Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
The trigger will not dispense solution. the clean surge trigger, however, does work. what am i doing wrong
Hoover floormate fh40160 won't dispense solution
Hi there! Sometimes it is necessary to prime the trigger to get the solution flowing. Try these quick steps.
1. Recline the handle.
2. Pump the trigger vigorously about 60 times.
3. Power the cleaner on and squeeze the trigger for 60 seconds.
The cleaner should start to dispense the solution. Be sure you are using only the recommended cleaning solution to avoid internal damage. If your Floormate is still not dispensing there could be an issue with your pump. We would recommend taking the cleaner in to a Hoover authorized service center for repair. Follow the link to locate the nearest service center to you. Service Center Locator
Hope this helps!
Jul 07, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
How can I fix my Hoover spin scrub 50 solution trigger? It is not working.
Hey there! Sounds like you have no tension in your trigger. This could mean a problem with the trigger spring or control rod in the handle. Try reassembling the handle. Remove the two handle screws and slide the handle up and off. Inspect the control rods for damages. They should be the same length. Make sure they are pulled down as well. Reassemble the handle. If the trigger still has no tension but the cleaner dispenses from the hose, a replacement handle may be needed. To replace the handle, follow the link below.
Search Results
Hope this was helpful!
Jun 11, 2014 | Hoover SteamVac Spinscrub 50 Carpet...
My Hoover Two Tank carpet cleaner still dispenses cleaning fluid...but only if I keep my thumb down on the 'extra solution' trigger. The main (and much easier to use) trigger doesn't work anymore. I'm...
The main trigger might have broken. This is common if the trigger is pulled too hard. You can take the handle apart on most units and replace the trigger. Usually the broken spot is where the trigger pivots.
Oct 29, 2013 | Vacuums
I just bought a hoover steam vac model F5914900 and the clean water tank is leaking. I tried pressing the clean surge button and the trigger button that was suggested by someone else but it won't
Go to Hoover.com and find a local Service Station. They will replace it at no charge. MUST be a warranty location to get it free. Take your sales slip with you.
Jul 28, 2012 | Hoover SteamVac F5914-900 SpinScrub...
It is not dispensing the shampoo on to the carpet.
Firstly, please ensure that there is shampoo in the tank and the tank is correctly and fully inserted. There are 2 ways to dispense shampoo on to the carpet:
1. Use the solution trigger on the underside of the handle (numbered 2 in the picture below)
2. For tough stains use the "Clean Surge" button to dispense extra shampoo (numbered 3 in the picture below
Dec 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I have bissell proheat 2x 9200 no water or cleaning solution is dispensing from bottom of machine hand dispenser is not working too. how can I troubleshoot it?
Ensure you have water in tank and solution (or water in solution tank). When you start the vacuum up, the pump starts to prime itself. If you have air in the system, it takes a little longer to prime. Allow the vacuum to run for 1 minute before attempting to pull the trigger. Then pull the trigger.
If this doesn't work, you'll need to open the unit up and check the hoses for any clogs, and next test the pump to see if it is functioning.
Jan 21, 2010 | Bissell 9200 Upright Vacuum
Cleaning solution tank dumping
in some cases the reservoir that the tank sits on would have to be replaced. best way to tell is, if you take the tank off and pour a little water in the valve where the rubber gramet is. if it holds the water its good, but if it goes down without you pressing the trigger then it will be the reservoir.
Jul 27, 2009 | Hoover F5906-900 Upright Steam Vacuum
Detergent constantly dispenses
I would check to see if the trigger is still pluged in it sound as if the trigger is not pluged in or it is hung up.
Jan 24, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
When squeezing trigger and Depressing Clean surge Button on Upper handle of the Hooover Steam Cleaner F5914-900 there is no "snap" indicating trigger rod is in place. Everything else went in as...
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=552215
Generic problem for all Vacuums
Posted by lnikol6 on Apr 28, 2008
Hoover Steam Cleaner F5914-900
When squeezing trigger and Depressing Clean surge Button on Upper handle of the Hoover Steam Cleaner F5914-900 there is no & quot; snap& quot;
indicating trigger rod is in place. Everything else went in as instructed. The screws and bolts were no problem
this concerns me because the main complaint I read about this model was leaking from the trigger and clean surge and the problem was not getting the rod in place. No matter how many tries or people (three) it still doesn't occur.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I would suggest getting a schematic, owners manual or product breakdown to see what you are doing wrong or to check with the Hoover tech support line to see if the can either mail, fax or email the schematic to you so that you can complete your service job. There is something definitely happening with the serv job that we are overlooking and the schematic or product breakdown will help in the serv job you are doing, it sounds to me that you are doing things right but there could be another broken part or while installing the current part may not have been install properly, or is in need of an adjustment. Feel free to contact your local vac dealer or contact the Hoover Tech Line listed below:
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Apr 28, 2008 | Vacuums
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
55 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
