Question about Hoover Vacuums
I understand I can download a manual for my Hoover Commercial vac, but when I enter the model number (C1401) I'm told there is no such model. Can you point me to where I can obtain a repair manual for this machine? Thank you! Walt Friedrich
SOURCE: Hoover Steam-Vac Cleaner F5861-900 Series 17.9 Can't Find User Manual
http://www.hoover.com/pdfs/manuals/F5914900.pdf
this one works well as a replacement for the manuel.. everything is the same.
Posted on Dec 02, 2007
  • 909 Answers
SOURCE: Lost Manual for Hoover Steam Vac Model #5906-900
Visit www.hoover.co.uk
There you can pick after sales service,instruction manuals, etc. etc.
You will find your manual there.
I hope this helps
Posted on May 13, 2009
SOURCE: My Hoover steam vac spin scrub model 4060-900 brushes are not spinning and I have lost the manual. Any ideas. Thanks. bushteachers@yahoo.com
The problem I found with one a neighbor was tossing out is the bearings in the part that drives the brushes were stuck. Lubing them up solved the problem, but took a bit of work to get into. This also provides a good chance to clean the crud out of bits that usually don't get much attention. I found mine clogged with a fair amount of pet hair.
You'll need a Phillips & Flat Screwdriver, some light machine (3-in-1) oil or Lithium (white) grease, and a lot of patience. Having a pan or something handy to keep all the little bits organized would help.
First remove both the soap & recovery tanks, they'll just get in the way & are designed to be easily removed & replaced for filing/dumping. Be sure to fold the "wings" for the recovery tank in or they'll foul removing the cover later (as will the brush speed button).
The tricky part is getting the Brush Speed knob off. It's held on only by friction, but can be tough to pull for without breaking the plastic stick it's pushed onto.
Remove the brushes. There are 4 blocks between the outer & next in rollers. Put the flat screwdriver between the gray & clear plastic, pushing gently toward the brushes. This pushes a wedge away far enough from a hole in the gray plastic to "unhook" the brush housing from the main body. Once all 4 are clear, the brush assembly should pull out easily.
Remove the 2 big screws in front of the brushes and the one at the back of the clear plastic front of the vacuum bit. The small ones at the extreme front corners hold on the clear plastic front, and can be removed if you want to clean out the vacuum channel, but are not necessary to remove to remove the top.
Toward the back sides of the top are 2 slots that hold this part on. Once the front screws are removed & the front is loose, push the side in gently & you should be able to lift the back of the cover. Push in lift both side, the top should pop right off.
Now I have the top off, holding 2 black & 1 silver long screw. In the center-front of the new-exposed guts is a box with a round top & a cone at the front with 2 screws.
This is the Brush Motor Assembly, and it's actually vacuum-powered. Remove the 2 screws holding down the from, then look for 2 large holes on the bottom of the unit behind the black "squirter bar".
There's very long screws at the bottom of these holes that also hold down the brush motor.Once the 2 bottoms screws have been fully loosened & the top-front screws removed, the brush motor should pull up easily.
On the right is a square port, in front the the brush speed stick (where the gray button pops onto). on the left is a gray & black hose, these should pull off easily, but may have some liquid in them.
Pull out the brush motor & set it on a convenient spill-resistant work surface upside-down. You should see the square-hole drice for the brushes, a gray piece of plastic, & a cresent-shaped hole.
The port at the front & hole on bottom provide an air path for the vacuum to poll air through this assembly & spin the brushes. You should see 2 screws at the back of the motor & 2 more at the bottom of holes surrounded by the gray plastic. Remove all 4 screws.
You can now pull off the bottom cover with the gray plastic. Front to back you should see the brush drive gear, an intermidiate gear, ant one of the bearings for the fan that drives the whole thing. pulling out the bearing & gears to clean out this area & lube up the gears with some Lithium Grease helps, as well as making sure the bearing is well lubed with 3-in-1 oil and/or lithium grease.
The top is held on at this point with 4 platic clips. The top doesn't need to be removed unless you *really* have to see the fan. The clips can be broken off if one is not careful, and there's nothing in there to be lubed. Best to leave it as-is.
At the top of the driveshaft is a second sealed bearing. I couldn't figure out how to get it out without braking it, lube this one in place. The bearings are supposed to be sealed, so removing the black "washer" from the bearing is done completely at your own risk. I just put some oil on there, spun it to work it in, then repeated with the white grease.
Replace the intermediate gear, the brush drive gear, then the lower sealed bearing in that order. You can spin the gears to ensure they're spinning well. Mine was OK, but after a bit of use worked the grease in & the brushes really started spinning.
Keep in mind everything here except the screws is plastic, be creful to get a snug fit with the screws without overtightening. "Gorilla-ing" the screws will just break the plastic & make the whole adventure an exercise in frustration.
Reattach the bottom plate with all 4 screws, 2 in the holes in the gray plastic, 2 in the back.
Reattach the gray & balck hoses to the left side of the brush drive. They're 2 different sizes, so there's only 1 place the smaller hose will fit easily. Place the assembly back in the machine & replace the 2 screws in the front.
Flip the machine up so you can put the 2 really long screws back into the underside of the brush drive. There's 2 guide slots on either side, make sure the brush with the indicator wheel on top goes into the big hole on the right. You may need to spin the brushes a bit to get the center squure stick to line up with the hole in the drive gear. The brushes should pop back in easily if everything's lined up right.
Put the top cover on, making sure the Brush Speed stick & center screwhole line up, as well as the back sides snap into place.
Screw down the top, then flip the unit up so you can snap the bottom-front of the top over the gray wedges on the front, then screw into place.
Replace the Recovery Tank, fill & replace the solution tank, and test-drive.
Vanger Chevane.
Posted on May 27, 2009
ginko
  • 19396 Answers
SOURCE: Need a Manual
Check the links below:
Online User Manual and Guide for Hoover F6020-900
Do n ot forget to leave rating.
Thanks.
Posted on May 30, 2009
SOURCE: I am looking for the operating manual for a Hoover
Go to hoover.com
Posted on Sep 18, 2009
Manual for Hoover Steam VAc model #6040-900
need manual for steam vac dual V model:F7206-900 series:Z12.0
Jul 13, 2011 | Hoover SteamVac F5914-900 SpinScrub...
I have lost my instruction book on my hoover Vac;- mosel no U4617-906 is it posable to get a copy SamGlen
http://homeappliance.manualsonline.com/manuals/mfg/hoover/hoover_all_floors_vacuum_product_list.html
Jul 12, 2008 | Hoover Vacuums
I need to download the manual for the Hoover Steam Vac model #F5843-900
Look on the lower left of the www.Hoover.com website under Download Manuals. If this model does not come up try F5914-900, which is the newer model number.
Mar 14, 2011 | Vacuums
Don't remember how to use my hoover carpet cleaner
Visit HOOVER Support HERE and enter your model number to download a free copy of your manual. Happy Cleaning!
Nov 28, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
I hope this helps
May 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
I need a manuel for a hoover steam vac ultra with spin scrub brushes
Hi You need to find the model number and enter it into the location bar after you follow this link which wil take you to Hoover's main U.S Site.
http://www.hoover.com/CustomerService/Manuals/Default.aspx
Mar 23, 2009 | Vacuums
Directions on how to operate the vac from beginning to end
Hi! Go to www.hoover.com then click on the "Customer Service" tab. In the next window, under "Product & Support Information", click on Product Manuals and Information. In the next window enter your model number and click on Search. You will then be able to download the complete product manual. I hope this helps. I value your feedback so please remember to rate this response. Good luck!
Feb 21, 2009 | Hoover F5807 SteamVac Wet/Dry Vacuum
I need a booklet for my Steamvac-Dual V Widepath with auto rinse shampoo machine. The Model # is F7425-900 SeriesAA 12.0. Please send me one.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=736301
Generic problem for all Vacuums
Posted by wolners2 on Jul 03, 2008
I need a booklet for my SteamVac-Dual V Wide path with auto
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F7425-900 Series AA 12.0 Amp. In order to get the owner’s manual for the Hoover SteamVac-Dual V Wide Model # is F7425-900 SeriesAA
12.0. you will need to contact the Hoover factory cust serv and request the owner’s manual from the Hoover website or the Hoover cust serv. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 03, 2008 | Vacuums
#for hoover steam vav ve with rinse
Here is a link http://www.hoover.com/pdfs/manuals/F7220900.pdf
Or go to hoover.com, scroll down and on the left click on downloads, enter your model number and a pdf. file will come up that you can download.
Jun 10, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40488&thid=640907
Posted by mid-nite on Jun 02, 2008
My aunt lost the instructions to her steam vac, and she never got the chance to read them. Do you know how to operate it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac F5914-900 Spin Scrub Upright. The best thing to get an owners manual is to download the owner’s manual from the Hoover website or to call your local vac dealer or to call the Hoover Factory / Manufacturer to have them send you out in the mail a new owner’s manual for the model you have listed above . the phone 3 are listed below:
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Go Ahead. Use Us.
Jun 02, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
29 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
