Question about Toro Lawn Mower With Toro Power Tools
Toro ready start, will start but losses power 2 yrs old
  • 577 Answers
Service carb, pull apart and clean and replace needle/sweat
Posted on May 20, 2011
Loss of power
Loss of Power could be
a. Restricted Fuel Flow through the CARB
b. Plugged or Fouling Spark Plug
c. Worn Piston Ring..
ALWAYS make sure you use a High Quality 2-Stroke Oil...
Apr 08, 2013 | Toro 2-Cycle 25.4 cc Straight Shaft Gas...
I have a Toro 20" self propelled, electric start
I am strictly Briggs&Stratton. They are hard to start when the fuel tank is half empty. Clean the plug and air filter.
Jun 15, 2011 | Toro Power Lawn Mower
After trying to run a water hose through it to clean my Toro 650 190 CC lawn mower has refused to start for me, let me add before the hose I turned it upside down to get out excess grass, Now I've...
Only tilt a lawnmower backwards toward the handle end (spark plug end raises) Other ways move the oil around to places it doesn't need to go. Now you probably have gas in the oil....check it or change it (milky looking or smells like gas..contaminated...might need changing anyway...You probably will have oil in the carb and it will blow smoke...You probably filled the oil breather with oil and it will drain down...causing smoke also. This was the wrong thing to do A 2 year old unit should be mechanically sound..Check the air filter, spark plug and carburetor for oil fouling. Remove the bowl on the carb to help get some of the oil out...it will leak gas when you do.
Jun 10, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Toro lawn mower wont start
pour alittle gas in carburator & then try starting see what happen if it starts & then dies then you have a carburator problem
Nov 09, 2009 | Toro Lawn Mower With Toro Power Tools
I have a Toro recycler approx 2 years old. No spark, cleaned flywheel and magneto and its getting gas. Has the primer button on the side for starting. Please help. No key start.
Check to see if there is a wire off under the shroud that will run to the magneto. May have a hole rubbed in it allowing a short. The magneto should not be bad being only 2 years old, but it's possible.
Oct 24, 2009 | Toro Lawn Mower With Toro Power Tools
10 yr old mower, has not been started for 3 or 4 yrs, won't start
Remove the fuel filter and fuel line and replace then try it, if it still does not stay running you will have to change outthe primer bulb. If you need more innformation let me know. Aslo please rate this as this is a free service and thanks for using Fixya.
Aug 18, 2009 | Toro Lawn Mower With Toro Power Tools
My Toro mower is 7 yrs old. 3 speeds, blade
I've noticed that when the blade get dull it work harder a cutting tall grass. I just put a new blade on mine and now it runs and sounds like a brand new mower. also if the inside of the deck is coated with old grass that makes a differance too
Jun 23, 2009 | Toro Lawn Mower With Toro Power Tools
Turn the key for electric start,nothing happens
If you never used the starter,You need to have it checked, possible that it i froze up. Or brushes in starter arn't making contact. Also check connections. Good Luck
May 19, 2009 | Toro Lawn Mower With Toro Power Tools
Can't start toro mower. cleaned spark plug , new air filter . will run for 2 or 3 seconds on prime , then stalls ,will fire every time , but won't continue to run what next? 22" self propelled...
Hello:
There are 2 Possible Causes for this Problem.
1- The Carburetor Requires Soaking and Cleaning.
2- The Valve Clearances Require Setting.
You can View a Breakdown of this Unit at the Following Site Addy.
https://lookup3.toro.com/partdex/default.cfm
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
67 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
