Question about Nakajima AE-710 Typewriter
Removed old ribbon cartridge. Unable to install new one. I snap it in place but it is not working. No print. Can you send a diagram of how it is supposed to be installed. I have a model AE-710. Thank you
  • Nakajima Master
  • 3,594 Answers
First thing remove the ribbon turn the hand feed knob and see if the ribbonmoves if not you have a bad ribbon. The ribbon has 2 little feet thar hook on the ribbon deck and then it snaps down and latches into place. Go to NADIST.COM, Click on current models you will find a manual there.
DickyO
Posted on May 19, 2011
Testimonial: "Your quick response was very helpful. I didn't know where to get a manual. I downloaded and printed it for future reference. thank you.Jan"
How do I install a replacement ink cartridge in an unidentified printer?
are you sure its the correct type of ink cartridge?
are there any shipping protection on the contacts or ink slots at the bottom still attached?
do the old ink cartridge snap into place without problem?
if the old ink cartridge slot in place but not the new. and there is no protective plastic from shipping on the new ones. then it is wrong kind of cartridge
Nov 29, 2015 | Office Equipment & Supplies
Jammed print head
Sounds like the cartridge is not installed correctly.
verify the cartridge is the correct one for the printer
gently removed or snap out cartridge then gently reinstall
until you hear it snap into place.
On my HP printer, the cartridge slot slants towards me I have to slide into place then gently push forward.
Then from your printer or on your computer ask the printer to do an "alignment" and then a test color.
then print a test page
Dec 19, 2013 | HP Office Equipment & Supplies
Install lift off tape cartridge
Remove the ribbon by pushing the blue lever to the right and front of the ribbon. The correction tape cartridge is attached to the bottom
of the Printing ribbon. Depress the center of Printing ribbon to release the correction ribbon. Snap on a new one.
Nov 04, 2013 | IBM Personal Wheelwriter 2
How do you load a new ink cartridge?
Replacing the Print Cartridge
1 Open the front cover, and then open the top cover by pressing the blue levers on both sides of the top cover.
2 Remove the old print cartridge containing the used ribbon and dispose of it.
3 Remove the plastic stopper from the new print cartridge.
Note You can reuse the print cartridge until it breaks. If you purchased refill ribbons, follow the instructions that came with them.
4 Turn the black spool on the right clockwise to tighten the ribbon as shown.
5 Install the new print cartridge by inserting the recessed first, and then placing
the cartridge into its four holders.
6 Press down on both sides of the top cover to close it securely.
7 Close the front cover.
Brother Customer Service at 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada).
Vertical Black Lines When Receiving
The sender's scanner may be dirty. Ask the sender to make a copy to see if the
problem is with the sending machine. Try receiving from another fax machine.
If the problem continues, call Brother Customer Service at 1-800-284-4329
You can save money by purchasing the 2-PK Refill Ribbon Rolls (PC302RF).
Installation instructions will be included. If you handle the print cartridge (frame)
carefully, you can reuse it until it breaks.
Jan 17, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Nov 23, 2009 | Datacard Group SP55 Card Printer
Printing with no ink
1. Lift the front cover, and wait for the printer to move the old cartridges forward.
2. Take off or pull the clear plastic tape off of the back of the cartridge.
3. Pop the cartridge holder off of the top of the cartridge you are changing and pull the old cartridge out.
4. Carefully insert the new cartridge into the holder until it snap in place.
5. Close the front cover.
6. Your printer will automatically recognize the new cartridge.
7. Try to print a test page.
Oct 20, 2009 | Lexmark X5470 All-In-One InkJet Printer
How do I put new cartridge in
Follow this procedure to install print cartridges in you printer.
1 Turn on the HP Officejet, and then lift open the print-carriage access door.
The print carriage moves into view.
2 After the carriage stops moving, push down on the top of the print
cartridge to release it, and then pull it toward you out of its slot.
3 Remove the new print cartridge from its packaging and, being careful to
touch only the black plastic, gently remove the tape by using the pink pull tab.
Caution! Do not touch the gold-colored contacts or ink nozzles.
Once you have removed the plastic tape, install the print cartridge
immediately to prevent the ink from drying in the nozzles.
4 Hold the black or photo print cartridge with the HP label on top. Slide the print cartridge at a slight angle up into the right side of the print carriage.
Press firmly until the print cartridge snaps into place.
Caution! Do not attempt to push the cartridge straight into the slot.
It must slide in at a upward slight angle.
5 Hold the tri-color print cartridge with the HP label on top. Slide the print
cartridge at a slight angle into the left side of the print carriage.
It must slide in at a slight upward angle.
Note: You must install both print cartridges in order for your HP Officejet to work.
6 Close the print-carriage access door.
“Press OK to print Align page” appears on the display.
7 Press OK.
Oct 06, 2009 | HP OfficeJet 4215 All-In-One InkJet...
How to replace ribbon
Hi cci5,
I will guess that you have the old one out, take the new ribbon, it should look just like the old ribbon, turn it upside down and look for a hole that has ribs or like a gear will fit into it, then look in the printer and find the gear, slide the ribbon over the print head thats where ink goes on the paper if the ribbon is printing, then snap the ribbion in place.
Good Luck
Jan 28, 2009 | Panasonic KX-P3626 Matrix Printer
Have just unpacked new HP Photosmart C4200 All-in-One Cannot get machine to accept cartidges which werre supplied with the printer
NOTE: The product must be on before you can insert the print cartridges.
  1. Open the print cartridge door. Figure 7: Opening the print cartridge door c00880893.jpg
  2. Make sure the print carriage moves to the right. If it does not move to the right, turn the device off, then turn it back on again.
  3. Open the packaging and remove the tape from both cartridges. Figure 8: Removing the tape c00880894.jpg CAUTION: Do not touch the copper-colored contacts or re-tape the cartridges.
  4. Hold the cartridges with the HP logo on top.
  5. Insert tri-color cartridge in the left cartridge slot and the black cartridge in the right cartridge slot . Figure 9: Inserting the print cartridges c00880895.jpgc00880896.jpg
  6. Push the cartridge firmly into the slot until it snaps into place.
  7. Close the print cartridge door.
Step eight: Align the print cartridges When a new print cartridge is installed, the product aligns the cartridge. Align the print cartridges at any other time by using the software installed with the product. Aligning the print cartridges ensures high-quality output. NOTE: If a print cartridge is removed and reinserted, the product will not prompt for an alignment. The product memory retains the alignment values for that print cartridge. Follow these steps to align newly installed print cartridges.
  1. When prompted, make sure that plain, white letter or A4 paper is loaded in the input tray, and then press the button next to OK . The alignment page prints.
  2. Lift the lid. Place the top of the alignment page face-down on the front, right corner of the scanner glass. Figure 10: Placing the alignment page c00880898.jpg
  3. Close the lid.
  4. Press the button next to OK . When the On button stops flashing, the alignment is complete and the page can be removed.
Nov 18, 2008 | HP Computers & Internet
Diagram to change ribbon cartridge
The cartridge just snaps on, printing half letters may be caused by the ribbon being folded over on itself or not moving look at the ribbon toward a light you should see each letter clearly thru the ribbon
Sep 20, 2008 | Swintec 7040 Typewriter
Nakajima AE-710 Typewriter Logo
199 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Ron Dufek
Ron Dufek
Jim Keysor
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
