The cartridge holder is not stopping to where I can change the ink.
  • 39 Answers
You should make sure the printer is ON and simply lift the cover. The cartridge should move to the center automatically when you open the cover. You can then change the ink cartridge.
Posted on May 19, 2011
Ink holder will not stop in middle to change ink
Hi, normally when changing ink cartridge, once you open the cover the printer head move from home to the center of the printer and halted,if in case this not happen something wrong with the sensor, if the printer move from home to center just pull off the power cord to stop the printer at the middle or nearly at the middle just to remove the cartridge and replace it. Upon replacing the ink cartridge, just power on the printer and it will return home to its position.
Jun 17, 2011 | Office Equipment & Supplies
How to replace catridges for Epson Stylus Office T40W??
Good day. I hope this steps can help you in replacing your cartridges. This how i remember doing it. Just follow these steps.
>Make sure the power light is on, but not flashing.
>Open the printer cover and the output tray.
>Press the ink button. The ink cartridge holder moves to the ink cartridge check position and the
power light begins to flash.
>Press the ink button again. If more than one ink cartridge is expended or low, the ink cartridge holder moves to the mark.This
occurs each time you press the ink button until all expended or low ink cartridges have been
indicated. Once all of the expended or low ink cartridges have been indicated, the ink cartridge
holder
moves to the ink cartridge replacement position when you press the ink button. >Open the cartridge cover and place the ink cartridge into the cartridge holder with the bottom down.
Then push down the ink cartridge until it clicks into place. Then close the cartridge cover
>Press the ink button and then the printer moves the ink cartridge holder and begins charging the
ink delivery system
Hope this will help you a bit with your ink cartridge replacement problem. Have a great day.
May 22, 2011 | Epson Computers & Internet
Epson stylus sx200 refuses to acknowledge black ink bought direct from epson
I believe the DX series and the SX use the same system
# Determine which ink cartridges are not recognised.
# With the ink cartridge holder in the ink cartridge replacement position, lift up the ink cartridge holder lid and take the cartridge or cartridges out.
# Check that the cartridge is a genuine Epson ink cartridge - look for the EPSON branding and T0xxx codes on the cartridge labels.
# Check that the cartridges are correct for your Epson product.
# Wipe the green Intellidge Chip on the cartridge that is not recognised.
# Check the chip contacts within the ink cartridge holder for any debris or dried ink and wipe with a lint-free cloth if necessary.
# Check that the plastic at the bottom of the cartridge has been pierced.
# Check that the cartridges are in the correct slots.
# Reinstall the cartridges into the ink cartridge holder in the correct order.
# Push the ink cartridge down firmly. It should click into place.
# Repeat this for any ink cartridges that were removed.
# Push the ink cartridge holder lid down. It should clip into place and be secure.
# Press the Stop button, this will return the ink cartridge holder to the right hand side of the unit.
# If the error light flashes after the print head returns to the home position, the ink cartridge may not be installed properly.
# If the red light is no longer displayed, but Status Monitor still reports a Non-Genuine Ink warning.
# If the red light is still on the printer, and Status Monitor indicates that an ink cartridge is not recognised, follow the steps below.
# If the problem remains, there may be a fault with the ink cartridge.
Dec 30, 2010 | Epson Office Equipment & Supplies
Don't know how to change the ink cartlige
Hi
thank you for your query
Make sure the printer is on but not printing. Raise the printer cover, then press down the Maintenance button for six seconds until the print heads move to the center. Pull up the empty ink cartridge clamp all the way. The cartridge rises up from its holder and should be disposed. Unwrap the ink cartridges and remove ONLY the yellow tape seal from the black and color ink cartridge. If you accidently remove anything but the yellow seal you cannot use the cartridge or it will damage the printer. To install the new cartridge, tilt the ink cartridge forward slightly as you lower it into its holder. Hang the tabs at the back of the cartridge on the hooks on the holder clamps. Don't place the cartridge tabs under the hooks on the holder clamp; you may damage the clamp when you close it. Install the ink cartridge and press the Maintenance button to begin charging the ink delivery system. Charging takes about a minute and is complete when the power light stops flashing and the error light goes out
Sep 24, 2010 | Epson Stylus C40UX InkJet Printer
How to change ink?
Press print button. Choose replace ink. Ignore this two steps if the display on your printer is Colour Ink is Empty.
Open cover. Press the round side of the ink cartridge holder arm and the holder will pop up. Take out the ink cartridge. Put in the new cartridge and pop the holder arm back by pressing it down.
Remember to remove the seal below the new ink cartridge before replacing it.
Jun 10, 2010 | Brother MFC-3220C Plain Paper Inkjet Fax
Change ink cartridge on epson stylus SX200 -printing head moves from side to side but then parks to the R and I cannot get access to change the cartridges.........
The ink cartridges are all separate so you press the cancel button (with no jobs pending) to bring the cartridge holder in to the right place open the holder remove the cartridge and then replace it, let the printer purge the cartridge then your good to go
Mar 24, 2009 | Epson Stylus Photo R320 InkJet Printer
Change printer ink
Turn on the printer.
lower th epirnter's output tray, pull out the extension, and open the cover.
press and release the ink button.
if your ink lights is on or flashing, the printer head moves to the left, and the cartridge that need to be replaced stops under the ink out mark.
open the cartridge cover
Pinch the back tab of the empty cartridge as your left it out of the printer.
shake the ink cartridge 4 to 5 times while it is still in the package.
unwarp the new ink cartridge and lower it into the holder. Push down gently until the cartridge is firmly seated.
repeal the procedure if more than one ink cartridge is out.
close the cartridge cover.
close the printer cover and press the ink button.
The green power light flashes and the printer makes noise. charge takes about a minutes. When it's finished, the green power light stops flashing and stay on, and the red ink light should go out.
Oct 10, 2008 | Epson Stylus C66 Photo InkJet Printer
Ink cartridge changed but computer will not recognize it has ink
Please try the following in an attempt to resolve this issue:
1. Make sure the unit is turned on, and not printing. The POWER light should be on, but not flashing.
2. Lower the OUTPUT tray, and lift the scanner portion to access the ink cartridges.
3. Press and release the INK button.
4. Open the CARTRIDGE COVER. Pinch the front and back tabs of the first cartridge, and remove it from the printer.
5. Place it back into the holder. Push it down gently into the holder, until the cartridge clicks into place.
6. Repeat steps 4-5 for each cartridge. Close the CARTRIDGE COVER once all of the necessary ink cartridges are re-seated.
7. Carefully lower the scanner, until it clicks into place
8. Press and release the INK button.
The ON light flashes and the printer makes noise. Charging takes about 30 seconds. When it's finished, the ON light stops flashing and stays on steady.
CAUTION: Never turn off the printer while the ON light is flashing, unless the printer hasn't moved or made noise for more than 5 minutes.
Aug 30, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Help with Epson Stylus CX 6000
Hi Open the cover then switch on the printer and then off from the mains when the cartridges are in the middle. Hope this helps!
May 23, 2008 | Epson Stylus CX6000 All-In-One InkJet...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
