Question about Vizio P50HDTV20A 50 in. Plasma HDTV
Change screen from wide to regular our cable guy put it on wide my control will no longer change it
  • 30 Answers
Vizio has a set of buttons on the left side where you can access your settings and change the aspect ratio of your TV. Though why you want it changed is beyond me. Wide screen is for 16:9 aspect ratios. At 4:3 (Standard) you won't be using your full TV picture.
Posted on May 19, 2011
How can i change AOC monitor to wide screen, menu bar does not highlight. I have three monitors and the one on display port is wide screen by itself.
go into the computer , control panel find the appearance and personalization section ans change the aspect ration of the screen there. don't forget to apply and save(ok) before leaving
Feb 13, 2015 | AOC Computers & Internet
Widen the screen on Westinghouse tv
Screens are controlled by ASPECT RATIO.
Monitors can have 4:3 16:9 and 16:10 ratios.
You are doing 1 of 3 things.
  1. You have a regular monitor and the tv and are duplicating the screen.
  2. You have a regular monitor and the TV and are extending the screen.
  3. You have just the tv connected.
Your video card has to have a screen resolution that meets the tv's ratio to have the tv take the full screen.
If your configuration is 1. the tv will only match the monitor resolution, so if you change the screen resolution, you may get bars on the monitor, and the tv will go wide screen.
if your configuration is 2. the tv is controlled independently and you can select it to change its resolution to an appropriate aspect resolution. *this requires that your video card gives you the correct screen resolution for your tv. not all displays will work.
If your configuration is 3. the tv is the only resolution that is being pushed and just adjust the resolution til the screen is filled in.
To adjust the screen resolution, right click on the desktop where there isnt an icon and select either Properties (windows xp) or Screen Resolution (windows vista, 7 and 8).
if you have 2 screens press the identify button and it will put a number on each screen. click the appropriate screen and go to the resolution dropdown below. Change, apply and if it doesn't look right, revert and try a different setting. if you try them all and it won't take up the full screen, then the video card can't push the video resolution your monitor wants.
Sep 30, 2014 | Computers & Internet
How do I make the screen on my sanyo tv full- It has a black bar top and bottom
Your TV remote control (not the cable box remote control) would have to have a button that would allow the changing of the TV screen sizes. My Sony TV control has a button called, ' wide', and when pressed will change my screen to either, full, wide zoom, and zoom. Only zoom gets rid of the black bars on my TV. If no button, than the screen size will be determined by the broadcaster.
Feb 10, 2013 | Sanyo DP26640 LCD TV
How do i change my screen from wide screen to movie
to change screen from wide screen to movie is dipending to the movie player you use to play movie
you can go to option(setting) the screen setting is at Screen control or pan&scan control
try it
Feb 22, 2011 | Westinghouse Electric TX42F810G 42" LCD...
I have LG 50PC3D-UD display issue. I'm getting a black screen with thousands of blue pixels in center of screen. 5-6 inches wide orange horizontal from top to bottom moving across the screen. I check and...
The reason the blue pixels are igniting is caused by the driver board, not the power supply or main board. The drivers are part of the LG screen and cannot be replaced.
Mar 08, 2017 | LG 50PC3D 50 in. Plasma Television
Wide option on osd no longer highlighted
When you use an HDMI or component output and the device (cable box or DVD is set to only put out a 1080i signal te display will lock up. It is usually OK for the DVD player, however you may want to go into the cable box and check off all possible outputs ie: 480, 720 etc. This may allow you to chage display settings when needed
Feb 17, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
The picture has shrunk - maybe 720P vs 480P?
make sure your hd cable connection from your cable box is going to an hd connection to your tv.[via hdmi, dvi,or componant.] if you have a different hook up such as rca out or coax out, these are not hd connections and you are probably streching out the picture.look at the rear of the tv & cable box and see how the connections are.the hd hook up to the hd input should make the picture the right size only if it's set on the hd input channel.hook up the dvd player to a aux/line in or video/source input and try changing the picture size. you may have to play around with it till you get it the way you want.
hope this helps.
wg
Feb 06, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio P50HDTV20A 50 in. Plasma HDTV Logo
585 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
