Question about Garden
Hi, I was taking apart my weedeater featherlight blower FL1500LE and was not careful and the spring popped out. any suggestions to putting it back?
  • 2,239 Answers
You can wind them back in, hook the anchor end of the spring into the houseing, then start to wind the spring in a coil at a time, keep ypur thumb on the coils already wound in or they will jump out again, if you buy a new spring it eill come in a keeper, all you do is drop it in and push home to release the keeper.
Posted on May 20, 2011
My fl1500le blower starts in full choke but dies as soon as i move it to half choke
Check the following, and then clean or replace:
  • Fuel Filter - Located INSIDE the fuel tank
  • Spark Plug
  • Spark Arrestor - at Muffler
  • Carburetor - May need a rebuild kit
Also watch this...
and this one as well...
Dec 10, 2013 | Weedeater 2 Speed Gas Blower FL1500LE ()
I have a featherlight FL20 and after running for a few minutes it cuts out. I believe it might be the fuel filter. How do I clean it?
remove it from the tank with some needle nose pliers,, and check the filter for built up grime, also,, check the plug for fouling,, it may be getting flooded as you run it,, clean the air filter too
Jun 10, 2011 | Weedeater 2 Speed Gas Blower FL1500LE ()
Need to know how to replace string on weedeater gas blower FL1500LE
The Weedeater FL1500LE is a 23cc 2-Stroke Gas Blower and does not use string. It only uses air.
Mar 31, 2011 | Weedeater 2 Speed Gas Blower FL1500LE ()
Start coil wont re-wind
The spring inside has broken or come loose. You can order a new one at the manufacturers web site, plus diagrams and instructions on how to replace it.
Feb 23, 2011 | Weedeater 2 Speed Gas Blower FL1500LE ()
Replaced starter spring on Poulan/weed eater FL1500LE leaf blowe.
you may have wound the spring backwards, try winding the othe way.
May 09, 2010 | Garden
How to repair spring starter on FL1500LE
The casing is situated so the spring faces the starting spool. The spool is plastic and the rope is wound around it. The hook goes to the spool. Put it back together carefully! Good luck...Lee
Nov 24, 2009 | Poulan Featherlite Gas Blower, with Low...
How to get the spring & starter rope back together on a weedeater featherlight leaf blower. model #FL1500LE
easiest is to take a slotted screwdriver, poke into the underside air intake and rotate the wheel a bit...usually the rope goes right back in...if not take the three screws out and release the rope.....while your there give it a few twists to loosen it up....you will do this soon enough when the rope breaks :)
GG
Nov 05, 2009 | Poulan Featherlite Gas Blower, with Low...
MY ROPE WONT GO BACK IN?? HOW DO I SOLVE THIS PROBLEM..THANK YOU IN ADVANCEITS ON A WEEDEATER FL1500LE
well, either the screws that hold the plastic on (thats hooked up to the rope) are loose, or the spring in the recoil is wedged, missing, or dislodged. Might want to take off the recoil and check for any missing parts, wedged in or dislodged. if none of these is the case, try asking a person at your local hardware store, (home depot, westlake, strausser, harbor-freight, Lowe's)
Jul 10, 2009 | Poulan Featherlite Gas Blower, with Low...
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
