Here are some steps you can follow to set a static wireless IP address for your Brother HL-2170 printer:
Press the "Menu" button on the printer's control panel.
Use the arrow keys to navigate to the "Network" option and press "OK".
Select "WLAN" and press "OK".
Select "Configure Network" and press "OK".
Select "Manual Setup" and press "OK".
Select "IP Address" and press "OK".
Use the numeric keypad to enter the desired IP address for your printer. Make sure to use a unique IP address that is not already in use on your network.
Press "OK" to save the changes.
Press the "Back" button until you return to the main menu.
Turn the printer off and on again to apply the new settings.
After following these steps, your printer should have a static IP address that will not change. You may need to update the settings on your computer or other devices to use the new IP address in order to print.
Most printers can be stopped by going to your control panel and selecting printer and then find the command that cancels the printing job. Try this teaching video: https://www.youtube.com/watch?v=YXIM_17IIl0
Right click with mouse on the print icon in bottom right of pc ,select cancel print in list, then go to printers in control panel and clear all print jobs in your printer list.
This error occurs when your printer is dealing with a particually complicated print job and cannot process it all. Try to reduce the complexity of your document or cut the print resolution. It may be worth trying to print the document in several parts if at all possible.
If you tried to print something that is still pending and you need to get it out of the print queue follow these instructions:
On the lower right side of your computer screen near the clock area - look for the printer icon (picture of your printer) Right click with your mouse on top of the picture of the printer and choose "properties" from the drop down list. Click on the name of the document that you wish to cancel and click file and click on cancel document. You can also click on the name of the document you want to cancel and then right click on it again and choose cancel from the drop down list.
You may need to choose cancel all documents to get rid of any which are pending.
1. Open Cover. 2. Press the Clear key to display drum status. 3. Press 1 (hold) on the telephone keypad. 4. When the display shows "ACCEPTED", close the front cover. PRESTO!
You have the wrong drivers or corrupt drivers on your system.Disconnect your printer and restart.uninstall your printer and download new drivers and reinstall.all should be fine
