Question about Troy Bilt 5.5hp Self Propelled Mower
6.75 h.p. troybuilt mower runs but surges I removed and cleaned the carb. there is no fuel filter that i can see
SOURCE: Hello. My John Deere mower has started surging at
I have a john deere 420 rider. It would surge at a higher speed. It is a hydrostatic and there were 2 bolts on the transmission that were loose. now it runs beautifully smooth,
Posted on May 04, 2009
  • 32 Answers
SOURCE: Mower idles rough and stalls at times. Also blows
look by the carboreter and there is a little screw with a spring. turn the screw a half turn and try to start it, then try another half turn, and keep expirementing.
Posted on Jun 13, 2009
  • 109 Answers
SOURCE: Cub Cadet 2165 engine surges and eventually stalls
If this is a Kohler engine, the surging is probably from the engine starving for fuel. Try replacing the fuel pump.
Posted on Jun 29, 2009
  • 15 Answers
SOURCE: 1996 GMC Sierra 1500 XC 4x4 5.7 Hard To Start
It is probably the fuel pump. If I remember the number correctly, this fuel system needs about 50 lbs to open a valve.
Until this valve opens, no fuel gets to the fuel nozzels.
Posted on Apr 30, 2010
SOURCE: Craftsman 16.5hp 42 in. Mower runs for about
I am having a problem with my lawn tractor similar to what you describe. Mine runs fine for 15 to 20 minutes and then stalls. It will start back up and run for a few minutes and then stall again. When it stalls it is like when you get off of the seat with the blades engaged. I have replaced the gas and fuel filter and have cleaned the carb and air cleaner with no effect on this problem. I am now thinking that the problem is the fuel stoper located at the bottom of the carb. There is a plunger screwed into the bottom of the carb bowl that is held down when the key is turned on. If you get off of the seat when the engine is running and the brake is not on or the blades are engaged the stoper is pushed up into the main jet fuel path causing the engine to stall. I am going to fabricate a heat shield around this plunger to see if this corrects the problem.
Posted on Jun 25, 2010
Lawn Mower Surges
Check valves. Vacuum from the engine draws the fuel in...sounds like vacuum is surging. Also it may have a "fuel pump" that may be bad
Aug 24, 2016 | Briggs & Stratton Garden
John deere lt190
If fuel is getting into the oil, I would say the needle and seat or float in carb is not stopping fuel flow. I would check carb again and adjust float level. Change or install an inline fuel filter too. Surging is almost always carb related. If problem persists after checking carb again, check governor springs. If they have been bent at all after removing carb, they can be bad. If you replace new governor springs and surging still exists, try doing a static setting on carb/governor. If your unit has an oil/centrifugal governor, move governor arm in the direction that opens throttle valve in carb all the way, hold in place, loosen nut on governor arm and grab small tang that goes inside engine and turn in the same direction you moved governor arm, rotate this until it stops, hold in place and tighten nut on bottom of governor arm. This is called a static/factory setting. Make sure throttle cable is in high position when doing this. Let me know if you have any questions. Good luck!
Oct 22, 2013 | Garden
Engine surging
Drain the gas replace fuel filter then see if that helps if not clean the whole carburator should stop it.
Jul 29, 2017 | Tecumseh Lawn Boy Push Mowers Insight...
Have a 4.0 quattro Briggs and Stratton lawn mower. Starts up great and doesn't stall out. Has this annoying surge and slow down of motor. Removed gas from tank and sprayed some gum remover in tank and...
it does sound like a carb issue it may need to be rebuilt also check your fuel line and if you have a fuel filter check the filter clean the gov. assembly with carb cleaner
Jul 30, 2012 | Garden
My Briggs and Stratton 300 148 cc lawn mower surges up and down while running. Seems to run best when almost out fuel
You most likely have a partially clogged carb (main jet) and it isn't allowing enough fuel for the engine to run smoothly. This is fairly common. The carb needs to come off, get disassembled, and cleaned paying close attention to the small opening in the main jet.
May 19, 2012 | Yard Machines 158cc Push Lawn Mower #11a...
My 13.5 ho b&s surges heavily but smoothed out when blade/ deck is engaged or when I apply choke. I've twice cleaned carbs and still now working. I ran in garage with no air filter to elimina
hello sir, mower will not start or run,runs only when primming, does it have good spark,good compression,or only runs on full choke, are you getting fuel to the engine if not try this,your fuel pump or your carb. is clogged up here is what you can do for a simple repair for the carb,you can remove the air filter and assy, empty fuel tank and clean out tank and line,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bow, and fresh gas,you should be good to go,hope this helps.,thank you.~~
Feb 19, 2012 | Mtd Garden
Briggs & stratton 550 / surges, gas hog
check your air filter. If it's clogged, the engine will spool up to keep from dying, run for about 15 seconds, then it will happen again. If that's it, just clean the air filter. Solved my problem
Jul 26, 2010 | Briggs & Stratton Garden
My troybuilt lawn moer. won't start. changed fuel filter, plugs,fuel pump. fuel mkes it to the bowl on the bottem of the carb. engine will run if i put fuel though carb.v twin clylinder engine. Briggs
You didn't list what engine you have. Depends on what motor and carb, but you'll have to remove the bowl. If your bowl is round with a special brass hex bolt holding it on , then be sure the passage in the bolt is open fully. Next the passage it screws into must be clear. In anycase you will probably have to remove the carb and clean every passage throughly.
Jul 26, 2010 | Troy Garden
09 JD X 340 27hp Kawasaki eng\ surges
Hi
That is a fuel problem caused by stale gas you will need to remove and clean the carb with carb cleaner.
Sam
Jan 07, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Briggs and Stratton lawn mower engine Model 10H902. Surges up and down but runs and is usable. Uses lots of gas.
surging is most likely starving for fuel try to clean carb with spray and replace all the filters ? you may need to get carb rebuilt?
Aug 29, 2009 | Garden
Troy Bilt 5.5hp Self Propelled Mower Logo
64 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
