Question about Frigidaire (5303002176) Remote Control
WHAT IS THE CODE FOR A FRIGIDAIRE A/C REMOTE CONTROL
A/C remote control K-218E CHUN GHOP10ZB61465 how to program it to a frigidaire 6000btu window unit a/c
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Oct 16, 2016 | Frigidaire Televison & Video
Tip
DirecTV Remote Control Code List Download
Download DirecTV Remote Control Code List
Have you lost your Code List for your DirecTV Universal Remote Control?
Would you like a digital copy of the DirecTV Universal Remote Control Code List for easy searching of terms and quick reference?
The DirecTV Universal Remote Control Code List is available free in pdf format, just follow the link below (& Click FREE):
Download DirecTV Universal Remote Control Code List
I hope that helps.
________________________________________________
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Search
DirecTV Remote Control Code Entry
on Jun 10, 2010 | Universal Remote Control DIRECTV Universal...
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
I want to find a frigidaire control remote UL-R51M/CE
Hey Ralph, thanks for your post!
I see that you need help locating the remote for your Frigidaire refrigerator. In order to better assist you I would need to have your model number. You can locate the model number on the inside wall of the refrigerator. Once I have that information I would be happy to assist you further. -Matt
Apr 27, 2016 | Frigidaire Refrigerators
I have a kt-9018e universal a/c remote can you tell me the code for a frigidaire
Thank you for your post, John!
Based off the information you have provided you need the code for a universal air conditioner remote. You may need to speak with manufacturer of the remote for that direct code. Best of luck! -Matt
Aug 10, 2015 | Frigidaire Heating & Cooling
I have a chunghop rm-88e universal remote and I need the codes to program it to my frigidaire dvd player
This remote control have no set-up codes to Frigidaire DVD player. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" or "Magazine" view, will make surf easier.
Universal remote controls are available at most of the electronic spare part selling shops.
Check this link too. http://remotesearch.blogspot.com/
Apr 28, 2014 | Frigidaire REMOTE CONTROL BOARD KIT Remote...
I have a chunghop rm-88e universal remote and I need the codes to program it to my sanyo tv?
0049 0050 0065 0101 0102 0107 0131. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
Try this link too
I need codes for AC Frigidaire for Quality QTH 4000 universal remote cotrol
Since you do not have the code for your Frigidaire AC just aim remote control at AC press for 6 seconds and release SET key until ac open automatically, then press ENTER
Aug 03, 2013 | Philips Universal PH301S Remote Control
My frigidaire electric range had a f1 code come
The F1 code is a failure of the ERC (electronic range control), the only fix would be to replace the control board.
May 17, 2010 | Frigidaire FES367 Electric Kitchen Range
Televison & Video Logo
193 people viewed this question
Top Frigidaire Televison & Video Experts
Lawrence Oravetz
Clint Millett
Are you a Frigidaire Televison and Video Expert? Answer questions, earn points and help others
