Question about Durabrand DPX3290L Player
Sound, but no picture. Could not identify LCD display. I was told to contact the service center for lens cleaning information.
  • 1 more comment
  • annhorne May 19, 2011
    I place the DVD disk on the machine, press play, the sound comes on, but the picture
    does not. This has happened before, but has corrected itself. Now it appears to
    be permanent.
    Tell me what to try, please.
    I have received NO advice so far. Please give me a suggestion for something to try to get the picture on the DVD player to play.
    Thank you.
  • Durabrand Master
  • 11,800 Answers
If you get sound then the lens from the optical; reading head works perfectly fine: the disk is read correctly, the data from it extracted and decoded correctly but only the sound is present.
The fault is in the video circuits: either the screen (in the data cable that connects it to the processor or the backlighting) or in the processor itself.
To find out which you must do 2 tests:
1 - play a dvd, get a powerful flashlight and point it straight at the screen: if you can see the image then the backlighting has failed and will have to be replaced - $100 for parts and labor at a repair shop. If not then the screen is not active so a second test is needed.
2 - dismantle the case of the player (both the lid with the screen and the bottom with the unit) and remove and verify the data cable that connects the optical unit to the screen; if it's broken it will have to be replaced ($15 for a new cable, from a repair shop); if it's not broken and even after reconnecting it properly the image is missing then the video section of the procesor has failed. In that case the player is dead, since it will be cheaper to buy a new one than to replace the board of this one.
Posted on May 19, 2011
    Top Expert:
  • Durabrand Master
  • 75,404 Answers
Hello
Will you please give me some more details of the fault of your Duraband TV. Give me as much as details as you can; so that I can get into a conclusion and place a solution before you. OK.
  • The Knight
    The Knight May 19, 2011
    As far as sound is there, everything at the inside circuit of your Duraband DVD player is Ok. The fault lies with dither the display control or display itsef. This set is very difficult to service, as there are so many tine internal connections, and must need some special tools to disassemble and reassemble it. Actually saying, this is not a user repairable item. In many cases the strip wire that comes inside the main chasis to the display panel found damaged. If the strip wire has got breaked and happend to vet in touch in between it same connections, there is a chance for display card also get damaged. Anyway, get it repaire by some expeienced service personal, if you are not sufficant exprience and sound knoledge in electronics. Ok
No picture, no sound display though back light lamps are ON.
Contact the authorized service center for Sony. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 16, 2015 | Sony Bravia V-Series KDL-52V4100 LCD TV
Hi i'm trying to identify the model of my McCulloch chain saw. Number on the bottom 600016F 15-017314. Can someone help please?
I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Jan 04, 2012 | McCulloch Garden
Samsung 46" LCD HDTV - have sound, but no picture.
I am a samsung service center. Please give me part number.
Feb 18, 2011 | Samsung LN-S4692D 46 in. LCD HDTV
Someone sat on my es-55 samsung camera, when i put it on an ink blot picture appears on the screen, this might be the lcd screen , the lens is okay as it still slides out.How do i fix it?
Hi
Does the 'ink blot' appear on any pictures you are taking or just on the Samsung ES55 LCD screen?
If it just appears on the LCD screen it's probably been damaged when it was sat on, and the only option would be to replace the LCD screen by contacting a Samsung service agent in your region.
If the 'ink-blot' image is appearing on the pictures you are taking then check the lens is clean - be careful not to extert to much pressure on the lens when it is retracted.
if the lens seems clean, as a last suggestion change memory card, or totally reformat the card that is in the camera - if the card has become corrupt the images may not be displaying correctly.
I hope one of these few suggestions sorts your problem.
Regards
David
Jan 17, 2011 | Samsung Cameras
My Nikon D60 won't let me take any pictures on Automatic setting and all pictures on manual are coming out black. I notice on the digital display there is an F that is flashing? Not sure what I have done...
i`m afraid your lens electrical component is not working properl,
try to change with antoher lens and shoot
do not forget to clean the connector plate on your camera and rear side of the lens using dry-clean cloth
if the problem`s still exist, i suggest you to contact your local camera service center
Dec 21, 2010 | Nikon D60 Digital Camera
Image looks fine on LCD screen before snapping pictures and then has streaks or over exposed on the final picture
your problem is lens shutter maybe broken or stuck up. If you notice once you take picture and check to the display it was fine but try to zoom to the maximum you will found out that there's a line in you image.the only way to solve your problem is bring to service center and ask for cleaning the lens shutter.
Jun 03, 2010 | Kodak EASYSHARE Z1285 Digital Camera
Water in LCD, sound but no picture
This unit is having a problem in the main board. This is the television control board. The video television tuner is not working correctly. Have you tried other signal input sources to see if they are working, like dvd or vcr. If they are then the problem is in the tuner section only. If the other inputs are also not functioning , then it a problem with the video circuits failing.This is a problem that need to tested and serviced in a service center. The service center will have all the correct service information to evauluate the problem and repair it for you. The customer support telephone number for Insignia is. 1-877-467-4289. They also have a costumer support section on their website, which is . www.insignia-products.com. You can also contact Best Buy customer support at this telephone number 1-888-237--8289. Give any one of these support centers the brand name of you television and the model number. Ask them to evaluate the problem and where you can take it for testing and service. I hope this information helps you with your problem.
May 26, 2009 | Insignia IS-LCDTV32 32 in. Television
Nikon D80 error msg "F--" and "r02"
Remove the lens, clean the contacts, reattach the lens, and jiggle the lens to seat the contacts. If that doesn't fix it, either the camera or the lens may require service.
Feb 19, 2009 | Nikon D80 Digital Camera with 18-135mm...
Sony Handicam
dear kwilsey,
just turn on your camera and look at the front side of camera.i.e just note tat your lens shutter is opened. if lens shutter is opened then prob is with your ccd devices. Contact the nearest authorised service centers.
Sep 05, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Spot appears in pictures and LCD display.
That's a good bet, I think the service centers will do this as an
"annual internal cleaning" although I don't know what they will charge. Taking apart the optics is challanging and risky.
Jul 01, 2008 | Fuji FinePix F20 Digital Camera
Durabrand DPX3290L Player Logo
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
