Question about Samsung SyncMaster 400PXN LCD TV
My Sync Master 400 PXN won't turn on. It just keeps making a clicking sound and never boots up. Help!
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: Hi, I have a samsung LCD that keeps making clicking sound and won't turn on. From my research you need to change the capacitors. I have done this and it still won't turn on. Is there anything
if you did find puffed up caps and replaced them consider replacing the power board as there may be other bad parts on it.
Posted on May 16, 2012
Ktm 400 battery won't keep it's charge
Sounds like your stator is shot. That usually happens when you run it with a dead battery. Stator over works
Mar 29, 2013 | KTM EXC 400 Racing Motorcycles
After a few hours my Aprilaire 400 makes a constant clicking sound that won't stop. Is it the solenoid?
This is either the solenoid or a loose low voltage wire. Make sure all the wiring connections are tight, if they are the solenoid if bad and will need to be replaced.
Dec 14, 2012 | Aprilaire 400 Humidifier
1991 Lexus 400 - engine doesn't start - battery seems charged - 12.3 volts - makes clicking sound only - doesn't turn over at all.
Is it one click or multiple clicks. If it's multiple clicks, it sounds like a dead battery. Voltage isn't always an indicator of a good battery, you need to have enough cranking amps to be able to start an engine also. If you have dash lights and it only clicks once, you could have a bad starter. An easy way to check this is to try and jump start the vehicle. If it starts up with a jump start, you need a new battery. If it still doesn't start up and it just clicks, you probably need a new starter.
Good Luck!
~Brandon
Jun 01, 2011 | 1991 Lexus LS 400
Won't boot from dvd or hard drive, changed hard drives and still won't boot
Depends on what you mean by won't boot from DVD or Hard Drive,
it sounds like your boot order is what you're looking for help for.
To do this you need to get into your computers BIOS (or "Setup")
You can do this by rebooting the computer and the very very very first screen you see tells you how,
usually by pressing DEL or F2 or F10.
Without knowing the specific computer you're looking for help on I can only point you in the right direction however keep in mind the BIOS is for advanced users only and you can damage your computer by randomly changing settings.
What you're looking for though is usually called the Boot Order or Boot Sequence
You'll need to set whatever device you want to boot from higher on the list (usually with the up arrow or PgUp)
If you don't see your device on the boot list then it may not be detected due to failure.
May 31, 2011 | Computers & Internet
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
Samsung SyncMaster 400PXN LCD TV Logo
64 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
