Question about Brother IntelliFAX 4100 Laser Fax
Poor quality of copies
We have recently changed the toner cartridge. Using a new brother toner cartridge specifically for this machine. Can't find the manual. The copies are of very poor quality and light. Does the drum need to be replaced? Is there a message that will come up when this needs to occur? If so, no message has been displayed as of yet.
  • 328 Answers
If it is a real genuine Brother toner. Not a reman. You may also need to change the drum. If you have a user manual, it will show you where the drum life setting is in the menu structure. Make sure the little glass window inside on the right is clean so it can read the toner level. Make sure the toner save feature is turned off.
Posted on Aug 18, 2008
How do I prevent excess toner from spilling out of cartridge and affecting copies?
If you 'replaced' or refitted the original cartridge, then I would suggest that the toner cartridge has failed. If this is the case, please try a new one.
If the original has not done a fair (check manufacturers specification) number of prints, you may be able to ask for a replacement.
If this was a new cartridge, and printer uses separate drums and toner cartridges. Then it could be a faulty drum. Above replacement path could be tried.
Aug 01, 2015 | Sharp AL-1631 Laser Toner Cartridges
Tip
Getting Full Yield in Brother Printers - Preventing Early Supply Failures
Brother laser printers, fax machines and multifunctions all use a toner reclaim system. That means the used or left over toner (along with paper dust and debri) is recycled into the new toner cartridge supply. There is no waste section for the leftover toner and debri. This design is efficient however their are some short falls that you need to address. The toner cartridge supply is slowly contaminated with debri and dust that will send the cartridge down prematurely if your not using a good quality paper.
In addition, Brother Drum Units (ie DR-400, DR-500, DR-510, etc...) are expensive and suffer from the same premature failure problems. There is a charging brush and transfer roller inside the front top inside of the drum that drags on the drum surface to charge and discharge it properly for toner transfer. If you use poor quality the built up paper dust and debri interferes with this system and ultimately prevents it from working prperly. Here's a photo of a newer drum that failed due to the use of poor paper. Note the paper dust embedded in the transfer roller (top), caught up in the charge brush (center) and actually laying on the drum (bottom).
Here's a closeup of the charge brush so you can see the problem better below.
Below is the damage that bad paper caused. This DR-520 drum pictured is rated for 25,000 pages but due to low quality paper lasted just over 7,000. This was caused by a "Store Brand" paper.
Here below is a photo of the inside of a brother toner cartridge contaminated with paper dust and debri due to la ow quality super store brand paper. Note all the white paper dust in the toner.
To get the full yield from your Brother supplies, simply use GOOD QUALITY PAPER. STAY AWAY FROM STORE BRAND PAPERS as they go out on low price bid rather than to meet a tight quality standard. I would recommend a HP Brand paper as it's an "ALWAYS KNOWN GOOD" paper. The cheapest on the HP branded papers is HP Office and it works well.
Hope this has helped you understand the importance of using good quality paper in your brother machines. If you found this helpful, please rate it with a FIXYA as significant time and effort was used to help you.
Thanks and Happy Printing
on Mar 31, 2009 | Brother HL 5250DN Laser Printer
Tip
Get the most from Brother Drums and Toner - Stop Early Failures
on Aug 30, 2008 | Brother FAX-8360P Plain Paper Laser
I just changed the toner and the printer does not print.
If u have the CD of tht printer , u just delet tht printer from the Devices and printers settings. And re installed it
Aug 14, 2012 | Brother HL-2040 Laser Printer
BROTHER DCP7055 PRINTER SHOWS REPLACE TONER EROR
When replacing the toner cartridge, you MUST install a brand new, unused genuine Brother toner cartridge in order to reset the toner status. Swapping toner cartridges from one machine to another or installing a partially used toner cartridge may cause this problem. Brother machines control their image quality for the most suitable print quality by monitoring toner consumption. If you install a partially used toner cartridge, your Brother machine is unable to recognize toner consumption correctly which will cause this problem. Therefore, when you replace the toner cartridge, please use a brand new toner cartridge, not a partially used toner cartridge from another machine.
Jul 26, 2012 | Brother Office Equipment & Supplies
I have a Brother Laser Printer HL-5350DN. I refill toner myself but the toner light will not go out. How do I reset it so it goes off?
There is a reset gear in the cartridge that needs to be "reset" or replaced. I've included a link to a PDF file that goes over the procedure to properly refill and reset the toner cartridge. This is a document that is used by a company that does a complete rebuild, so you probably won't need most of the information, just the part on resetting the reset gear.
http://www.uninetimaging.com/downloads/technical/TecArtWebAdded/Brother_HL_5300_Series_tn650_Reman_Eng.pdf
Apr 05, 2011 | Brother HL5350DN Laser Printer
Poor copy quality - smudgy copies - changed toner - still the same.
check your OPC drum life, if you have a poor quality with a new cartridge installed (light copy, dirty copy) the opc drum must be replaced, check you machine counter if you have reach 100k copies you need to replace the drum, if you are using a new OPC DRUM, you need to clean the machine, you have to call for service because there is many parts that muat removed to clean properly.
Dec 27, 2010 | Canon NP 7130 Black and White Copier
Poor copy quality
there are 3 reason if the copy gray & less sharp:
1) the toner you are using is not compatible very well with the cartridge unit if you changed other compatible toner.
2) the cartridge going near the life-cycle, (also cause print blurred)
3) the photo drum going near the life-cycle
you may try to change the quality toner (original factory). or
change the cartridge if it is out of the life-cycle
Jan 09, 2009 | Dell 1600n All-In-One Laser Printer
Intellifax 4100 grinding noice
Probably caused by the toner cart. Only use genuine new Brother brand supplies. Remans fail quite often with Brother machines.
Possibly bad gears on fuser drive. But with the poor print quality, I suspect it is the toner.
May 02, 2008 | Brother IntelliFAX 4100 Laser Fax
Poor quality fax to fax, copy great, computor fax great.
beware of generic toner!
you may need to change out your drum unit
the drum unit may have been contaminated by the staples toner.
also clean laser window under drum cartridge.
Mar 17, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
167 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
