Question about Kenmore Ovens
Stove stuck on lock how do I unlock - Kenmore Ovens
  • 8,197 Answers
May I get the make and model # to help you more
Posted on May 19, 2011
Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
May 11, 2014 | GE Ovens
Oven is locked how do i unlock it
UNPLUG THE STOVE.Take the cover off the back of the stove.
On the left rear (facing the back of the range) find the timer motor. It may have stopped. You may be able to free it with a bit of WD40. If not, unplug and insulate the wiring to the timer motor and the microswitch on top of it ( 4 wires). Take the long steel wire off of it and unlatch the oven door.
This probably has something to do with the timer motor on the self cleaning cycle and it is stuck.
Do NOT use the self cleaning function unless you fix the timer motor.
Feb 20, 2011 | Whirlpool Ovens
We used the self cleaning option and now we cannot get the oven door open. The lever is stuck in lock mode. Can you give suggestion?
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock.
IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature)
Thank you and thanks for using fixya
Sep 29, 2010 | Jenn-Air JGW8130A Electric Single Oven
We self cleaned and the 2 days ago and the door is still locked. Help
The lock is operated by a solenoid and may have stuck due to friction or goo around the magnet core. Try bumping the stove or lifting it 2 inches in front and dropping to the floor. 2 inches will not break anything. There may be a mechanical timer in the self-cleaning circuit... is your gas stove still plugged in and showing signs of power such as ability to ignite top burners electrically? If the timer has failed the door lock solenoid is still activated and there could be a slight hum. Try unplugging the range and see if the door can be opened. The thermal interlock should be free to let the lock retract. If that works replace the timer motor. If solid state (no timer motor) replace circuit board with timer relay.
Dec 12, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
How do you unlock the stove. I was trying to clean the stove so i pushed clean then lock light came on .I pressed the arrow button and it locked but now won't unlock please help
here is a link that could probably help you its differrent model but the mecanism is the same.Kindly click the link below to find out:
http://applianceguru.com/forum1/611.html
If you find my answer helpful,please vote.Cheers and God Bless
Nov 09, 2009 | Ovens
I have an older frigidaire self cleaning stove and i cannot get it to unlock for some reason it is stuck on lock mode the knob is wore out so it is a little hard to see where i need to get it
have you tried to unplug the stove and see if when you plug it back in it will allow you to unlock the door? you may have a door lock solenoid burnt out on it as well, in which case you will need to replace the door lock mechanism.
Oct 24, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
After self cleaning cycle, oven door will not open. the lever won't move.
in the rear of the stove there might be a wax motor that has melted not allowing the stove to be unlocked. or a stuck switch.
all too common with self clean ranges.
unplug stove, remove rear panel and begon looking for any type of heat damage, or any switches that may have been stuck closed.
i see this at least once per week
Oct 09, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
How do you unlock a whirlpool stove if it locks manual
I think you mean if it locks automatically not "manual". There should be small print next to one of the buttons that includes the word "lock". Hold this button down until the indicator goes out.
Aug 08, 2009 | Whirlpool RBS245PDS Electric Single Oven
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Unlock my stove
On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam. If it is a built-in over, sometimes bending a coat hangar into a hook and sliding from the right side into the lock you can unlock the door.
May 24, 2008 | Ovens
Ovens Logo
59 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
