Question about Fisher Price Private Connection Monitor With Dual Receivers
My monitor keeps beeping no reception no matter where I put it or what channel it i on
Sony 910 baby monitor makes loud beeping when turned on
The picture you posted looks like it has the channel setting option. Notice at the bottom there are three little holes that are (as I recall) either red, yellow or green. You have to set the channel on both the transmitter in the baby's room, and in the receiver you keep with you, so that they have the same pattern of colored dots in those holes. When they have the same pattern, they're on the same radio channel. If you can hear a neighbor's monitor, pick a different color pattern to change channels. As long as both units have the same pattern, you should hear the baby, not the beeping.
Aug 09, 2014 | Sony Ntm-910 Baby Monitor
The monitor keeps beeping no matter how close are you to the base
The wireless link is not working, check to make sure both the transmitter and receiver are set at the same frequency, other than that a technician will need to go deeper into the matter to see if it can be resolved.
Mar 02, 2012 | Baby Care
Monitor and base are plugged in but the monitor continues to beep. We have tried to change channels but it still beeps. Please advise.
I realize this original post is old, but just incase someone is looking for solutions, I will put what worked for me. I have the T4841, and had the same problem. No matter how close or how charged the battery, it kept beeping saying out of range even though it was only a week old. I got it to work by pushing the reset buttons on the monitor and receiver at the same time. The reset button on the receiver is on the back (tiny hole with black button - a pen tip fits nicely). The reset on the monitor is on the left side just about halfway up - right below the light button. Hope this helps!
Jun 27, 2011 | Fisher Price Dual Private Connection...
Walkie talkies model gmr325-2 ic;513C-UT914 HOW DO I GET THESE TO TRANSMIT, MY HUSBAND HAS CANCER AND WE NEED THEM IN OUR BEDROOMS AND WHEN I AM OUTSIDE, TK U, TK U
In order to get the most out of your new radio, read this reference guide completely before attempting to operate the radio.
Turning the Radio On and Adjusting the Volume
1) Press and hold the key to turn the radio ON.
2) To change the volume level press the volume/monitor up or down key to increase or decrease the volume level.
3) Press and hold the key to turn the radio OFF.
Adjusting the Sound (Key Beeps)
Your radio emits a beep each time one of the keys (except for the PTT button and call key) is pressed.
The sound of the Key Beep will increase or decrease depending on the volume level setting.
To turn OFF this beep:
Press and hold the call key while turning ON the radio.
To turn ON this beep:
Turn the radio OFF and ON again.
Choosing a Channel
Your GMR325-2 radio has 22 channels you can use to talk to others. In order to speak to someone,
each of you must be set to the same channel.
To choose a channel:
Press the channel/scan up or down key to increase or decrease the channel number displayed.
Channel Scan Feature
Your GMR325-2 radio has a channel Scan feature that allows you to easily Scan all 22 channels. When an active channel is detected, the unit will pause on that channel until the channel is clear. Then after a 2 second delay, the unit will continue scanning.
Pressing PTT button while the Scan is paused on a channel will allow you to transmit on that channel.
To turn ON channel scanning:
Press and hold either the channel/scan up or down key. The channel number on the display
will rapidly cycle through the channels.
To turn OFF channel scanning:
Press either the channel/scan up or down key.
Talking on Your Radio
To talk to others using the radio:
1) Press and hold the PTT button and speak in a clear, normal voice about 2-3 inches away from the microphone.
While you are transmitting the tx icon is displayed. To avoid cutting off the first part of your transmission, pause slightly after pressing the PTT button before you start talking.
2) When you are finished speaking, release the PTT button.You can now receive incoming calls. While receiving, the rx icon is displayed.
Transmitting a Call Alert Tone
Your GMR325-2 radio is equipped with a call tone that will be transmitted when the call key is pressed.
To transmit the call alert tone, press the call key.
The tone will automatically be transmitted for a fixed length of time.
Auto Squelch Feature
The GMR325-2 is equipped with an automatic squelch system which shuts off weak transmissions
and unwanted noise due to terrain conditions or if you have reached your range limit.
Monitor Mode Feature
Your GMR325-2 radio allows you to listen for weak signals on the current channel at the press of a key.
To turn ON monitor mode:
Press and hold the volume/monitor up or down key. The rx icon will blink.
To turn OFF monitor mode:
Press the volume/monitor up or down key. The rx icon will stop blinking.
Automatic Power Save Feature
Your GMR325-2 has a unique circuit designed to dramatically extend the life of the batteries. If there is neither transmission nor an incoming call within 2 seconds, your radio switches to the Power Save mode. The radio is still able to receive transmissions in this mode.
KEYLOCK ON/OFF
Press and hold the call key until the "L" appears. After 1 second, the LCD will return to the channel display.
To exit Keylock on mode, press and hold call again.
Note: While in keylock on mode, it will still receive transmissions.
ROGER BEEP
Roger Beep is a BEEP that is sent to notify the end of transmission.
Roger Beep can be heard through the speaker when Key Beep is on.
Roger Beep is transmitted even if key beep is turned off. However Roger Beep will not be heard from the speaker.
To turn OFF Roger Beep: Press and hold the channel/scan up Key while turning on the radio.
Jun 21, 2011 | Motorola Walkie Talkies 2-Way Radio
Static only
If you have static, more than likely you dont have the monitor on or plugged in. Also, make sure the the channels are set equally on the monitor and receiver, either on channel 1 or 2.
Try not to place the monitor or receiver near tv's, microwaves, radio's, etc. this may interrupt reception.
Hope this is helpful!
Feb 26, 2011 | Safety 1st Baby Monitor
Why does the monitor continuously beep? It has a
May 16, 2010 | Fisher Price Long Distance 900mhz Baby...
TV doesn't receive signal
Faulty Video boards If you bought it in May then rapidly get it fixed under warranty or exchange it for a better brand. Who is Hannspree? not well known and may be cheap Korean TV with no parts available
Please rate our help to keep FREE service online++++Thanks for using FIXYA
Sep 12, 2009 | Hannspree HT09 28 in. LCD TV
It gives an excellent reception but only for a while
There is a problem with the tuner section. I would first suspect poor solder connections. If resoldering the ground connections on the tuner fails to resolve the problem, a replacement can be purchased for $38.40 using part number: 8-598-594-30
Dan
Jan 05, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
Fisher Price Private Connection Monitor With Dual Receivers Logo
112 people viewed this question
Top Fisher Price Baby Gear Experts
Lyle Siemens
Lyle Siemens
Jennifer Rock
Jennifer Rock
Are you a Fisher Price Baby Gear Expert? Answer questions, earn points and help others
