Question about Philips DCM230/37 iPod Docking Executive 30 Watt Micro Audio System Shelf System
No sound is coming from the speakers or the headphone jacks in any mode
2 Suggested Answers
  • 6771 Answers
SOURCE: no sound comes out of the system/speakers on my FW-C255/37
There is a problem with the headphone jack or there is a audio output problem, get some electronic contact cleaner attach straw and spray inside the jack, push the headphone jack in and out quickly and spray again and repeat, this should clean the contact points, if no sound, audio output should be suspect.
Posted on May 11, 2012
I have an Integra DTR 20.3. Recently, I have been getting no sound from the speakers after removing the headphones from the headphone jack. Any ideas?
Usually the headphone jack has a contact that's "made" by the 'ring' section of the jack when you push in the plug, which bypasses the speaker circuit (that's what automatically silences the speakers when you plug in the headphones when there are no switches to turn the speakers on/off manually)... if the 'ring' strip got bent somehow so it's pressing against that contact all the time, it won't let the speakers' circuit come out of bypass. Look inside the jack with a flashlight... the sideways Vs that touch the 'ring' sections of the stereo headphone plug should be about in the middle of the opening... if they're pushed over too far it may require disassembly to bend them back to the proper position.
Mar 08, 2015 | Integra Dtr-20.3 THX Select2 Plus AV...
Broken headphone jack, no sound threw laptop speakers
change the entire jack you will get it for 200 bucks by breaking the jack you shorted out the speakers
Apr 05, 2014 | Toshiba Satellite A105-S4074 Notebook
My headphone jack does not work, sound still comes out from the speaker when i plug head phone. please what should i do?
it shows that the headphone may gone bad, or the jack of your pc needs repair, check your headphone to some other computer if it ok then go for repair the jack from some qualified technician
Jan 11, 2013 | Computers & Internet
No sound comes out of the system/speakers on my FW-C255/37
May 10, 2012 | Philips FWC255 CD Shelf System
When I disconnected my Headphones from my LG tv the headphone jack came right out with it.. and now it is stuck in wired headset mode and no sound will come out of it, any solutions or tips?
Usually there is a nut on the back that hold it in place. If you can solider replace the jack. There are three contacts on the jack, one is ground, one is audio and the other is the speaker. If you know your way around tyou can jump the audio and speaker wire together and sound that way.
Tom Miller
Sep 08, 2011 | LG 32LE5300 Widescreen 32 in. HDTV
Sound
Except for the Headphone jack (mini-jack) and the coax audio, all of the audio jacks are audio IN. Which jack do you have your speakers connected to? The headphone jack is on the side next to the coax connection (ANT) and the coax audio out is at the bottom of that set of side jacks. The headphone mode should automatically cut the TV speakers. The coax audio out is set up by pressing Menu and then using the down arrow to highlight Audio. Then press the right arrow button to enter the submenu. Press the up or down arrow to reach SPDIF. Then you use the left and right menus to select PCM, Digital Dolby or OFF.
I hope this helps.
Jul 10, 2010 | Element ELC-HS321 32 in. LCD TV
When I plug in my headphone sound still comes from my laptop speakers.
when I plug in my headphone sound still comes from my laptop speakers.
Jan 13, 2010 | Compaq Presario 700 470024-192 Notebook
Can 2.1 pc speakers work thru headphone jacks?
No it's not possible to have a sound. Because the HDMI and the Headphone (3.5mm jack) are on two different technologies.
The monitor does not have a way to convert the sound from HDMI to Headphone.
There could be a converter that might convert the sound signal from HDMI to headphone (but I'm not sure).
Aug 30, 2009 | Logitech X-540 Computer Speakers
Sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Mar 01, 2009 | Dell Latitude D410 Notebook
No sound
See if it works with the headphone jack instead of speakers.
If the sound is intermittant on the headphone jack too then the headphone jack is broken causing the speakers not to work. You could probably find a place to solder the jack.
If it works fine on headphones then either the speakers are bad or the amplifier on the mainboard has failed.
Dec 24, 2007 | Samsung X05 Notebook
Philips DCM230/37 iPod Docking Executive 30 Watt Micro Audio System Shelf System Logo
35 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
