Question about Samsung HT-DS1000 System
How to reset Samsung HT-DS1000 Home Theater System without a remote controller ?
  • lauris150 May 22, 2011
    please someone help me :O
  • 3 Answers
SOURCE: unlock home theater system samsung ht-x20
http://www.videohelp.com/dvdhacks/samsung-ht-x20/8981
This should solve it :) I had similar problems. Swapnil
Posted on Nov 04, 2008
  • 12 Answers
SOURCE: my samsung HT-TZ512 home theater
Do what I do for every piece of electronic equipment I own, especially remote controls. Go to the manufacturer's Website and the go to support and download the user manual in PDF format and save it to your MY Documents file or whereever.
Posted on Mar 08, 2009
SOURCE: v ipod mode in Samsung HT-Z420 home theater system not working
Plug a yellow video cable into the TV (IN) and the Sound system (Out) then go onto AV1 on the TV or which ever port you plugged the cable into and play a movie and u can see it. A menu doesnt come up like the A ipod funtion so it comes up no signal until u play an actual movie on the ipod. If u dont have a yellow video cable i think u can use the white or red audio ones.
Posted on Aug 20, 2009
SOURCE: samsung ht-c550 dolby pro logic II mode does not work.
1. Go to the DVD input.
2. Select menu
3. Settings
4. Audio
5. ASC
6. Turn OFF the Auto Sound Calibration
7. Exit the menu
8. Go to the DVD input and retry the pro logic II button and switch to MATRIX.
(Also you have to enable the "matrix" setting each time on all of the inputs you use.)
Posted on Jan 27, 2011
How to unlock dvd
Here is how to unlock the HT-DS1000:
Step 1) Disconnect your player from its power source for 30 seconds
Step 2) Reconnect your player to its power source
Step 3) Press the Power On button on your remote control
Step 4) Press the Enter button on your remote control
Step 5) Press the 8 button on your remote control
Step 6) Press the 4 button on your remote control
Step 7) Press the 2 button on your remote control
Step 8) Press the 6 button on your remote control
Step 9) Press the 9 button on your remote control
Step 10) Press the Enter button on your remote control
Step 11) Your player should now place itself in Standby mode
Step 12) Press the Power On button on your remote control
Please rate my answer if this helps,
Many thanks,
Chris
Mar 14, 2011 | Samsung HT-DS1000 System
Hello! Pls, send diagram connector to sub-woofer Samsung HT-DS1000. I want to connect low signal(Sub woofer) direct to amplifier. If connect to AUX - sub woofer sound with delay, no good sound. Thank...
The speaker connections are documented in the manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Samsung-HT-DS1000-Home-Theater-Systems-manual/id/287ci764/t/2/
Are we talking about an external add-on sub not supplied with the HT-DS1000? If so, please identify it.
The interconnecting cable itself is a 13-pin DIN.
Mar 07, 2011 | Samsung HT-DS1000 System
The remote isn't working at all with the home theater system. The tv is also a samsung i disconnected everything and reconnected but the problem still exist. any ideas of what i should do?
First of all, what is the remote control that you're using?
If you are using the remote control that came with the HTS unit and it's not working with the home theater, press the DVD RECEIVER button. That should work.
If not try this. Take out the batteries on the remote control and hold down the POWER button (without the batteries!!).
Hope this helps!
Jun 26, 2009 | Samsung HT-TZ312 Theater System
Hi, I have Samsung HT-X50 connected with SWA-4000. It was working fine, then for somereason I had to remove and reinsert Tx card. After doing that SWA-4000 is not connecting to HT-X50. Blue light blinks...
You have to reset the connection:
With the home theater system off, press the 0-1-3-5 buttons in that order on the home theater's remote control.
Power on the home theater system.
With the wireless module on, press the [ID SET] button on the back of the wireless module for five seconds.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Hope this helps!
Jun 09, 2009 | Samsung HT-TZ515T Theater System with...
Samsung ht ds1000 audio problem
I had the same issue 6 months after I purchased the unit. Worked with tech support several times. Finally they sent new woofer and that fixed it.
Jun 12, 2008 | Samsung HT-DS1000 System
Samsung ht ds1000 plays fine, but there is no sound.
you have not blown thye fuses the static sound suggests that that is not the problem
Jan 19, 2008 | Samsung HT-DS1000 System
Dvd does not load
clean the lens of your dvd if that does not work there is a strip connected to the lens have that replace or adjusted by a tech.good luck.
Apr 03, 2007 | Samsung HT-DS1000 System
Samsung HT-DS1000 System Logo
67 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
