Question about Dishwashers
Hello! we have LG LD-2120WHU and we have error OE!! we glean filters, and try different programs and and seems to as,water not goming to dishwashers??? Thanks!!
2 Suggested Answers
  • 3 Answers
SOURCE: LG dishwasher LD-2120WHU I get the
This happens to my LG dishwasher every 6 months or so. It also makes a groaning sound as if the system is starved for water. The resolve the problem by removing the dishwasher and laying it over on it's right side. I then remove the two plastic assemblies that are on the left side and I remove them from the dishwasher (you will need a vice grips to remove the hose clamps from behind them, you will also need to remove the round circular water intake plastic disk that is on the inside of your dishwasher on the left hand side right in the middle of the left wall) and clean them. Once the water can run freely through these plastic parts you will get a good water flow and you should be fine. Until you have time to do this I recommend putting a few quarts of hot water into your dishwasher once you start to hear the groaning problem. This solution should be very easy for anyone who is comfortable doing their own oil change. Oh, and turn off the power supply first.
Posted on Nov 07, 2010
Hello, LG LD 14AT1 dishwasher, starts cycle runs 3 minutes, starts stops on off no water in bottom. Then displays OE chimes! Checked tap under sink water there, checked filter inside bottom, turned off for...
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
May 26, 2010 | Dishwashers
My Lg Dishwasher , model 12aw2 , has an error message OE shortly after start up , dishwasher is over 6 years old , is this a simple fault to repair? or not worth it ?
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 11, 2010 | LG 24 in. LD-12BW5 Free-standing...
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
My husband has just installed a LG LD 14AW2 which was given to us
OE = Outlet Error It involves everything related to pumping the water out. Easiest is to start at the drain and work back. Check for a plugged drain. then a kink in the drain hose. A plugged hose?
If problem remains, remove lower rack and unscrew/remove the filter from the sump area, looking for debris. Rinse out any filter in the mesh filter. Look again for anything that is blocking the drain outlet. Reassemble and run a cycle.
If problems continue, the probable cause is a failing pump motor. Servce call time.
Good Luck!
Mar 30, 2009 | GE GSD5920 Dishwasher
Ld-1204w1
What did you find the problem to be?
On an LG dishwasher, I am not aware of an E0 error. But there is a "OE" error code (as in output error)
The first thing to check is the lower sump area - remove the filter beneath the spray arm and look everywhere for blockages that have slipped through. If that is not the problem, the drain motor has probably failed.
Good Luck!
Oct 19, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
OE fault in Dishwasher model LD-14AT2
suggest you take the drain pump motor out and inspect. either a blockage or its defective.
Jun 15, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG LD-12AW2
this unit has an anti flood device. if it leaks it lifts a piece of plastic in the base and hits the microswitch. try leaning the unit to one side and i would put towels down. if water comes out then try a program. hope this helps.
Feb 12, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LD-14AW1 keeps coming up with OE error code
Good Luck!!!
Oct 28, 2006 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
130 people viewed this question
Top Dishwashers Experts
Owen Barnes
