My laptops will connect but its saying local only when im wireless. It also has two connections one factory and the other self made. How do i just have one connection point, and make it connect to the internet without having to plug an ethernet cord into the laptop. With out the cord it says local only. On both laptops one is running xp and the other vista. I had no problems before then i had to disconnect all the wires because i was moving now I put everything back together and i get local only. Help!!!!! lol
  • 30 Answers
Okay, since you moved and unplugged the router you reset the router to factory defaults. You need to boot your wireless laptop wired to the router so the DHCP can reestablish an IP address.
That should do it.
Good luck,
Cullen
Posted on May 19, 2011
Connected with limited connectivity
Go to your local area connection from Control panel>Network and internet connection>Network connection.There choose the property of your local area connection.
In property,uncheck the option Notify me when this connection has limited or no connectivity.And choose OK button.Now you have done.Now disable and enable local area connection from network connection.You will seenotification saying acquiring network address and connected.The error of limited area connectivity will never disturb you again.
Resource : http://www.ehowportal.com/fix-limited-connectivity-laptops-wireless/
Apr 26, 2012 | Computers & Internet
I want to no how i can get my laptop to put my xbox360 online
nice its really simple with windows xp im not sure about vista but what i did with windows xp is i would open the box for my networks i was connecting to the right click the local thats going into the xbox too computer and and click properties and click share internet connections and click share for all the things for local connection which is xbox to laptop and make sure it syays ur connected locally then u wanna go to the wireless connection right click and click properties and and advanced tab click share this connections with other hosts using this computer and if that works u should have xbox live for best xbox live speed u need atleast 3-4 bars if its smaller than that move ur laptop closer or u will have very slow reaction time
Feb 01, 2010 | Microsoft Wireless Network Adapter Xbox...
Its not connecting proprely to the internet
You forgot to mentioned the kind of what brand of wireless router you have. first you have to activate or properly setup the wireless router. the factory default ip address is 192.168.1.1 Go to web browser even it will say fail to connect to server. type in 192.168.1.1 to the address bar. the default user id admin and the password is password. wireless basic setup is the first one, next is the wireless setting. Since I have no clue what kind or brand you have there is a setting for b,g,n most likely your laptop is a g signal. if the router is set for n signal your laptop will not connect. make sure to set to b,g,n setting and this will work. your laptop will connect to the internet. oh I forgot to mention to set for wep key or passphrase. then input the to your laptop to connect. I hfope this will help you solve the problem.
HH
Aug 12, 2009 | Acer Aspire 5050-3242 Notebook
Airport connection says Connection Timed Out.
I don't think this is a problem with your macbook, it is probably a problem with the wireless router that is broadcasting the connection. Try restarting the router and connecting then.
Jul 02, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Laptops not connecting to the internet when the hp c4599 is on
Perhaps the printer is conflicting with the laptop by taking its "address" on the network...Do you know how to give your printer a diifferent IP address? Or your laptop? Its a bit complicated to explain but if you can make sure the laptops and the printer are all set to use "DHCP" then they should all each get an adress on your home network and work together.
In Windows Vista, click Start, Control Panel, Network & Internet, View Network Status and Tasks. Then view the status of your Wireless Network Connection and click details, if it says "DHCP Enabled" in there then your laptops are not the problem and should be sharing addresses.
You should be able to see in the printers control panel or by printing a self test page how its setup on the network, maybe it needs to be reconfigured while the laptops are turned on as well.
May 17, 2009 | Office Equipment & Supplies
No wireless detect connection
Hi
Note all changes to be made from wired computer only . Any computer that is phisically connected to the router.
Open the router setup page by typing in your default gateway address( router address) on the web browser
You can get it by
Start -> run -> cmd -> ipconfig
You will see the router setup page opening up
Check what it says . IF on the top it says Internet Status :: Connected then
1. Under wireless you'll see channell and ssid
2. Change channell to 6 or 11 .That gives you the best wireless signal strength . This is the most probable cause .
If you want you can also change the
3. Check your security key
4. And apply changes
5. Now on your wireless laptop go to Control panel ->Network connections -> wireless network connections -> right click -> deleate preffered networks -> refresh netweork list
6. You will find your network there select and connect.
Works great
If Ip status : says not connected
1. restore factory default
2. reconfigure router
3. reconnect
This shoud help and please let me know .
Mar 26, 2009 | Linksys Wireless-G WRT54G Router
Laptop wont connect to wireless belkin router
If you connect the laptop wired, does it work correctly?
If your Wireless router has password protection, try resetting it to factory defaults, and connect it that way.  If you can connect with the factory defaults (with no security), it's likely an issue with the security on your router.
I'd suggest starting again. Reset to factory defaults, re-secure the network and try a different SSID name this time, and try again.
Mar 18, 2009 | Gateway 802.11g Wireless DSL/Cable Router...
Internet connection
Have you tryed running a antivirus check? If so it could be your cookie setting in the tools>internet options.
Sep 11, 2008 | Acer Aspire 5100 Notebook
My router will not connect to the internet
The laptop may not have the correct wireless settings same as the router.
What is the Operating system of your laptop and does it have a builtin card?
May 21, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
