Question about Refrigerators
Refrigerator drip pans too expensive are there alternatives?
I need an alternative for a drip pan instead of spending 40 some dollars for a new one. My thought would be to get a plastic painters pan used for rollers and put a sponge in it.
    Scholar:
  • 132 Answers
Whats the sponge for ??
Caution with the type of plastic tray you use.
Theory is - yes you can do what you suggest - However - dependant on the location of the drip tray (above motor ! ! ! ) some plastics will 'perish' and become brittle / fibrous.
Posted on Aug 14, 2008
How do i replace a oil housing gasket on a 2000 3.8 grand prix?
You'll need new gasket for oil pan,,,proper socket and drive to fit the bolts around circumference of pan.scraper and new oil or catch pan to save old oil, approx 5 qts . 1/ Begin by draining oil....drain plug on lower part of pan..get that wrench also.....it is larger than bolts arund pan......2/after drained, put drain plug back in and tighten snugly. not too tite......3/remove pan by removing all the nuts around pan, dislodge pan from it's seal , may takea little tender tapping with rubber mallet to release the pan, do not pry at lip, you may damage pan....4/ Clean both sealing surfaces of old gasket.....5/ dampen new gasket with oil and put it on pan in proper position, ....6/put bolts back in pan one on each side to hold pan up,,,put rest of bolts in pan and tighten in random pattern around pan trying to keep pan even at mating to engine.....7/when pan is on and fairly snug, fill the oil into filler at proper fill neck w proper amt of oil. about 5 qts,U.S......Make sure drain plug is not dripping, if so, put a little more torque on it. Not too much,they are prone to strip. Done. Or, about 40 dollars at oil change place.
May 16, 2017 | Cars & Trucks
George Forman Grill GFSG80
Hello!
In this case, I would rather suggest you to go to the vendor of your george foreman. maybe they have some spare parts for replacement or incse not found, I am sure they know the service center of your stuff that cater your needs.
May this help,
Melnavz
Feb 23, 2008 | George Foreman GFSG80
Model# kfcs22evms8 kitchen aid fridge- how to clean drip tray? Can't get at it.
Clean Refrigerator Drip Pan, Clean Walls - YouTube
? 2:55
https://www.youtube.com/watch?v=I9YP0iH_zho
Aug 5, 2008 - Uploaded by Handyman Matters
Scheduled Home Maintenance: clean refrigerator drip pan and wipe ... leaking,Kenmore,Sears,Whirlpool,KitchenAid,Roper,10677292790 ...
How to Find the Drip Pan on Refrigerator ' Home Guides ...
homeguides.sfgate.com > Real Estate Rentals & Leases > Get out of Leases
The drip pan on your refrigerator is a receptacle that catches condensation flowing from ... Occasionally you may need to get to the drip pan to clean it, remove a ...
KitchenAid refrigerator drip pan Questions & Answ
Dec 16, 2015 | Refrigerators
How do I locate and clean drip pan on LG french refrigerator?
the evaporation pan is under the refrigerator, over the top of the compressor unit. Sometimes fungi or algae can grow in there causing a mildew smell. If you can get access to it you can pour a mixture of baking soda and water into the inner part of the pan to destroy the plant matter and remove smells. About 1 tsp in 1/2 cup of water should do it.
Alternatives: 1/2 cup water with 50 ml white vinegar, or 20 mls bleach should do it. Be sparing with the water - it has nowhere to go but the floor after it overflows the evaporation tray.
Dec 21, 2014 | LG LFX31925SB
How do i replace the cracked drip pan in the french door refigerator
  • Unplug the refrigerator from the power source and remove the decorative vent cover at the bottom of the fridge under the door. Some vent covers are screwed on but many just snap onto clip that hold them in place.
  • Pull gently on the exposed front edge of the drip pan and ease it out towards you. The drip pan slides on runners on each side of the bottom of the refrigerator. It may be full of liquid or debris so go slow and steady and then discard it.
  • Line up the new drip pan with the two side guides beneath the refrigerator and slide into place. Use the flashlight if to make sure the drip pan is in the groove on each side.
  • Clean and replace the vent cover by clipping or screwing it into place. Plug the refrigerator back into the power outlet
  • Dec 15, 2013 | Freezers
    I have a brand new kenmore oven. I did not realize that the burner is under the bottom of the oven. I put an aluminum drip pan on the bottom of the oven and turned it on for the first time. The pan is...
    You may be able to scrape off the remains of the pan but you must be careful to avoid damaging the oven lining. The alternative is to buy a new oven.
    Nov 27, 2013 | Kenmore Ovens
    How do i remove a drip pan from a kenmore refrigerator
    The drip pan collects water when the freezer goes into a defrost cycle. Most times there is very little water and the water evaporates quickly. When there is a problem with the freezer or the water does not evaporate between defrost cycles, the drip pan fills with water. If the front bottom of your refrigerator has a grille, you access the drip pan from the front. If there is no grille, access the drip pan from the rear.
    Instructions
    Rear Access
    1 Unplug the refrigerator from the wall outlet. Pull the refrigerator away from the wall so that you can access the rear of the refrigerator.
    2 Look under the refrigerator with a flashlight and locate the drip pan. Often when people install refrigerators they neglect to pull the packing from around the drip pan. The drip pan may have tape or styrofoam around it.
    3 Remove any packing material away from the drip pan and pull the drip pan out from under the refrigerator.
    Front Access
    4 Pull the grille at the bottom of the refrigerator below the refrigerator door with your fingers. The grille secures to the refrigerator with plastic clips.
    5 Remove any debris from the access area and throw the debris in the trash. The coils and fan under the refrigerator attract dust and dirt. Clean out the area with a lint brush if you have one.
    6 Pull the drip pan out from under the refrigerator.
    Apr 20, 2012 | Kenmore Refrigerators
    Drip pan replasment on mzsd2665heq
    Hello there,
    To remove and replace the drip pan on your refrigerator, please follow the instruction below:
    1. Unplug the electrical cord of the Maytag refrigerator from the power outlet before attempting to remove the drip pan.
    2. Detach the grille on the bottom of the refrigerator in the front, pulling the grille off by hand.
    3. Place a towel in front of the refrigerator to clean up any spills that may occur while pulling the drip pan out from under the appliance.
    4. Slide the drip pan forward until is free of the Maytag refrigerator.
    5. Empty the drip pan in the sink.
    6. Replace it with a new one,
    7. Then you reverse the process to reassemble it back together,
    8. Plug it back to the power outlet.
    Hope this helped. All the best Elect_Comp
    Sep 21, 2011 | Maytag MZD2766GES Side by Side...
    Trying to get drippan out from bottom of refrigerator,will not just slide out. Don't want to damage drip pan. Two brackets holding pan in place.
    Hello.
    On newer refrigerators the drip pan is no longer removable as it was on older ones but it is instead a entire molded peice that is part of the base frame and not removable
    Aug 17, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
    I have an odor coming from my Whirlpool side-by-side refrigerator. I have cleaned it top to bottom, inside and out. The odor seems to be coming into the refrigerator through the fan. There is black...
    It is the water that is emanating the odor. If you look at the back you will find a drain for this drip pan. If you cant find any then you may like to use a self made mop kind of a thing. A thin stick with some cloth tied to one end. Push it into the opening where you located to water from and dip it into the water and pull the stick and squeeze the water down. You will have to do it a number of times depending on the quantity of water in the pan. Then use a dry cloth the dry up the pan. This should remove the odor. Alternatively you can use a long rubber hose to siphon out the water. BUT, this is not a cure. To cure you may want to call a service personnel.
    Sep 17, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
    Refrigerators Logo
    451 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
