Question about KitchenAid KHMS145J Microwave Oven
Kitchen aid kcms145jbl-1 microwave. When I push start the light comes on a second later I hear a click the turntable does not turn and the timer countdown works.. it thinks it is cooking but it is not. I tried playing with dor moving up and down and pushing it in. no luck,
  • KitchenAid Master
  • 43,501 Answers
One or some of the high voltage parts inside have gone bad. It then blows a fuse which stops everything.
The fuse could be replaced, but that would be a temporary fix most of the time.
Do not try to repair a microwave yourself as there are dangerous voltages inside that can kill you!!
If you want to try to get it repaired it is best to find a local shop that will do it for you.
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on May 19, 2011
Lights on, timer going, but not heating, no whirring sound & turntable not turning
KITCHENAID are a budget make despite what you paid. it is better to buy a company that specialises in microwave ovens rather that a company that buys cheaply made products in China or Taiwan and badges them. As you know KitchinAid is a company that does all sorts of kitchen gadgets and utensils. Toshiba and Panasonic are the brand leaders. GE are long established.
The problem with yours sounds like a safety interlock problem. Every microwave has about 4 safety switches attached to the door so that it is impossible for the unit to be run with the door open. They are small micro-switches that are adjusted like a hair trigger so that as soon as the door moves, power cuts. If it is the switch, it is a cheap fix, if it is the Magnetron, it isn't, so diagnosis is needed by a reputable company. You can't take it apart as they use security screws because of the dangers of cooking yourself and the high voltages in the capacitor, and poisonous Beryllium in the magnetron. Your call on fixing or buying new.
Mar 11, 2017 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kitchen aid microwave kbms1454rss clicking
Yes! from the information, you probably have one or two defective door switches. Parts need to be replaced for normal operation.
May 19, 2012 | Microwave Ovens
Problem with GE microwave-JES738WJ02
The problem is one or two door switches are malfunctioning or the keypad control board has failed.
Apr 23, 2012 | GE Microwave Ovens
I cannot stop the DEMO
Demo Mode The Demo Mode is ideal for learning how to use the microwave oven. When set, functions can be entered without actually turning on the magnetron. The microwave oven light will come on, the fan will run, the countdown will run very quickly in the display, and the turntable will rotate. To Turn On/Off: The microwave oven and Timer must be off. Touch and hold TIMER SET/OFF for 5 seconds until 1 tone sounds. Repeat to turn off.
Jan 21, 2012 | Whirlpool Microwave Ovens
Re. Viking DMOS200 1100 watts microwave oven does not turn on
I'm guessing that's a VMOS200?
If so, that's a rebranded Sharp R-530ES (as is the Dacor DMO2420S) and its secondary interlock (bottom door switch) or that switch's mount is bad.
See this file on door switches. If you only need a switch, you can order a universal type here for $5 postpaid.
The Sharp R-530E service manual will aid you in disassembly and it is here.
Jul 02, 2010 | Viking DMOS200 1100 Watts Microwave Oven
The timer counts down but the microwave doesnt turn on.
I have a FNCB115GC Microwave problem. The microwave has a icon on the left hand side of the panel that looks like a opened book on a stand with lines on top. This is best that I can descibe it. The microwave turntable does not move or the microwave does to come on but the light comes on and the timer will count down. I have cleared the microwave and unplugged it with no results. Please help. Thanks in advance.
Jun 03, 2010 | Frigidaire FMCB115GC Microwave Oven
Heating ceases after one second
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://207.234.249.73/mwd/safety.txt http://207.234.249.73/mwd/disassembly.txt http://207.234.249.73/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
If yours is not a Panasonic, please reply back with your brand and model number so we can help you.
May 30, 2010 | Panasonic NN-H275 Microwave Oven
The door of my Kitchen Aid Microwave YKCMS1555RSS wouldn't open because the plastic prods that push open the latch had worn down. The oven was otherwise functional. I inserted some plastic knobs to extend...
The door latch heads (prods) are not making proper contact with the door switches, so it will not work right.
The latch heads need to be replaced.
You can order parts for this Canadian model here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 02, 2008 | Microwave Ovens
No fan, turntable or heat, but counts downs
The 'Clock, is Machanical just like an ordinary kitchen timer The reast of it is electronic, and at that age time for a new one.
Jun 26, 2007 | GE JE1640WA/GA Microwave Oven
KitchenAid KHMS145J Microwave Oven Logo
105 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
