Question about Refrigerators
My fridge wont cool? is it the motherboard? is it the condenser? please help...thanks in advance. Hank
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on May 20, 2011
Guanaquito you suggested I spray with water my 690 subzero condenser or with degreser . It won't do the demage to anything if I use water .Thank you . Vacume is not helping but everything else is working...
You can use a chemical degreaser on the condenser, just be sure to unplug the unit and put paper towels down around it to absorb the grease and cleaner, and let it air out well before plugging it back in and turning it on. Water wont help anything if its grease buildup. if your fridge is not cooling, it's most likely some other problem though. it's very rare that a dirty condenser causes cooling issues on a 690 Good Luck!
Oct 25, 2013 | Sub-Zero 690 Side by Side Refrigerator
My proline fridge freezer not cooling
I have the same problem with a proline plc 190w fridge freezer not cooling in the fridge compartment please help it's my mums and she can't afford a new one , thanks in advance
May 19, 2012 | Refrigerators
Hi, I have a Samsung Refrigirator SRS618DP, and both the fridge and freezer are not cooling. There is power to both sections. Could someone help me out here please. Thanks in advance
heatman101
Apr 24, 2011 | Refrigerators
My Fridge is running Hot on the freezer side and the temperature is rising. Ice cream is melting etc. Fridge side seems OK but also not really cold. Which of the the settings on the internal dials 1 to 9...
It sounds like the condenser is dirty. It's under the refrigerator.
This is easy to do. Just get all the dust out of the condenser and things should start cooling down.
I hope this helps. Please leave feedback.
Thank You.
Aug 24, 2010 | GE Profile PSW26P Stainless Steel Side by...
Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Nov 20, 2008 | Kenmore 64802 Top Freezer Refrigerator
Does not stop cooling down
Door edges being warm is caused by what is called mullion heaters that operate to prevent humidity from condensing at these points.
Some refrigerators have an energy saver switch. Turn this switch if you have one to the energy saving position when the humidity is low. Is anything freezing in the refrigerator? If so setting the controls to a little higher setting may solve your problem.
May 03, 2008 | GE Profile¿ Arctica® Energy...
I am using windows xp
Is you network card built onto the motherboard?
If Yes. Try going to http://www.nvidia.com/Download/index.aspx?lang=en-us and under option 2 to selecet motherboards and follow the steps.
Apr 07, 2008 | Computers & Internet
SRL551DP, fridge stops, display on door flashing.
You most likely have a problem in the freezing/cooling circuit. Check your condenser, evaporator fans to see if they are running okay. Most likely it may be the condenser fan.
Dec 17, 2007 | Samsung CoolTech Plus / Basic Bottom Mount...
Not cooling after smoke damage
Assuming that the motor is running, my best guess would be that the condenser (a large grid of thin piping) was covered in soot, and should be THOUROUGHLY cleaned, preferably with compressed air.... The condenser will either be underneath the unit, behind a small panel in the front bottom of the unit, or at the back behind a cover at the bottom of the fridge which runs the whoile width. Make sure the fan at the back near the compressor is also running....if the condenser fan is not running when the compressor is running, it won't cool. If the condenser is excessively dirty, it won't cool!
Jun 26, 2007 | Frigidaire PLHS269ZC Side by Side...
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
