Question about Kenmore HE2 Plus Front Load Washer
Hello, I have a Kenmore HE2 Front Load washer, Model 110.46462500. The washer fills with water even when off, and I believe the problem to be the "inlet mixer valve" (which I presume is the same as a "fill valve"? I was trying to find what that actual part number is. Thank you.
  • Kenmore Master
  • 2,128 Answers
Part number 8540751 and it's around 30 to 35 dollars and it is the water valve.
Posted on May 19, 2011
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
A light came on to clean the washer. Is there something special I need to do?
Even a blonde can do it! Quick fix/repair for Kenmore He2 ...
? 4:57
https://www.youtube.com/watch?v=4o9hWHQkOMM
Sep 1, 2013 - Uploaded by And Justice For All
Quick fix/repair for Kenmore He2 front loading washing machine... a Kenmore He2 front loading washing machine when blinkinglights error code occurs ... How to Clean Front Load WasherDrain Filter and Empty the Water ...
Front Load Washer Pump Clean Out - YouTube
? 3:03
https://www.youtube.com/watch?v=f9uS8_0-pWY
Sep 6, 2012 - Uploaded by GE Appliances
If you have a front load washer with a pump filter, your pump filter may become ... pressed start again but it still stops and the cleanpump light still comes back on. .... Samsung Washing Machine cleaning the pump & coin trap
Nov 29, 2015 | Kenmore Washing Machines
Kenmore he2 won't stop filling
sounds like a faulty inlet valve. if its got 2 pipes at rear too fill. turn 1 off and if it still fills the other 1 is faulty and vise versa
Jun 18, 2014 | Kenmore HE2 Plus Front Load Washer
Kenmore he2 plus front loader washer no water and no error code.
there are 1 or 2 valves that go into the m/c where the pipes from under you sink etc go to the washer these are two valves some times these fail and dont let water into m/c hope this helps ivan
Sep 27, 2012 | Kenmore HE2 Plus Front Load Washer
My Kenmore HE2 front load washer when I go to start a load of clothes it's making a humming sound and not filling up with water?
Either one of your water valves isn't working properly, or the lines have sediment restricting the volume of water . What I would do is turn the water to the machine off and remove the water lines and make sure they aren't filled will calcium, etc. and look in the water valves where the hoses connect because that are, which has a screen, may be full of nastiness. If both those are good then the water valve solenoid(s) are stuck and won't open. The humming sound you hear lets you know the rest of the machine is working because the sound is generated by power being applied to the valve by the control.
Jun 21, 2012 | Kenmore 43142 Front Load Washer
My Kenmore front load He2 fills with water in the dispenser cup then spills out from the dispenser cup onto the floor. Can anyone help?
SOLUTION...DON'T BUY THIS PRODUCT. THEY ARE LEMONS.
Kenmore you failed. Claudia Bennett, Boston
claudiabennett80@aol.com
I should have kept the older unsophisticated model ...my basement smells...I did not know I am supposed to be a technician to wash my clothes!!!!!!!!!!!!
Jul 30, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
126 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
