Question about Garden
What is the fuel mixture for Echo air blower PB 210 E Serge.
dontbother10
  • 2220 Answers
SOURCE: what is correct fuel mixture for Echo CS 6701
"Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more."
The above excerpt is from the Echo FAQs (6) here:
http://www.echo-usa.com/faqs/
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 08, 2010
localwonder
  • 6784 Answers
SOURCE: oil gas mixture of model pb-2100 echo leaf blower
GAS-- Use 89 octane r+m over 2 (mid grade or higher) This gasoline known to be good quality. Gasoline may contain up 10 15% MTBE (methyltertiary-butyl ether). Gasohol containig methyl alcohol is not approved.
TWO STROKE OIL-- 50: 1 is usable.
please rate and god bless.
Posted on Mar 27, 2009
SOURCE: Proper gasoline and oil mix ratio.
My echo uses 50-1 ration. Home Depot sells the small containers for Echo Leaf Blowers that you mix with one gallon of gas.
Posted on May 26, 2009
  • 4088 Answers
SOURCE: A pb-200 blower won't rev high enough
Does it seem to have about the same compression as the other? Does it have equal spark? Any excess friction when pulling it through? When you had the muffler and carburetor off, did you notice any piston skirt damage visible through either port area. How about carbon build-up at the upper piston-side of the exhaust port--common on 2-strokes running heavy oil/fuel mixes. Worn/leaking crankshaft seals?
Posted on Jul 04, 2009
  • 430 Answers
SOURCE: ho spark on a pb 403t backpack blower
Be sure you have no spark ( 90% of the units that come into my shop for repair with the complaint of no spark- have a fuel issue). Be sure the spark plug is good.
If no spark then remove the ground wire from the module and check for spark again. You must use the recoil starter- spinning by hand is not sufficient. If still no spark then replace module. If there is spark with the ground wire disconnected then there is a problem with the kill switch or a bad wire.
Posted on Nov 30, 2009
Fuel mixture for echo pb 400
Hi john b. thomas
Use the mixture of 50 to 1
1 pint of 2 cycle oil to 6 gallons of gasoline
Please take time to rate me
Bud
Sep 24, 2012 | Echo Garden
What is the fuel/oil mixture for my echo pb 250 blower
Sometimes, the fuel ratio is stamped on the fuel cap. Your ratio is 50:1. Echo specifies using 89 (mid-grade ) octane Here is a chart that tells you how much oil you need in a gallon of gas...Just 1/2 it for a half-gallon mix. A copy of your manual is also here.
http://support.mtdproducts.com/app/answers/detail/a_id/347/~/two-cycle-engine-fuel%3Aoil-mixture-chart
http://www.echo-usa.com/getattachment/624aee9f-103c-416c-ae9b-55fb42dd94af/PB250es1112_010410_1.pdf
Jul 22, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
I have an older echo blower. just had it tuned up and adjusted and still running poorly. just wondering if it is my fuel mixture of 25;1
25:1 may be too rich a mixture. Clean your spark plug well. Then get some good synthetic 2 stroke oil and try a 32:1 mix or a 40:1 mixture. Here is a fuel mix chart for you use.
May 15, 2011 | ECHO, Inc. PB-251C Handheld Blower
What kind of fuel do you put into an Echo PB201 Leaf Blower?
The blower is a 2 cycle, so you run an oil and gas mixture. Here is the link for the owners manual.
http://www.echotool.ru/files/50_17_21-21G-00.PDF
Apr 08, 2011 | Echo Blower Nozzle Es 2400 Pb 200 201 2100...
I lost my manual. What is the gas to oil ratio?
Your manual can be found here:
http://www.echo-usa.com/documentation.asp?Model=PB-251&lang=E
Please download a copy, IPL too.
Page 21 - Fuel Oil Ratio- 50:1 (2.6 oz/ 1 gal)
A rich mixture often causes hard starting.
Oct 29, 2009 | ECHO, Inc. PB-251C Handheld Blower
May 24, 2009 | ECHO, Inc. PB-251C Handheld Blower
Echco PB-230LN blower
Try adding some "Seafoam" brand additive to the fuel mixture, that did the trick for mine. Must have been something in the carb and the Seafoam cleaned it out, runs just like the day it came out of the box
Nov 01, 2008 | ECHO, Inc. PB-251C Handheld Blower
Garden Logo
569 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
