Question about Toshiba 42HL167 42 in. LCD Television
I have a toshiba model 42HL167. the tv turns on and displays only virtical colored lines. all of the video ports in the back also dont work. what can i do to fix this the cheapest means?
  • 760 Answers
You need to replace your T-com board. Not very expensive.
Posted on May 19, 2011
  • David Duncan
    David Duncan May 19, 2011
    I meant to say T-con. Not com. Sorry.
Samsung LED TV, Model# UN55B6000VFXZA turns on to black screen then displays large blocks of colored vertical lines?
check every flat cable main boerd to t-con t-con to display if dont help display is a problem
Feb 24, 2017 | Samsung Televison & Video
Brand toshiba lcd model 42HL167 no image but only menu dis ok
This could mean that the tuner board is bad. By saying "no image", does that mean that there is snow on the screen (i.e. from no signal received), or simply a black background or distorted image from bad reception? If the menu is displayed than that means that the image driving circuitry is working correctly.
Jul 19, 2014 | Toshiba 42HL167 42 in. LCD Television
42hl167 no picture but has sound
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 02, 2014 | Toshiba 42HL167 42 in. LCD Television
Screen goes blank on toshiba 42hl167. sound still works, and turning the tv off for a few minutes restores the picture.
your tv's pictures tube are creating the problem. contact with the tv brand customer services center for the repairment of your tv
Jan 06, 2011 | Toshiba 42HL167 42 in. LCD Television
42" toshiba regza tv hdmi inputs location
Download the manual below it will tell you all. Its on page 12,it sorta on the Right hand side down bottom, it IS marked. http://www.tacp.toshiba.com/tacpassets-images/models/42HL167/docs/52hl167_e_final.pdf
Mar 13, 2010 | Toshiba 42HL167 42 in. LCD Television
Tv will not turn on
Possibly not.. in this case with the 42HL167, the CPU pcb (most commonly referred to the SEINE PCB) is having issues booting and just isn't starting up.
My friend gave me his 42HL167 after this problem started after a power event during a storm and I managed to fix it by reloading the firmware.
I posted instructions on my website at:
http://www.benjammin.net/www/pages/techtips/Toshiba-Regza-42HL167.html
Once I figured out some of the facts, it was a breeze...
I posted this elsewhere here since there's so many duplicate threads... trying the firmware update is simple, so it's worth trying that first since the case doesn't need to be opened.
-Ben
Jul 10, 2009 | Toshiba 42HL167 42 in. LCD Television
Magenta Color
Here is something that may help from the toshiba.com website under your model number television. Q. Why are people on my screen green?
Models: 32HL17, 37HL17, 42HL17, 42HL167, 47HL167, 52HL167, 42HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00107
If the problem is not the connections, try adjusting the tint on your television. A high tint setting will usually create a green
image on the screen where as a low tint will create a more red hue. In order to access your television's tint:
1. Press the “MENU” button on your remote control and use the LEFT or RIGHT arrow keys and select the
VIDEO menu.
2. Then use the UP and DOWN arrow keys to highlight PICTURE SETTINGS and press the "ENTER" button on
your remote.
3. Next use the UP and DOWN arrow keys to highlight TINT then use the LEFT or RIGHT arrow keys to adjust the
TINT. If the picture is too green the tint will need to be lowered.
4. Once you have adjusted the tint to your liking, use the DOWN arrow key to highlight DONE and press ENTER. The toshiba customer service telephone number is : 1-800-631-3811. I hope this helps you with your problem.
Feb 01, 2009 | Toshiba 42HL167 42 in. LCD Television
No sound on my Toshiba Regza 42HL167
Found this troubleshooting method on the www.Toshiba.com website. Q. My TV has a picture, but there is no audio?
Models: 20DL77, 20HLK67, 26HL47, 32HL17, 37HL17, 42HL17, 26HL37, 32HL37, 20HL67, 26HL67, 32HL67, 37HL67,
42HL167, 42HL67, 47HL167, 52HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00128
1. Please check your connections and make sure if you are using COMPOSITE “yellow, white, and red cables”, SVIDEO,
with “white, and red” or Color Stream COMPONENT “green, blue, red, white and red cables,” that the white
and red cables which are used for audio are plugged in securely into the same inputs as the video.
If your connections are secure, the station may have broadcast difficulties. Try a different channel.
2. If you are using the coax cable from the wall, press the “ENTER” button on the middle of the remote. If the
information provided shows that you have SAP selected we will need to change it to STEREO or MONO. To do
this, we will need to press the “MENU” button, and use the RIGHT or LEFT arrow keys to highlight the AUDIO
menu. Next we will need to use the DOWN arrow to select AUDIO SETUP press “ENTER” and then arrow down to
MTS and use the RIGHT arrow to select stereo.
3. If you have a cable box or satellite receiver, please make sure the TV’s volume, as well as the box’s, volume is
turned up sufficiently.
4. The station may have broadcast difficulties. Try another channel.
5. The sound may be muted. Press VOLUME.
6. If you still have problems after following these steps please contact Customer Solutions at 1800-631-3811 Monday
through Friday 8am to 7pm CST. The Toshiba customer service number is 1-800-631-3811. I hope this helps you with your problem.
Jan 06, 2009 | Toshiba 42HL167 42 in. LCD Television
How do i take the stand off of my toshiba tv model 42hl167?
Ok, this is what I did. I had to remove the four screws in the back of the tv. You can look in your manual for what screws or look up toshiba.com ... customer support, and enter your model number and from there you should be able to find the manual.
Dec 01, 2008 | Toshiba 42HL167 42 in. LCD Television
Have Virtical and horazonal lines ....Please help
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Mar 14, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 42HL167 42 in. LCD Television Logo
105 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
