Question about Watches
Tag Heuer Chronograph Carrera crown replacement
I tried to adjust the time on my Tag Heuer Chronograph Carrera (automatic) and the crown came right off in my hand. There is still a small stem outside the watch where the crown should be. Do I need to purchase a new crown or what is my next step ? Any help would be greatly appreciated.
  • Anonymous Mar 28, 2009
    same problem with professional. crown came right off and there is a small spring inside.
SOURCE:
escapement
  • 2338 Answers
SOURCE: i pulled on the crown and it came off the stem
Do not open the watch yet, as you do not know how to get the stem out.
Take an eyeglass and examine the crown. You will find the small hub in the centre of the crown. If the centre of this hub is hollow and you can see the thread in it- you will be able to screw it back on stem (all watch crowns are screwed on to stems, never pressed).
If the centre of that hub looks filled with metal, then the stem end is broke and you will need replace stem AND crown (the metal filling the hub is the broken end of stem).
In case if the crown still in tact, let me know by asking questions and I'll guide you through all the process HOW TO.
Rate me, please.
Posted on Mar 24, 2009
SOURCE: How to set up time on TAG HEUER SLR CHRONOGRAPH ?
The crown at 3 o'clock is used to set the time and change modes. The crown at 9 o'clock is used to rotate the flange at the edge of the dial.
The A button at approximately 2 o'clock starts and stops the chronograph function. The B button at approximately 4 o'clock resets the chronograph.
Lap Timer: When the watch is displaying normal time, press the right side crown to switch to chrono mode (the hour hand will indicate CHRONO). This watch measures lap times, press A to start timing the first lap. Press A again to stop the first lap and automatically start timing the second lap (the hour hand will move to indicate you're on the second lap), and so on. You can measure up to 20 laps this way. When you're fininshed timing laps, press the right side crown to see the best lap time. To reset the lap timer, hold down B for 2 seconds. To switch out of chrono and see the normal time, just press the right side crown in.
Chronongraph: To time an interval that is not a lap, just follow the above instructions, but instead of pressing A to stop the first lap, press B and the watch will show the elapsed time to the nearest 1/100th of a second. Hold B to reset.
Crown at 9 o'clock: This crown rotates the inner flange at the edge of the dial and is used to measure total race time (i.e. the total of all the laps). Simply rotate the crown until the the little start trinagle on the flange is aligned with the minute hand. This way, the total elapsed time can be read at any time, similarly to how a rotating bezel works.
To set the time: Ensure the watch is not in CHRONO mode, if so, press the right side crown in. At this time pull the right side crown out until you feel a click.The position the second hand moves to indicates what is currently being set. If the second hand is at 9 o'clock, you are setting am hours, press A repeatedly to set am hours. Then press B and the second hand will move to 6 o'clock, pressing A repeatedly will set the minutes. So on for year (11 o'clock), month (12 o'clock), and day (1 o'clock).
Posted on Apr 03, 2009
SOURCE: chronograph hand does not reset to 0 (12 o'clock)
fake
Posted on Jun 22, 2009
Bob Gemmell
  • 212 Answers
SOURCE: I have a TAG HEUER Grand Carrera and the second has stopped
Are you aware that these are automatic watches and need to be moved to keep the watch going, kinetic energy winds up the movement which allows it to keep going, if it is left off your wrist and in a drawer or sat stationary it will stop. Shake it violently (without dropping it) and it will restart.
Posted on Aug 26, 2009
  • 183 Answers
SOURCE: hi there i have bought a second hand tag heuer
Great watch! Operation should be pretty straight forward. The top button starts the chrono and stops it. The bottom button resets it. To calibrate the sweep arm into the right position pull the crown out to the first or second set position and press the start button until the sweep arm is in the start position you desire. This is typically 12:00 or 0.
If your chrono is not working then have the battery checked. If the battery has been recently replaced then make sure the watch doesn't need to be cleared.
I recommend you take this to a watch maker/technician who will be familiar with the service requirements of this model including resealing and pressure testing the watch to be sure it is sealed to its marked water resistance specifications.
Thanks!
Posted on Sep 20, 2009
How do I wind up my tag carrera automatic using the crown??
Wow, how wrong yall are.
There are three positions for the Carrera's push-down crown. The inner position is used for normal wear and winding. To wind the crown manually, simply rotate it clockwise.
Changing the date on the Carrera is done from the middle crown position. Turn the crown clockwise to advance the date, one day at a time. Push the crown back to the inner position when finished.
The outer crown position is used for setting the time. You can turn the crown in this position either clockwise or counter-clockwise. Adjust the time forward or backwards. Setting the time backwards will not damage the watch. When the time is correct, press the crown all the way into the inner position.
Feb 24, 2011 | Tag Heuer Automatic Chronograph Series...
My Carrera automatic does not keep time, it loses at least 2 minutes a day
2 minutes a few months is OK but 2 minutes a day is too much. Bring it to service center for clean & service.
Feb 17, 2011 | Tag Heuer Automatic Chronograph Series...
The stem broke off of carrera watch. How much should repair for this problem be?
mcdevito75 here, A new stem and crown Approx. for your Tag Heuer, $125.00 that"s if the stem is broken, if the stem just pulled out it may be able to be saved. Check here at fixya, bottom of page, click on repair service directory the watches.
Jul 03, 2010 | Tag Heuer Automatic Chronograph Series...
I have tag heuer carrera s laptimer. I cannot figure out how to adjust the time and am/pm. Can you help me?
Unfortunately the TAG web site does not have downloadable instructionsfor your model, so I can only suggest that you go to their site (www.tagheuer.com/the-brand/contacts-services/retailers/) --<copy this into your search engine and it will take you to the relevant section> and ask them for help. They claim to be helpful, so you may get all the information you need.
Feb 10, 2010 | Tag Heuer Automatic Chronograph Series...
Hi there i have bought a second hand tag heuer carrera tachymeter,i dont have a user manual,but cant seem to get the chronograph functions to work ?
Thanks!
Sep 20, 2009 | Tag Heuer Carrera Series Chronograph Watch
Tag heuer automatic series, how do you start the watch after purchasing?
push the crown in if it is in the adjust position .then shake the watch around the auto mechanism sould start the watch
Aug 23, 2009 | Tag Heuer Automatic Chronograph Series...
Quickly change date on my Tag Carrera
When yoy pull out the crown you will notice there are two clicks. You have to pull out crown to the first click only and then adjust a date by turning the crown.
Rate me, please.
Mar 13, 2009 | Tag Heuer Carrera Auto CV2113.FC6180 Wrist...
Watches Logo
506 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
