Question about ASUS RT-N13U Wireless Router - 300 Mbps 1 x 10/100Base-TX Network WAN, 4 x 10/100Base-TX Network LAN... (RTN13UUS11PUSB1) Print Server
Why is there a delay in loading websites when using an ethernet connection to my router??
  • 367 Answers
There will always be some kind of delay, though it shouldn't be real noticeable as your requests get routed. You may have a bad network cable that is dropping packets. Make sure you are not running your network cable along side power cords for more then a couple feet. This can really mess up data transfer and speed.
There are updates for the firmware to your router. Make sure you are running the latest. http://www.asus.com/Networks/WiFi_Networking/RTN13U/#download
Don't forget to backup your settings before updating the firmware.
Cheers Chris
Posted on May 19, 2011
How to connect pc to thinkland
Make sure your firewall is not blocking your ability to go to websites. I saw this the other day, somehow the users firewall was set to block all internet traffic out of the computer.
Disconnect ALL cables from the modem and routericon1.png: internet cable, power, (and ethernet). You can leave the computers on, but if this doesn't work , try it with the computers off.
Connect the modem, cableicon1.png, ethernet, and power. modem .
Connect power on router, Wait until router has a connection
then connect ethernet from modem,
then one by one connect the computer ethernet lines to the router.
Feb 07, 2014 | Computers & Internet
Plug magicjack usb
If you have a magic jack + your best to connect via Ethernet , the reason for this is because you don`t have the delay a computer imposes. the reason your device dos not work on your routers usb port is the port dos not have the driver software or the operating program magic jack uses to interface with a computer and there is no way to to load it up on your router.
It will not work for you, the usb connection is for comunity access to a had drive on your network only ,,,as far as i know.
Oct 12, 2013 | TP-LINK Computers & Internet
Ethernet conection dosen't work
More than one computer or just one? Sounds like something wrong with the computer lan port.
Jan 10, 2013 | Computers & Internet
ASUS M5A78LM LX ethernet problem
To diagnose your network connection, please click on this link and follow my instructions.
http://www.fixya.com/support/r4229966-network_diagnostic_procedures
Dec 29, 2011 | ASUS M5A78LM LX Motherboard...
Hello. I bought this modem with wi fi ,dsl router. How to set it to use this modem as a router.I want to connect my pc with lan cord & use wifi connection with my laptop and phones.
Turn DSL-router off.
Turn Actiontec off.
Turn computer off.
Connect:
* telephone-port in wall <--- 4-pin telephone wire --> DSL router
* Ethernet port on DSL-router <-- Ethernet cable --> WAN port on router
* One of the LAN ports on router <-- Ethernet cable --> network-port on your computer.
Turn DSL-router on, and wait for it to fully load, i.e., pattern of lamps becomes repeatable.
Turn Actiontec on, and wait for it to fully load, i.e., pattern of lamps becomes repeatable.
Turn computer on, and boot it.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: Default Gateway....192.168.123.456
Start Internet Explorer
Type http://192.168.123.456 (or whatever numbers you saw)
Login to your router
Configure the wireless adapter inside the router
(enter an SSID, choose 'WPA' encryption, enter a password)
Disconnect the Ethernet cable from your computer
Click "View Available Wireless Networks",
and select the SSID that you provided.
Enter the password that you provided.
Oct 21, 2010 | Actiontec GT701WG Router (actiongt701wg)
Netgear WGR614 router with USB Cable Modem
When working with routers, CAT-5 cables are the more usual cable used. Your modem's Ethernet Port --- connect it via cable to the router's WAN input. Connect one of the router's LAN outputs to your computer's LAN input with another CAT-5 cable. Go through the appropriate Router Setup by putting http://192.168.1.1 into your Internet Explorer, with ' admin ' for User Name, and no password (just press Enter in Password frame). Once you are in to the router setup, you can select your Network Name (SSID) and then implement whatever Security you might want to use. You should be up and running by now, nhave lots of fun!
Dec 18, 2009 | NetGear WGR614 Wireless Router
Xbox can't find network on PC.
the other persons tip is trash mines better ;)
you can go to your routers2_bing.gif website and enter it manually. Type 192.168.1.1 this might be it or try 192.168.2.1 or 192.168.1.100
when it shows your routers2_bing.gif info write it down and then put it in your xbox's network by entering it manually. btw the secondary DNS is just 0.0.0.0 if it doesn't give you two. the gateway2_bing.gif is just your routers ip address.
what else you can do is do port forwarding.
But the xbox is not a static ip address2_bing.gif so it'll change. what you can do is when it says to put your ip address in your xbox put all the numbers the same as the routers ip address BUT DON'T USE THE SAME LAST NUMBER! so like if your routers ip address is 192.168.1.1 you can use 192.168.1.23 i use 192.168.2.15 but you may not have the 2 in yours.
http://portforward.com/english/applications/port_forwarding/XboxLive360/XboxLive360index.htm
a website that'll help
http://support.microsoft.com/kb/908874
list of ports you have to open
any other ?'s email me at mbish1993@yahoo.com
Nov 19, 2009 | Computers & Internet
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Router not being recongized
if your running windows xp then you should remove any programs that you installed to run router then look into hardware manager and uninstall router and restart computer . then try once again plug in router once comp boots and let win xp load the correct drivers if this doesnt work go to windows update website and get all available updates including all hardware updated then try installing again good luck with it
Jul 13, 2008 | D-Link AirPlus DI-524 Wireless Router
COD4
Are you playing online? If so how fast is your internet connection. If you are using dial-up, then yes, there is a HUGE time delay and the only way to fix it is to get a faster connection, i.e. DSL or Cable broadband.
-Using a wireless router will also cause timing delays, especially if you have high encryption enabled. I always use a wired connection for gaming with a CAT6 ethernet cable. Good luck.
Mar 15, 2008 | Sony Playstation 3 (PS3) Console
ASUS RT-N13U Wireless Router - 300 Mbps 1 x 10/100Base-TX Network WAN, 4 x 10/100Base-TX Network LAN... (RTN13UUS11PUSB1) Print Server Logo
359 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
