I have a visco TV and I cannot get it off of channel 1. The remote does not work so I bought a universal remote but it still won't work. I tried to codes for NEC and Polariod as suggested by others, with no luck. It will work to watch dvds, but I want to hook it up to the cable box and need to get the tv to channel 3. It used to work, but not it won't go past channel 1. Thanks.
  • youngqsue May 24, 2011
    I bought it new. It used to work fine, but I moved, the cable guy had it working when he did the install. My husband disconnected it to hook up a bigger tv on that box (I have a separate box, no dvr, for this tv) and now I can't get it to go anywhere but channel 1. I tried the channel buttons, changing the input from cable to air, the channel scan, etc. Nothing seems to work. I tried putting the input as AV1 because when I had comcast that is where it had to be to work. At the new house I have verizon but even so it does not work with anything I have tried. I have probably spent 4 hours messing with it, but I am not tech savvy. Thanks for your help.
  • 30 Answers
There should be channel buttons on the TV itself, try using those. Also, you may want to try changing the input from the Cable Box.
I am curious as to why the remotes don't work. Also, how did it get onto channel one. Did you get the TV used?
Here is a link to the AV Science Forum. It seems other people have challenges with this TV as well.
http://www.avsforum.com/avs-vb/showthread.php?t=745952
Posted on May 19, 2011
Universal remote for RCA tv channel 1
Something missing here. There is no channel 1 on a TV set. None of the universal remote instructions I have or have seen specify that as a first step. From your post, I believe you want to use some kind of universal remote to control an RCA flat panel TV, Can you tell me the brand of universal remote you are trying to use? The answer to the last line of your post is you don't need the original remote to "reprogram". That's what universal remotes do
Jan 04, 2013 | RCA Televison & Video
TV won't work on universal remote control
Brand name and Model number to your TV?
Dec 28, 2012 | Televison & Video
0093 change's channels won't turn tv off or on
Normally, universal remote controls buttons might not work properly to what it meant to be. It is a common fault to most of the universal remote controls. Just see, Original is always Original, and Universal is always so. Just try to setup the remote control by using an other setup code for your device. Choose the code, which will give you.
maximum functionality. That is all.
Jul 24, 2012 | One For All URC-3021 Remote Control
I have a VISCO 32' tv & lost the remote. Model # VSC-32V1. I need a remote to use to get to the HDMI area. I tried a universal but it only turns it on & does channel.
Check the operation manual and note down the model number and go and fetch it from any electronics shop nearby. These are available freely now in the market.
Jul 19, 2012 | Televison & Video
Why won't any universal remotes work with my LG tv?
The two possible reasons are:
1. None of the codes are correct for this model.
2. The remote infrared receiver in the set is bad.
(maybe the reason the other person got rid of the set?)
There are some ways around this depending on how you hook up and what you have for signal:
If a box (cable or sat) is connected to one of the sets of audio/video jacks on the set--switch to that input and change channels etc with the box!
Use the box remote for functions like channel and sound etc.
May 01, 2012 | LG 26LG30 26 in. LCD TV
I bought a Radio Shack universal remote. It does not list Element codes. I've done the suggestions but it doesn't work. What are Element's codes??
hello!
"Element" codes could be: Polaroid, MAG, LG, Vizio.
Have you tried "code search" mode on universal remote? If you won't find the luck of those "brands" I suggested, do "code search". Refer to remote's owners manual. I did the same for myself: obtained RCA convertor box, without remote, RCA codes won't work, RCA is out of TV business. By using "code search" I made it work. Then, you may want to do "code retrieval" option, to know the correct code.
good luck,
Alex.
Feb 16, 2012 | Televison & Video
While moving my parent's Curtis Mathes Cm19001 TV produced in 1999, I touched the channel button which took the TV off of channel 3. We've tried to use the channel buttons to return to channel 3,...
I have one of this tv model too.Just used a RCA component cables like Y,R,W hook one side to the tv Video IN INPUT holes and the VCR the other end of the cable to VCR Video OUT INPUT holes.Now just pushes a channel manual button up or down a couples for the tv go into VIDEO Mode.Play the dvd player it will work.Or try Remotes.com to buy a tv original remote.Return the universal remote.
Jun 18, 2011 | Curtis-Mathis CM19011 TV
Direct tv on universal remote
For this type of problem you will need to call the RCA customer support at this telephone number 1-800-645-4994. Give them the model number of your remote control and ask them for assistance with your problem. Thank you for using FixYa and have a nice day!
Apr 04, 2009 | RCA 3-Device Universal Remote with...
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Jan 13, 2008 | Sanyo DS27510 27" TV
Televison & Video Logo
243 people viewed this question
Top Televison & Video Experts
