/transparency at the top of the screen
regards
Graham Pratten
Feb 29, 2008 | HP DeskJet 1280 InkJet Printer
Power problem
I'ts because there are a paper jam
I have the same problem and I solved it myself
-.... look into the lock behind the printer remove it then put it back again >>>>>>>>
Dec 17, 2007 | HP DeskJet 1280 InkJet Printer
HP DeskJet 1280 InkJet Printer Logo
172 people viewed this question
Ben Johnson
