Question about Sony DUALSHOCK3 Wireless Controller PS398052
My dualshock 3 controller wont charge when i plug it in it doesnt do anything until i hit the PS button. then it will work fine but doesnt charge. i tried resetting it but it doesnt work. when it it plugged in and on and i hit the PS button there is an x by the charging status bar.
  • 22 Answers
First, try hitting the reset button on the back on your controller - it's located just to the right of the screw located just above the label describing the FCC information about the controller. The button can be pushed with a paperclip, toothpick, or pen. If this is unsuccessful, then try plugging your controller into a USB port on your home computer or laptop. Other than that, I would recommend trying to return your controller, it may have been constructed wrong and the warranty should cover it. Good luck!
more information:
http://www.ehow.com/how_5510542_reset-ps-controller.html
Posted on May 20, 2011
If i press the ps button on dualshock 3 controller all four lights on it are supposed to flash but it doesn't therefore the ps3 system cannot be turned on using it
Have you charged it? If you have plugged it in and no lights blink you may have a defective controller. If so check with Sony support/
Oct 05, 2012 | Sony Ps3 Sixaxis Wireless Dual Shock...
I have a ps3 dualshock 3 controller that wont connect. i have taken it apart to check and see if anything was wrong with the inside, but i saw nothing. When i put it back together, i tried pressing the ps...
Welcome to Fixya. Heres how you can connect your controller to your PS3.
1. Press the tiny Reset Button on the back of the controller
2. Plug in the USB Connection wire
3. Restart Console
4. When loaded, Press the PS Button
5. Disconnect the USB wire
Then it should have recognised the controller and auto-assigned, hope this works for you
Rate me if it works so that i can help other people like you!
Thanks for using Fixya
Feb 13, 2011 | Sony Dual Shock 3 Controller for...
My ps3 dualshock controllers won't turn on. Even when I try hit the ps button nothing happens. Itried the rest button but that didn't work. The ps3 itself works fine I just can't play it without the...
ok number 1 try a friends controller with your ps3 if that works then get a dart or pin and press in the reset button on the controller while having it connected to the ps3 at the same time and then that should work
Jan 30, 2011 | Video Game Consoles & Games
When I press the ps button on my dualshock 3 controller for the ps3 two lights come on over the 1 and 2 labels and it won't respond. What is the problem? It used to work fine.
Hi, I dont have a ps3 myself, but sometimes when I play at my friend's house, this happens when u got more than 4 controllers on, like the ones from gh/rockband.
Press and hold the ps button, it should get u to the screen where u can chose to turn off the system, turn off the controller or change the controller number, just put it in number 1 to 4, and should work fine.
Nov 01, 2009 | Sony Dual Shock 3 Controller for...
All lights on Dualshock 3 blink 5 times, then do nothing.
On the back of you dualshock pad next to the L2 button there is a tiny small hole witch looks like it could be a screw hole ! well this is the reset button once you have pushed this you will be able to conect your pad to your usb cable and it work on your console again
Aug 30, 2009 | Sony Dual Shock 3 Controller for...
PS3 Controller will only work when plugged into the USB
I picked up the folling troubleshooting tips from the PlayStation Knowledge Center. I know it may seem silly or insulting; This is not my intention. Problems like this are usually just little things you're over-looking. Give thest tips a shot, one by one, and see if your solution is in here. If it isn't, message me back here & we'll try something else to get your controller working, ok? By the way... Is it a sixaxis controller or dualshock?
  • Verify if the SIXAXIS or DUALSHOCK 3 wireless controller works with the USB cable.
  • Verify that the SIXAXIS or DUALSHOCK 3 wireless controller's battery is charged.
  • Attempt to pair the SIXAXIS or DUALSHOCK 3 wireless controller to another PLAYSTATION 3 system. This helps determine whether the problem is with the system or the controller.
  • Attempt to connect another SIXAXIS or DUALSHOCK 3 wireless controller to the PLAYSTATION 3.
  • Move closer to the PLAYSTATION 3 system. The maximum range for Bluetooth is 30 feet.
  • Make sure you have less than seven Bluetooth peripherals paired with the PLAYSTATION 3.
  • Unplug any other USB device plugged into the system when pairing the SIXAXIS or DUALSHOCK 3 wireless controller.
May 19, 2009 | Sony Playstation 3 (PS3) Console
PS3 Dualshock Does not Charge.
hi i had this problem my controller would not charge although my head set would useing the same usb cable .i brought a new controller and tried two usb leads it was no different .this is the silly bit go and buy a new genuine ps3 usb cable and and i promise you all your problems will be solved .i have no idea y the cables stop working with only the conroller but they do i hope this helps all you people pulling your hair out trust me this will work
May 10, 2009 | Sony Dual Shock 3 Controller for...
Dualshock 3 sixaxis why does it always need to be plugged in
Once the controller is plugged in and connected to the console, hold down the PS button to select "turn off the system." Once the system has completed shutting down, unplug the controller and press the PS button. The console should turn on. If so, the controller will connect wirelessly. Unfortunately you'll have to do this with each controller but it works every time.
Feb 19, 2009 | Sony Dual Shock 3 Controller for...
Sony DUALSHOCK3 Wireless Controller PS398052 Logo
444 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
