Question about Home
Push button switch will turn on whirlpool but not off Only way to turn off is ar breaker panel I How is this switch removed Can it be removed from top
    Genius:
  • 1,015 Answers
Without more information it's hard to answer your question for sure.On most all units I have worked on you have to access swith from the bottom where it is held in place by a retaing nut. You will need to get to the underside so you can reconnect wires when you replace switch. Thank you
Posted on May 19, 2011
Replaced the control board in my whirlpool dishwasher model# WDT790SLYM1 and the push panel lights up but when I push the start button all lights go out and the dishwasher will not start.
Hello, We're sorry to hear about your Dishwasher. We recommend disconnecting power from the breaker for at least a minute and then turning the breaker back on to do a master reset on the Dishwasher. If you are in need of help after trying the reset, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 14, 2017 | Whirlpool Dishwashers
My on off button quit working on my bath jacuzzi. I can go out to the garage and trip the breaker to turn it off and on. I used to be able to barely push it and it would come on or go off, now you can...
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
Oct 25, 2013 | Jacuzzi Whirlpool Bath Tub Real EG85-969...
Our 7788F keeps going into a ground fault condition. Need help troubleshooting. John
Ground Fault ???
Troubleshooting Ground Fault
Troubleshooting a ground fault circuit interrupt, or GFI, breaker is pretty straightforward. Troubleshooting the circuit itself can be quite time-consuming.
The GFI breaker is designed with a test button incorporated into the breaker itself.
Pushing the test button should trip the breaker.
On GFI-style breakers the neutral wire going into the house's outlets is connected to the breaker's neutral connector, the white neutral that comes out of the breaker is connected to the neutral bus in the panel, isolating the neutral bus from the neutral wire going into the house.
The test button actually shorts the neutral wire feeding the circuit to the neutral bus in the electrical panel creating a ground fault that should trip the breaker.
It is considered a ground fault because the neutral bus in the main electrical panel is actually connected to the ground bus through the panel's metal casing. What to do if the test button isn't tripping the breaker
Push the test button on the GFI breaker.
The breaker should trip.
If the breaker does not trip, then it may be that the breaker has already tripped and just looks like it's on.
The position of the switch may only move slightly from the on position towards the off position when tripped.
Push the switch on the GFI breaker all of the way toward the off position.
It may take some force to get the breaker to reset.
Turn the breaker back to the on position.
When the breaker has been reset properly you should feel some resistance when pushing the switch back on.
3 Push the test button again and the breaker should trip.
If the breaker still doesn't trip then you should test for power at the screw connections inside of the electrical panel.
Remove the screw that holds the dead front covering the breaker's connections.
Remove the dead front cover.
Test for power with your voltmeter set on AC volts on the highest scale.
For a single pole GFI breaker, touch the black lead from the tester to the silver screw on the GFI breaker and touch the red lead from the tester to the brass screw on the GFI breaker.
You should see 110 volts on the tester. If voltage is seen but the test button won't trip the breaker, then the breaker is bad and should be replaced.
5
Test for power on a two pole breaker by touching the red voltmeter lead to one of screws with a black or red wire connected to it.
Touch the black lead to the other screw with a black or red wire connected to it.
You should read 220 volts or close to it on your voltmeter.
If you read voltage and the test button won't trip, the breaker is bad and needs to be replaced.
What to do if the breaker won't reset and keeps tripping when turned on
6
Unplug everything that is plugged into any of the outlets on the circuit in question.
Try resetting the breaker again by pushing the switch all the way to the off position and then turning it back to the on position.
If it won't reset and trips when the breaker's switch hits the on position, it could be a bad breaker or a problem in the circuit itself.
7
Use your straight-tipped screwdriver to loosen the brass connection screw or screws on the GFI breaker.
Pull the black hot wire, or wires, out of the breaker's connectors.
Loosen the silver screw the white wire is connected to and remove it from the GFI breaker.
8
Push the switch all the way to the off position.
Turn the switch back to the on position.
If the breaker still won't reset, then the problem is the breaker itself and it should be replaced with a new one of the same size, brand and model.
If the breaker resets normally and the test button trips the breaker when pushed, the problem is in the circuit itself and an electrician should be called to find your ground fault.
9
Reconnect the black wire, or wires, to the brass screws on the GFI breaker.
Reconnect the white wire to the silver screw on the GFI breaker.
10
Replace the dead front cover into the breaker panel.
Install the screw or screws that hold the dead front in place.
http://www.hilo-electric.com/blank?pageid=63
Aug 14, 2013 | Computers & Internet
I haven't used the tub in a while and now when I push the jet button nothing happens. No noise, nothing. Fuse breakers are all fine.
Hi, Dayne here,
If your tub has an air switch, it could be the push button, but more likely the air switch. Disconnect the tubing from the button and give it a light puff of air. If it turns on the pump. it is the button. If not, listen and veiw the air switch as you give it a light puff again. If the switch contactors close, the switch is probably good, and it unfortunately may be the pump. Remove and have it tested after looking for a reset or manual over ride by the air switch.
Thank you.
Dec 12, 2010 | American Standard Home
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
My dryer won't turn on when I push the button. I've set the regular setting and the lint trap is empty... not sure what's wrong?
This could be the thermal fuse, or the door switch. Most likely the thermal fuse. With the dryer unplugged remove the back cover. The thermal fuse is located just above the vent outlet. Its attached with 1 screw and has 2 wires plugged into it. Use a multi meter and check the fuse for resistance. If its open (no reading in ohms) replace it with (check link below). If that is OK then check the door switch, you will have to pop the top of the dryer up to access the switch connector. Of course before doing anything check your fuse or breaker panel for a tripped breaker or blown fuse.
http://www.appliancepartspros.com/part_details.aspx?part_id=3132867
http://www.appliancepartspros.com/part_details.aspx?part_id=2976041
Nov 21, 2009 | Whirlpool LER4634J Electric Dryer
My American Standard Whirlpool does not turn on. I push the Power button and don't hear anything. Circuit breaker is on, anyone have any ideas? Thanks!
Remove access panel make sure pump is plugged in some electricians put a GFI outlet under tub for motor make sure GFI did not trip. Next the switch is an air switch look for the hose going to switch is connected last you may need a new air switch which is common to fail
Nov 03, 2009 | American Standard 2770.018w.020 Cadet...
Dryer will not turn on
Normal 0 Hi, UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
Please let me know if this help or if I can assist you further.
Thanks
Vic
May 30, 2009 | Dryers
I just finished cleaning my swimming pool and tried to switch on the water pump but nothing happened.Then i noticed that the red trip light on the control panel was on. What do i have to do to fix this?
hi! there,
open the control panel,besure to close circuit breaker first,on control panel there is a over load protection relay,push the reset lever,then close the control panel,switch on the breaker and push the black push button to start the pump,observed if trip off again,check the cathridge filter,replace filter because the differential pressure
was exceeded the set up on pressure switch.have a nice day,don't forget to rate me,thank's
Apr 23, 2009 | Home
Home Logo
41 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
