I have a Xerox 7000AP digital color press and it's giving me a Subsystem fault code of 010-355. Do you know what this fault is and how I can fix it?
5 Suggested Answers
  • 2072 Answers
SOURCE: Fault code
arrwup.gifDescription An error has occurred related to the Electronics Module 50 V Power Supply. The clutches operate at 50 V. The Head Maintenance, Deskew, and Pick clutches are drawing too much power indicating a short in the supply or one of the components connected to it.
Posted on Mar 13, 2008
  • 239 Answers
SOURCE: fault code problem whit xerox 5665
This sounds like a fuser problem, underheat or over heat. On this machine also, it might be related to NVM, or NVM memory corruption. Sometimes the batteries on the Main Board, they just get old and die.
This can be a multiple problem on the machine.
This might require a Xerox service person to visit the machine.
Some ideas are: A bad heat sensor(Thermistor), very fragil and brittle.
A NVM might need to be reset, Over heat or underheat code in the diagnostice service mode. You need a service manual to find it.Very complicated to explain.
A full sump bottle can cause this, the machine enters a code in the NVM and will keep the machine from "Logicly turning on." Or a broken full sump bottle, sensor falls off or not in place will cause the machine to enter a error code in the NVM.
Good luck.
Posted on Oct 16, 2009
  • 661 Answers
SOURCE: I Have a subsystem fault 010-393 on a xerox 5252
Unfortunately, this means that your fuser is not warming up. This is something that you cannot fix yourself. Contact xerox.
Posted on Feb 03, 2011
SOURCE: On the Xerox 700 Digital
1. Check the front door and the toner door are both closed. 2. If that doesn't do it try powering the printer on and off. Note be sure to allow the machine to completely turn off before turning back on.
Best of luck!
Posted on May 29, 2011
On the Xerox 700 Digital Color Press, what does a 041-345 fault code mean?
Best of luck!
May 10, 2011 | Xerox DocuColor 12 Color Copier
FAULT CODE 124-373 ON WORKCENTER 5225 WILL NOT CLEAR
Xerox 5225 keeps showing error 124-373 and cant one to enter into set-up or status mode.How to correct this error?.I have jobs to copy for urgent meeting soon.your email is needed
Aug 28, 2010 | Xerox Workcentre 5225 / Copier, With...
Error-9-354
User Interface (UI) DIAGNOSTIC ENTRY:
Turn on the power… then while holding down the ‘0’ button, press ‘Start’.
The screen will prompt you for an “Access Number”… use the keypad to enter ‘6789’ which is the Default Access Number.
This should bring you to a menu of options to choose from:
• NVM Reset (Non Volatile Memory) / NVM Initialization
• NVM Read / Write (memory adjustments) you will need to know which codes do what
• Component Control (for testing sensors, motors, etc.)
• Print (for running Test Patterns from Diagnostics)
• Subsystem Check (for fuser nip measurement check out, and developer unit check out)
• Max Setup (for setting up copy quality)
Set NVM to 776-060=0 and 776-372=0
Hope that helps
Mike
Sep 23, 2009 | Xerox DocuColor 12 Color Copier
IT WONT WORK
here is how to print the fault codes.
http://www.office.xerox.com/support/dctips/dc99cc42.pdf
Not sure if it tells you how to clear or to call Xerox with the codes and know what is going on.
Good luck
Sep 17, 2008 | Xerox DC470ST Color Copier
Xerox dc 12 copier system faulit 9-354
Hi ,
Sir I am have dc12 mech
its giving error code 9-354.
send me the solution as soon as posible.
Aug 09, 2008 | Xerox DocuColor 12 Color Copier
Error Message 39,012.40:54812
Not much to do with that code, I will provide the documentation..
The troubleshooting table lists parts and wiring referenced in the troubleshooting procedure.
Table 1. 39,011.40 and 39, 012.40 Troubleshooting Reference Table Applicable Parts
Wiring and Plug/Jack References
Document Feeder, PL 1.0
arrwup.gif Troubleshooting Procedure Table 2. DADF Subsystem Faults Troubleshooting Procedure Step
Questions or Actions
Yes
No
Cycle system power and retest.
Does this correct the problem?
Complete.
Go to Step 2.
Replace the DADF ( REP 1.0.15).
Complete.
Mar 12, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
136 people viewed this question
jasbo
jasbo
