Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Washer is not spinning during final spin cycle. can smell rubber smell while not spinning. how do i get to area to replace belt?
    Master:
    Sergeant:
  • 385 Answers
Take off the front panel.
Posted on May 19, 2011
I have a 2012 top loading frigidaire gallery washer. It recently started making a loud thumping noise during the wash cycle. When it spins out it smells like burnt rubber. Any ideas? Thanks
There is a rubber belt between the motor and the rotating cylinder.
If it is frayed, then part of the belt is hitting something during the "wash" cycle, and rubbing much faster during the "spin" cycle.
Replace the belt.
Aug 27, 2015 | Frigidaire Washing Machines
Burnt rubber smell during spin cycle
Assuming it's a top loader, the coupling between the motor and the tub is failing. If this is an older machine, the cost of replacement may not be within reason. The cabinet has to be removed and additional disassembly is required to replace the coupling
May 15, 2013 | Roper RTW4300SQ Top Load Washer
Smokes on final spin
door gasket. pain to replace. clean stainless steel drum where it contacts rubber before installing a new one. I used baby oil and very fine steel wool.
Dec 12, 2011 | General Electric WCVH6800J Front Load...
Maytag Performa clothes washer. Model LAT2500AAE. Made screeching sounds during spin cycle also burned rubber smell. Turned off. Removed and replaced belts. One belt was shot. Ran a test run and still...
Check to see if your water pump is spinning. It could be seized up and the burning smell could be the belt spinning on the seized pulley. Good luck Friend.
Oct 10, 2017 | Maytag Washing Machines
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Burning rubber smell
Even though manufacturers' love to advertise it, I personally would not load "too many items", as it may cause excessive normal ware and tear on your machine parts, motor, belt, etc.
Yes; the smell can be the belt and possibly your motor as well. The motor may be spinning, but the weight may be too much when the belt is engaging to rotate the drum. I would be careful not to burn the motor (About $120 - part only)
You should be able to access and inspect the drive-belt in the rear of the machine by removing an access panel (back of washer).
To replace the belt if fairly simple. Remove and re-install by wedging a long screw driver in between the belt and metal pulley (circular), while simultaneously rotating the pulley.
You may be required to make a belt repair if you start to have problems with your "washer not spinning" or "making a noise/not spinning"
Jan 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Sep 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer smoke during spin cycle...
could be belts slipping or a bad motor going - what's it smell like - burning rubber or an electrical smell?
Aug 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
334 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
