Question about Canon PowerShot A520 Digital Camera
The shutter doesn't close completely therefore none of the actions of camera works.
    Master:
  • Canon Master
  • 443 Answers
I sergest you take it to a camera place neer youn to get it serviced
Posted on Dec 25, 2011
Now what?
Nothing is going on. Your camera is working as designed.
Most cameras have an upper limit on the shutter speed when used with flash. This is called the flash sync speed. At speeds higher than this the shutter is never opened completely, and as a result you would get only a narrow slit of a picture.
Usually this is not a problem since the exposure is determined almost exclusively by the flash and the aperture. Any action is caught and stopped by the brief flash, not the shutter. The primary reason for controlling the shutter speed is to use a slow speed to allow the background to expose.
Your camera may have a special high-speed flash mode that fires off multiple flashes coordinated with the shutter movement. Since you didn\'t say what model Canon camera you\'re using, I can only suggest you check the manual.
Apr 26, 2013 | Canon Speedlite 430EX TTL Flash
Our camera seems to be okay but when i'm attempting to get picture, i can't see any image in LCD, is it the lens?
First try pressing the DISP or DISPLAY button on the back of your camera. If that doesn't help, try taking a picture with the screen black. Is the picture also black? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 13, 2011 | Sony Cyber-shot DSC-S750 Digital Camera
URGENT! I have a canon powershot g12 and the display is totally black. I can't see any image. When I shoot a picture and download it to the notebook, all pictures are black! Playing...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 22, 2011 | Cameras
Hi! I've just bought a Lomo LC-A on ebay, and it seems that the shutter doesn't work properly. It opens and closes, it doesn't get stuck, but there's only one click, even when I put it in...
It's got ONE speed - 1/100. It's designed to use ISO100 speed, outdoors in daylight, or with flash, using sunny 16 exposre. These are incredibly basic machines similar to Holgas and Diana's. 1 or 2 f/stop choices, 1 shutter speed, maybe a flash connection.
Jul 07, 2011 | Lomo LC-A 35mm SLR Camera
What settings would I use taking low light action pictures
In general, taking action pictures is all about getting as much light in the camera as possible. In lieu of light, you can increase the camera's sensitivity to the light. This is called your ISO sensitivity and the higher the ISO, the more sensitive to light your camera is, and therefore they allow you to shoot with a faster shutter speed. The faster your shutter speed, the clearer your action pictures will be. In general, try a shutter speed of at least 1/250. Be warned: The higher your ISO, the more grainy your pictures may be, and if you have a consumer-end camera (point-and-shoot, or 4/3rds SLR) any higher than ISO 800 will most likely destroy the quality of your photos. If possible at all, try adding more light.
Hope this helped.
Chuck
May 06, 2011 | Cameras
Assistance in using the P for taking pictures How do you use the dials to determine a good picture.
The settings depend on what you're trying to say with the picture. You probably wouldn't want the same settings for a portrait as you would for a landscape. Two photographers at the same place and time with identical cameras probably wouldn't use the same settings, as each photographer has his/her personal style.
In the Program mode the camera select the shutter speed and aperture it deems optimal. You can turn the command dial to adjust the exposure, increasing the shutter speed and opening up the aperture, or decreasing the shutter speed and closing down the aperture by turning it the other way. Either way, the exposure itself remains the same.
If you're taking a landscape picture, you'd probably want a small aperture to get the maximum depth of field. If you're taking a portrait, you'd probably want a large aperture to blur the background. If you're taking an action picture, you'd probably want a fast shutter speed to capture the action. Of course, those are just guidelines. Sometimes you want to blur the action, or throw some portion of the picture out of focus. It's up to you. You use the settings to take YOUR picture.
Oct 24, 2010 | Nikon D90 Digital Camera with 18-105mm...
Lines on screen and photos, too bright photos outside
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
Aug 07, 2009 | Fuji FinePix V10 Digital Camera
Canon PowerShot A520 Digital Camera Logo
18 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
