LC32A6C2TG06FA1087 Soyo MT-3268AB takes many power button pushes before it will turn on. Any ideas
  • 6,993 Answers
Hi, welcome to Fixya!
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Posted on May 19, 2011
Where can i find the INPUT button on my soyo mt-sygwt2697nb LCD TV
Use the remote to choose the input. You can also use the menu button to find the inputs.
Sep 15, 2016 | Soyo Televison & Video
Remote code for the Soyo Model # MT-SYTPT4218AB What's your problem?
These are setup codes for Sanyo: 0049 0097 0110 0004 0268 0012 0108 0180
Oct 25, 2012 | Soyo SYTPT4218AB LCD TV
Soyo tv Mode MT-SYTPT3227AB will not turn on
It might be the power supply board. There is a repair service which addresses any problem with the power supply board, not just bad capacitors: http://www.coppelltvrepair.com/p/783/soyo-mt-sytpt3227ab-power-supply-board-repair-service-no-power-shutdown-etc
Jul 11, 2012 | Soyo SYTPT3227AB 32 in. LCD TV
Mt KT600 Soyo Dragon Motherboard comes and then shuts off after this long beep.I have changed thew memory and that did not fix it.I bought the computer not knowing it had a problem.
Hi'' this is on a kind of trouble shooting , try to place your PC shut off unplug it then open side cover , this is risky , you must have an assistance to do this thing , but if you can do this by your self try to to pull out ram be careful it has two locks do insert it back '' do it twice or trice ,check hard drive sockets connection if might be loosen ,if all parts are already been installed back in its proper place . turn on power and observe if it works properly , but if not Then if you can take this risk you can contact me by mail or send you mother board in my place for repair +639282825180
Apr 29, 2012 | Soyo Computers & Internet
My Soyo 19" TFT monitor Model:MT-NI-DYLM1998 comes on at power up but goes black after a few seconds. But on repeating turning power off then on again, the monitor comes on and then goes black again after...
Thank you for answering those questions. That usually indicates it has a bad power inverter. From what i can tell, that monitor is a few years old. You can attempt to find an inverter online to replace it yourself (usually about $50 if you can find one) since its no longer covered under warranty, or put that money into getting a new monitor.
Sep 06, 2010 | Soyo DYLM24D6 LCD Monitor
Fuse Blowing in Power Supply SOYO MT-GW-DYLM24D6 24
If you can solder connectors you can build your own power supply for SOYO. Try the following link or google "gbyer external power supply".
http://slickdeals.net/forums/showthread.php?t=1655449&page=5
Replacement power supplies were avilable recently but it seems they are all depleted.
Nov 06, 2009 | Computers & Internet
TV PARTS FOR SOYO
Have you checked PTS 18008447871 ?
Mar 17, 2008 | Televison & Video
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
