Question about Garden
I have a S&J strimmer SBC33NI and i wish to change the metal cutter with the nylon cutter how do I switcth the cutter head ? I have misplaced the manual
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: I have a Ryobi RBC30SBT
Hi and welcome to FixYa, I am Kelly
This took a while to find so I now understand why you gave FixYa the task of finding the manual.
Here are the manual links: Manual is 5.43 Mb
http://fr.ryobitools.eu/local/uploaded/catalog/e_RBC30SET-RBC30SBT_web.pdf
http://fr.ryobitools.eu/local/uploaded/catalog/e_960733002-02B_08Apr09.pdf
Parts can be found here:
http://services.ryobitools.fr/materiel.asp?zzz=1&materiel=RBC30SBT&Serie=1&DBRequestOnlyOneKEY=RBC30SBT%231#
Additional information and advice can be obtained from the in-house After Sales Support Team which can be contacted by telephone or e-mail:
UK Customers: 0800 389 0305
ROI Customers: 00 44 (0)1628 894 400
http://uk.ryobitools.eu/contact-ryobi.htm
Hopefully all of the links work for you and you have recieved what you needed.
Thanks for choosing FixYa,
Kelly
Posted on Aug 06, 2011
Partner strimmer
1clutch burned.2 link to the motor from the head inside the link pipe Brocken or worn
Aug 13, 2014 | Garden
Ryobi line strimmer hedge cutter attachment won't cut even though the blades are moving can you give any idea what he problem might be?
grass,string or vines can get wound around the motors shaft, you will need to take off the spinning head to remove debris from motors shaft
Jul 25, 2014 | Ryobi Garden
Could you please explain how I change from the nylon line trimming head to the metal cutting blade on my Echo brush cutter model SRM-22GES? Thanks for your help.
To change the head on the trimmer you will need to turn the trimmer upside down as if you were going to take the head off to restring it, spin the head and look for a slot in the side of the head when you see the slot, keep spinning until you see it line up with a hole in the metal piece the head attaches to. Stick a nail in the slot and hole and turn the head off the trimmer, if I remember correctly the head is backward thread.
Follow the steps backward for putting the brush blade head on the trimmer.
Apr 25, 2011 | Garden
Stihl strimmer engine runs but wont cut grass the head wont turn what cuts grass
First take the head off and look for grass, weeds and string wound up in there. A lot of times that's the problem.
Next, with the head off and the switch in the off position, pull it over a few times and see if the shaft spins. If not, could be a broken shaft or a bad clutch.
Apr 04, 2010 | Oregon Scientific Complete Carburetor for...
Small part fell out in grass and I can't find it. Where can I fi
They are called strimmer eyelets and most hardware shops, repair shops or hire shops will sell them
Oct 05, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have just bought an RBC30SET. I am trying to
To remove the strimmer and procut fitment first you need to lock the shaft by placing item 35 into the slot in the flange next to the fitment and through into the hole in the outer housing of the drive shaft, item 3. Then using the box spanner turn the fitment CLOCKWISE. Once this has started to move it can be turned by hand until it released. Place the brush cutter onto the shaft followed by the dished washer, cupped face towards the cutter and fix in place with the nut, turning it anticlockwise to tighted. DO NOT overtighted as the direction the cutter turns will tighten the nut further.
Sep 18, 2009 | Ryobi Garden
Huskvarna petrol strimmer
check spark plug connection & spark it self.
how I hear you ask...................
1st- ly remove plug connection from spark and place a screwdrive down into the rubber seal & scrach the sm.plate at the bottom remove s.driver and spray with WD40 and try this - failing this remove sparkplug from motor and ask some one to hold it and repeat after me -lol. No really place the bottom of the spark to the gills of the motor and pull cord - this will show you if the spark has a spark....if it dosen't then clean with sand paper and try again......
still no spark then you will need a new spark plug....
the type of head should make NO differents to the motor.
also it may be that you have flooded the engine in this case you just nedd to keep pulling cord in the on pos.with no prim.
hope one of these will work for you . best of luck.P
Aug 07, 2009 | Garden
BAD STARTER
it might have a easy start that wound make it seem like its sliping.change spark plug and gap at 030.see if it helps if not rebuild carb.
good luck
Jul 20, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Loose Cutter Block
when you remove the cutter block is there a white nylon fixture atop the vibrating mechanism? this nylon piece snaps on the vibrating rod and the cutter snaps into the nylon fixture.
Sep 02, 2007 | Braun Syncro 7526 Electric Shaver
Motor runs both forward and reverse, but cutters don't turn
How about a hidden 7th screw? If you look at the sticker on the underside where the bar code is you may see a dimple like there is a hollow space under it. If you can't see it, rub your finger over it to find the hole. Just stick your phillips screw driver through the sticker to get access to this last screw. As for the motor working both directions but the cutter doesn't turn it is most likely a broken nylon cog on the drive gears within the white plastic housing at the end of the shredder. There are 3 or 4 gears - all nylon (plastic), my unit had one tooth completely broken off and the one next to it was worn. I am looking into finding parts but I'm not having any luck so far with local service centres. I have a call into the fellowes main 1-800 number to see if they can help. On reviews I have seen this is a common problem. One reviewer was told they use nylon to reduce noise, but of course it isn't going to last long, especially if you ever jam. Nice metal cutters but the weak link is the drive gears that you can't see.
Oct 16, 2006 | Fellowes P600C-2 Shredder
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
