Question about Intel DP67BG P67 Chipset Desktop Extreme Board and Intel Core i5-2500K 3.30GHz Quad-Core Unlocked CP... (BOXDP67BGBundle)
HELLO - i have motherboard dp67bg the wifi cant be recognized by the window error code43 i tried drivers update.no use.in the device manager yellow triangle at the icon and theres no use.please could u help me.Many thanks Rog
  • 75 Answers
It could be the cable if it uses one, have you checked that? Did it come with a CD? Are you sure it's not broken?
Posted on May 19, 2011
Not recognized, needs USB driver
Click start control panel administration tools computer management device manager scroll through all of your devices If you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver If you computer came with a motherboard disk the drivers could be on it. Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Feb 01, 2013 | Aluratek Cinepad 4GB 7" WIFI Capacitive...
Uncknown device error code43
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luck
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Apr 13, 2012 | SimpleTech SimpleDrive Pininfarina 320GB...
Hello, I have Vista home premium on a Compaq laptop, windows. I have the Device Manager open and the isatap (with a lot of numbers in perenthesis after it). The yellow exclamation point is on it. how do...
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
cd/dvddrive not seen could be a registry problem
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
http://www.driver-fix.com/scan.php?id=scan5&key=2
Drivers Freeware
Now you can download driver updates automatically and safely. This handy software utility will keep your system up to date by automatically getting the latest drivers from your hardware
Oct 31, 2011 | HP Compaq Presario F500 F700 and G6000...
My writemaster has stopped recognizing blank discs, so I cant burn cd's or dvd's. can you tell me is there a fix for this?
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Sep 07, 2011 | Samsung Computers & Internet
System does not recognize the existence of HPdvd1170e. Error reads " not accessible" incorrect function" when I try to write to a dvd disc. My oper.system is Windows XP. External DVD writer...
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
Aug 24, 2011 | HP dvd1170e DVD-RAM Burner
Hello, I can't read CD/DVD, but I can do an eject from the windows explorer. Could you please help me?
im not sure what this can't means
click start control panel administrive tools,computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps
Apr 23, 2011 | Computers & Internet
The wi fi was remove after re formatting the laptop
To reinstall or update follow the Steps:
• Go to Start>
• Control panel>
• Double click on "System" Icon> (it shows the System PropertiesWindow)
• Select "Hardware" Tab>
• Select "Device Manager" Tab> (it shows the Device Manager Window and checkis there any thing is in yellow color or yellow question Mark). If not,
• Select "Network Adapters">
• Expand "+" symbol> (check the WiFi adapter is not in Questioned Mark (?)symbol with yellow color). If yes, need to install the drivers.
Right click on adapter (it displayed as unknown) > select update drivers, and specify the path.. to install..
Download the drivers from Website or if you have Motherboard CD, > insert the motherboad CD, browse>select WiFi driverfrom CD or downloaded path > install. After completion, restart computer andcheck.
Jan 19, 2011 | Computers & Internet
USB ports not working. Is it possible to repair the mother board or does entire motherboard need to be replaced? Have already tried disabling root hub, controllers etc. But still get unknown device...
have you tried updating the ports driver
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)right click update driver
hope this helps
Nov 27, 2010 | Dell Inspiron 1520 Motherboard
Hello, I just by a NWZB152, and my XP do not recognize it. I check, and i have XP sp3, and Windows Media Player 11 instaled. In Device Manager, under device status it says "Reinstall the drivers...
go to device manager. You will find MTP with a yellow mark on it. Right click - properties and uninstall. When hardware wiz come up again,cancel the driver install, and should not bug you again. If you really need this device, (don't think you do) look for driver on MB manufactures web site.
Nov 10, 2010 | Computers & Internet
Hi, My computer doesnt recognize the cd\dvd drive....
Hello there!
You won't probably be able to find drives because Sony, the makers of Optiarc, rely on Windows to supply the drivers.
You can right click the devices and remove them. If Windows asks, check the box to removed files as well.
Then reboot the computer. That may do it on it's own.
If not, run Windows update, and make sure to check the section about optional updates.
Aug 04, 2017 | Computers & Internet
Intel DP67BG P67 Chipset Desktop Extreme Board and Intel Core i5-2500K 3.30GHz Quad-Core Unlocked CP... (BOXDP67BGBundle) Logo
204 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
