Question about Datamax I-4208 Thermal Label Printer
I am printing on a data max I class, and for the last couple of weeks, no matter what I try, I get a wrinkle in the ribbon. which creates a void in the barcode. what do I need to do to fix i?
  • 54 Answers
On the I class printer, there are 2 solutions to make the ribbon wrinkle correct.
On the face of the printhead, there is an adjustable sheild that you can angle for and aft of the plane of the head.
There are 2 screws on the top front edge of the shield.
Also there is an adjustable cam bar just to the right, back of the printhead mounting. There is a small adjustment cam just inside of the lower rear of the head. To adjust the inmcoming angle of the ribbon, loosen the outer screw, and turn the knurled adjustment knob. You can see it plainly by opening the head, tand looking down the ribbon path. It is on the right hand lower side.
You might also try adjusting the printhead pressure(small green knobs on the top of the head) But that will depend on how much they are already adjusted down(more pressure).
Posted on Jun 21, 2011
Barcode scanner won't read printed labels
1. The printhead in your printer might be scratched (evidenced by thin white streaks through your print). This is common, and the most likely cause. Printhead must be replaced.
2. Material might be stuck on your printhead (usually evidenced by wide white streak vertically through print). Printing surface of printhead can be cleaned with rubbing alcohol and cotton ball.
3. The ribbon might be wrinkling due to uneven tension, producing intermittent diagonal streaks in your print. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment and/or proper media loading solves ribbon wrinkles.
4. Poor pressure and/or printhead alignment. Evidenced by grainy, light or no print on one side or the other of the media. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment solves printhead pressure and alignment issues.
Dec 11, 2012 | Datamax E-Class E-4203 Label Printer
Printer printed 5 tags but there is wrinkles in the tags so i tried to realign the ribbon and now it will not print
Ribbon wrinkles are due to:
- Ribbon too large.
- Print Head misaligned.
- To much heat.
- innapropriate Transfer film.
check with your tag dealer
Apr 24, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
I have a w class data max printer and it prints the labels but very light ink on it i was told that the green wheel on the side controls that but i have tried every single level on it but still light...
Lift the print head (where the label comes out and the ribbon should be right under it)
Take a clean Q-tip and some IPA, and wipe the little black line of dots you will see inder the head. These are the thermal points on the print head and they do build up debris which moves the head away from the ribbon causing lite print.
Dec 30, 2010 | Datamax M-4208 Thermal Label Printer
Constant wrinkle in the print. tried different
Usually a ribbon wrinkle is caused by an imbalance across the printhead. There is more pressure on one side of the ribbon then the other (if using a ribbon across the whole web). Check the printhead pressure adjustment dials located on top of the printhead. One side may be "down" more then the other.
Hope that helps !
Apr 05, 2010 | Zebra S4M Thermal Label Printer
Wrinkles in ribbon using Datamax H-4212 printer
Definitely. possible solution match the width of your label and ribbon. if your ribbon is wider for .5 inch it should be good.
1. check your spindle alignment, printhead alignment and rotate the green knob on the printhead while printing so that you'll see the difference.
Jan 29, 2010 | Datamax DMX I-4206 Printer
The ink is not to clear.. print right but get bad after a few weeks
Try cleaning the print head. I try to clean the thermal print head between each ribbon change. Use the Zebra cleaning tool (looks like a magic marker) or a q-tip with a little bit of denatured alcohol. If this is not the issue make sure there is no wrinkles in the ribbon.
Oct 23, 2009 | Zebra LP 2844 Thermal Printer
Z4MPlus Ribbon wrinkles causing lines diagonally across label.
Could be down to tension on the ribbon roller/spool. Check to see if you have pulled out the end part of the spool (black bit) that should ensure there is back tension on the ribbon.
Mar 27, 2009 | Zebra Z4M Printer
Thermal Ribbon has a wrinkle
The thermal print head is damaged. You can try to clean it with a thermal printer head cleaner. That will only help if it is just clogged up with thermal print ink.
Aug 19, 2008 | Datamax DMX-I-4212 Label Printer
Zebra Z4MPlus Ribbon Wrinkles
I changed the print head, and the issue was solved.
Aug 01, 2008 | Zebra Z4Mplus Label Printer
Ribbon error 754
Your printer is not correctly configured for ribbon. Download the manual located at ftp://www.servisource1.com/user_documentation/9855/9855oh-ae.pdf
Go to chapter 4-1 to see the map of the menu system and change your printer to ribbon yes.
Make sure that your printer is loaded with supplies and the ribbon is set up correctly, as well as slack taken out.
You may see a couple of labels not print well, but after that, you shold have proper tension and good print. If you notice a lot of ribbon wrinkle, you probably need to reload your ribbon or adjust the tension bars.
This should resolve any issue you have with the ribbon.
Ohiotech
Sep 14, 2007 | Monarch 9855 Thermal Printer
Datamax I-4208 Thermal Label Printer Logo
251 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Kevin Brown
Level 1 Expert
Greg Cann
Greg Cann
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
