Question about Kenwood KDC-1032 CD Player
I have a kenwood kdc-1032 and i cant get the sound to play
  • 132 Answers
SOURCE: Kenwood KDC-X590 ipod
Do you have a Ipod shuffle?
Is the deck on random?/shuffle?
Try pressing the small reset button on the deck, its small a small black button you would need a pencil tip to reset!
Hope it helps,
Don
Posted on Jan 02, 2008
tech48
  • 624 Answers
SOURCE: aux location
There is a RCA cable that comes off the back of the radio and also another cable for 3.5mm (mini-stereo jack) that also comes off the back of the radio. The RCA jacks can be used for "AUX" or "Sub-woofer" and the 3.5mm jack is just for "AUX". Your ipod can use the audio output jack or the headphone jack and plug that into the 3.5 mm jack on the back of the radio. You will need a "3.5mm male" to "3.5mm male" stereo cord that can be purchased at Radio Shack or Best Buy. Then you select "AUX" on the display with the source button to listen to it. You may need to go into the menu and activate the "AUX" input. Check your owners manual for details.
Posted on Aug 13, 2008
shagone
  • 34 Answers
SOURCE: Kenwood KDC-MP922
there is a button under the back of the face in one corner, just press around the back of the face with the car on until you feel the button press in and it should open.
If not you may have a bad ribbon cable that is not too expensive to replace.
Posted on Sep 10, 2008
jyackle5
  • 8197 Answers
SOURCE: cant set clock kenwood kdc 2011 s stereo
Here is a manual on how to set the time page 22.
http://inform3.kenwoodusa.com/manuals/KDC3011.pdf
Good Luck
Please Rate FixYa!
Posted on Dec 19, 2008
  • 18 Answers
SOURCE: I can't play my iphone on my kenwood KDC-MP435U
Jennifer, I have the same issue. the problem is that the 2007+ generations of Kenwood receivers are not compatible with the iPhone. You will need to get a 2009+ series in order to use your iPhone with the head unit. I had the same issue with the Kenwood KDC-MP435U in my mustang. I am going to get a newer head unit that supports the iPhone. You cannot do it with the MP435U.
Posted on May 30, 2010
Power no sound
Hi, check your ground wire fir a good solid connnection....and your wiring harness.
Jan 17, 2014 | Kenwood KDC-1032 CD Player
I installed my kenwood kdc 200U in my 83 regal it plays real nice till i start driving then the power cuts off and on what should i do
I got a Kenwood KDC-200U CD player.Wy is it that i cant play my IPOT Silver 6 GB on the IPOT setting but i cane ron it on AUX setting?
Nov 25, 2012 | Car Audio & Video
Where can i get a wire harness for my kenwood kdc 1032/ detach face installing in a 94chev cavalier
You can get this part from strereo install shops, they have tons in stock, usually.
Apr 03, 2011 | Kenwood KDC-1032 CD Player
Will the Kenwood KDC 1032 RCA outputs work with an ipod adapter similar to an aux output? If so, how?
Hi, if you are trying to get your I-pod to play through your car stereo, then you would need to have the RCA inputs, not outputs. If you connect your i-pod to the stereo outputs it won't work because both things are trying to push sound out of their outputs. If you connect the adapter to the stereo's inputs then it would work.
Aug 11, 2009 | Kenwood KDC-1032 CD Player
When i hook up my ipod to my kenwood kdc mp728 i cant figure out how to play it through the radio
it should be in aux try to press source buton and see if that is an option if not an alternative is to hook it up on the back of the cd player in the audio in or aux or aux 2 using a wire adapter from walmart in the car sterio section
Sep 14, 2008 | Kenwood Car Audio & Video
Kenwood head unit CD and AUX sound not working
I fixed the sound problem with tech support from Kenwood. I had the blue wire from the Kenwood which is the antennae turn on wired to the amp turn on for the vehicle (2001 Blazer with Bose factory stereo). This is how I was told to wire it from the installation tech where I purchased the wiring harness. The tuning played fine because the Bose amp turned on when I played the tuner but when I played the cd or aux the amp turned off, thus no sound. The kenwood tech toldd me to wire the blue/white wire to the amp turn on for the vehicle so the amp would be on when ever power to the Kenwood was on. I rewired this way and everything works great now.
Jun 09, 2008 | Kenwood KDC -X815
No sound on cd, (kenwood kdc-x469)
did you try another cd maybe your player needs a little cleaning and is your cd new or older
reason i ask is cause newer cd's have a different format then older cd's from a year ago its getting hard to play new stuff on old stuff
May 06, 2008 | Kenwood eXcelon KDC-X469 CD Player
Kenwood kdc-mp528
it sounds like the laser is bad, here is the part number
X93-2010-00
You can probable buy it from an authorized kenwood service center
Jan 20, 2008 | Kenwood KDC-MP528 CD Player
Kenwood KDC-2011S display blinks
Download the MANUAL here.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=037b5697f7192f25431654464fa26ba6&q=Kenwood+KDC-2011S
Enjoy!
;) Mak
Aug 22, 2007 | Kenwood KDC-2011S CD Player
Car Audio & Video Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
