Question about Hoover F5881-900 Vacuum
Cleaning stairs no solution and no suction from tube
    Master:
  • 623 Answers
Clean your vacuum cleaner
Posted on Aug 14, 2008
When you remove hose and insert the attachment for cleaning stairs there is no suction
There is something lodged in the attachment clogging it up.
Mar 24, 2011 | Vacuums
How to attached stair cleaning attachment
Hi There,
I'll be happy to walk you through step by step how you can attach the hose to your Hoover SteamVac.
Here are step by step instructions for you:
Step 1. To prevent possible leaking, remove
clean solution tank by pressing down on
tank handle (D) and pulling forward; set
tank aside (do not set tank on furniture2_bing.gif).
Remove hose from storage rack.
Step 2: Step on handle release pedal (E) and
lower carpet cleaner handle until it rests
on the floor.
Unlatch back part of recovery tank and
remove lid.
Step 3: Remove recovery tank front panel (F)
by sliding it straight up.
Step 4. Replace panel with converter (G).
Slide converter halfway down opening
until it is firmly in place.
Step 5. Before connecting tube (H) to
cleaner, make sure black tabs are
extended by pulling tan collar toward
tube.
Open door on hood labeled “Stair/
upholstery Cleaning Connection”. Press
round solution tube connector onto
round projection inside door. Press connector
collar down firmly to ensure
that it is fully connected.
Step 6. The tank replaces in a hinge-like
manner. Position front of lid under tabs
(I) on front of tank. Rotate lid down onto
tank.
Make sure lid is secure on all sides
before cleaning.
For full suction, it is important that
the recovery tank lid is properly
secured before cleaning.
Reverse procedure to remove hose
and solution tube.
Raise carpet cleaner2_bing.gif handle to upright
position.
I hope that this was helpful to you in hooking up your Hoover SteamVac hose. If you found this helpful, please be so kind and rate my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair, this is really appreciated.
Thanks again,
Chris J.
GoVacuum.com
Apr 25, 2010 | Hoover F5835900 Upright Steam Vacuum
How do i hook up my stair cleaner part to my hoover steamvac to clean my carpeted stairs? f5909=900 model
Hi There,
on the floor.
remove lid.
tube.
tank.
before cleaning.
and solution tube.
position.
Thanks again,
Chris J.
GoVacuum.com
Apr 25, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hi when i use tools to clean stairs etc loss of suction have checked tube seems ok.........
first of all, are you using a extended piece on the hose? if so then you should feel around where the hose and extended piece are see if air is leaking
Nov 29, 2009 | Hoover U8145-900 Savvy Bagless Upright...
How to I attach the stair / couch hose cleaning tool
on the rear of this model there is a suction port that you can open to attach the hose and tools
Oct 20, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
No hose suction
Clean your round filter and make sure there is nothing in the elbow tube in the bottom/back of the vacuum.
Jan 13, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
No suction with attatchments
if you have cleaned all the filters, there are two you need to wash and the hepa on the back may need to be changed, but the hose is probablly clogged. You can usually remove the hose ( twist it where the hose connects to the machine ) and use a broom stick to try and push the clog out.
Jan 12, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
Setting up for apolstery cleaning
Hoover Steam Vac F5853-900 Series 17.9
Remove the tank front panel by sliding it straight up. Replace panel with converter (located on end of hose, end is shaped like front panel that you slide out.Before connecting tube to cleaner, make sure black tabs are extended by pulling tan collar roward tube.Open door on hood labeled "Stair/Upholstery Cleaning Connection" Press round solution tube connector onto round projection inside door. Press connecator collar down firmly to ensure that it is fully connected.
When the solution tube is connected to the deep cleaner, the nozzle brushes will automatically be turned off and will not rotate when the deep cleaner is turned on even if the speed selector is in the HI oar LO position. For full suction, it is important that the recovery tank lid is properly secured before cleaning.The tank lid is replaced in a hinge-like manner. Position front of lid under tabs on front of tank. Rotate lid down onto tank. Make sure lid is secure on all sides before cleaning.Hope this helps.
Good Luck
Nov 15, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Stair attachment has weak suction
Did you put the duct in for the hose? It goes in front of the tank, take out the duct (#3)that is there and put in the duct that is on the end of the hose. Is there a slit somewhere in the hose, if so you will loose suction.
Nov 17, 2007 | Hoover F5826-900 SteamVac Upright Wet...
Tools
On the front of the dirty water tank is a block that you pull out(don't forget to put it back in when done, or you won't have any suction), Remove recovery tank front panel
(F) by sliding it straight up.
toward tube.
Press connector collar down firmly
The tank replaces in a hingelike
under tabs (I) on front of tank. Rotate
lid down onto tank.
hose and solution tube.
Raise carpet cleaner handle to
upright position.
Sep 13, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F5881-900 Vacuum Logo
44 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
