Question about Plantronics CS70 Wireless Headset
Have new headset, why is the base unit keep beeping at me
    Prodigy:
    An expert who has answered 500 questions.
  • 537 Answers
Here is an explanation of the beeps you are hearing:
• One beep every 10 seconds is caused by a low battery
warning. Recharge battery by returning it to the base charge
cradle for one to three hours until charge light stays lit or
quits blinking.
• Two beeps is an out of range warning. Move closer to the base.
• Three rapid beeps every 30 seconds indicates your mute is
on. Press the mute button once to turn mute off.
• When an optional lifter is connected, three repetitive beeps
indicate a call is coming into the headset. Press the call
control button on the headset to answer the call.
Plantronics CS70 User's Guide
Good luck from Headsets Direct!
Posted on Nov 10, 2011
I have a constant beeping on my jabra headset gn 9350
headset not syn'd with base, replace headset in base and remove power from base
count to 10 re-power base allow set up to complete, green lights across base and blue battery light on ear piece, allow to charge if less than two green lights on base.
if this still does not work slide ear piece apart count to 3 and silde back together again replace in base and allow to light up again, it will now work
Jul 18, 2014 | Jabra GN9350e Wireless Headset
I can't get the blue light to come on top of the base. The red lught keeps flashing and the amber light is lit. Plantronics 500a headset
The Plantronics 500A is the base for the 510S system, the headset may need to be re-paired to the base unit to make sure that it has a strong link or connection. Here are the links below for the pairing instructions, and also the user guide.
http://www.headsetsdirect.com/pdf/Voyager%20510S%20Bluetooth%20Headset%20System%20pairing.pdf
http://www.headsetsdirect.com/pdf/510_print_en.pdf
Good luck from Headsets Direct - 800-914-7996.
Aug 23, 2011 | Plantronics Voyager 500A Deskphone Adapter...
The headset does not come on
CS70 headset does not come on:
If the CS70 base has lights, to show that it is getting electrical power, you may need to re-pair the headset to the base unit (the headset will usually just beep when you press the button). Here is the link for subscription or how to re-pair the headset and base.
http://www.headsetsdirect.com/plantronics-cs70n-subscription-pairing-instructions
If the headset doesn't beep or anything when the button is pressed, and the base has lights, it could be that the internal battery has worn out and the headset needs to be replaced. The CS70 is an older model that has been discontinued for a few years, however you can get the CS70N replacement headset which will work on your base.
http://www.headsetsdirect.com/72910-01-cs70n-headset.html
Aug 07, 2011 | Plantronics CS70 Wireless Headset
While the headset works frequently, it will suddenly stop. Nothing I do will allow it to connect again. I hear nothing through the headset after the initial beep that indicates headset mode was enabled. ...
It sounds like the battery is no longer holding a good charge. There is no replacement battery for this headset. If you are using the original 510 headset you can replace it or pair a different bluetooth headset up to the 500A base. Just keep in mind if you decide on a different style of headset you will not be able to charge it in your base. I have included the link for the 510 replacement headset below.
Plantronics Voyager 510 Replacement Headset
Jul 14, 2011 | Plantronics Voyager 500A Deskphone Adapter...
My plantronics CS50 USB headset won't subscribe to the base, it just keeps giving 3 short beeps when the call button is pressed. Numerous attempts at resubscription and resetting have not had any...
I know this is an old post but I just want to share what I confirmed through Plantations. Hopefully it will help someone in the same situation. Sometimes, people buy replacements headsets and it should be noted the CS55 Headset does not pair with the CS50 base. While they headset looks identical, the only way to tell which headset you have is to open the battery cover and look under the battery. If you have a CS55 headset and a CS50 base, they will not pair.
Jun 24, 2011 | Plantronics CS50-USB Headset
The headset will not charge from the base unit
It maybe that you need a new charger for your base. If your base is messed up there is no replacement for that. I know you can purchase other product for the base but not the base itself.
Here is a link to the Plantronics 510S Headset.
Mar 14, 2011 | Plantronics Voyager 500A Deskphone Adapter...
It wont keep the charge. I make two call and starts beeping
Hello And Welcome to FixYa!
It seems like the battery inside the unit had gone weak, that's why it didn't keep charged. I would suggest you to replace the battery with a new genuine one and then check... This is definitely solve the trouble you are facing.
Best of Luck,
Concerned,
Waqar.
Aug 18, 2010 | Nokia BH-600 Wireless Headset
Phone displays a message saying no link to base when it is closer to the base?
Following may be the cause for getting no link to the base.
1. The handset has lost communication with the base unit.Move closer to the base unit, and try again.
2. Confirm that the base unit’s AC adaptor is plugged in.
3. Raise the base unit antenna.
4The handset’s registration may have been cancelled .Re-register the handset.
To Register, follow the below steps.
Headset: Press MENU and then press ‘0’ ‘0’
Base unit: Press and hold HANDSET LOCATOR until the CHARGE indicator flashes.
(After the CHARGE indicator starts flashing, the rest of the procedure
must be completed within 1 minute.)
Handset: Press OK, and then wait until the handset beeps.
Your handset is registered to Base unit.
Thank You
Aug 18, 2010 | Panasonic KX-TG2620 Cordless Phone
Only bass set going extra hand set not working
This is because the extra handset might have not been registered with the base unit.The headset should be register to use the headset with that base unit.
To register the handset to base unit please follow the instruction:-
On registration the handset is allocated a handset number for use on the new base unit, the handset numbers are 1-5.
1. Press and hold
d65e3ff.jpgon the base unit until 608a95f.jpgstarts flashing. Registration mode will remain active for approximately 3 minutes.
2.Press and hold both
19efd34.jpg together until you hear a long beep.
3.Select the base unit you wish to register by pressing the corresponding number button 1-4.
4. When PIN is displayed, enter the units PIN number (0000 for this model).
5. If the registration is successful the handset will return to standby mode in a few seconds.
Thanx
Jul 22, 2010 | Doro DECT 540 Cordless Phone
Plantronics CS55/HL10 Wireless Office Headset System with Lifter won't lift headset
You may need to re-subscribe the headset.
NOTE: Before re-subscribing the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
To Re-Subscribe:
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
7. If this procedure does not resolve your issue to try a system reset.
Jan 12, 2009 | Plantronics CS55/HL10 Wireless Office...
Plantronics CS70 Wireless Headset Logo
2,322 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
