Question about Epson Stylus Photo R220 InkJet Printer
Ink and paper red lights flashing alternately
  • howard134 May 24, 2011
    No. Although my printer is connected by the USB port as normal ther appears to be no reaction from it to any of the instructions you have given
  • 670 Answers
The problem may be because too many head cleaning cycles were ran and the sponges are now full.
Try downloading the SSC service utility by going to this website, Click here.
On the top part of the page is the download link and then follow the instructions on how to run the software.
Hope this takes care of your problem!
Posted on May 19, 2011
Why the green light is off but the paper and ink red light flashing nonstop
Can not answer without more information. What brand of printer?
Are the paper/ink lights flashing alternately?
If your answers are, "Epson" and "yes, alternately", then the model number will help. Or, google "epson waste ink pad reset" for how to fix.
Aug 07, 2016 | Office Equipment & Supplies
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Two red lights flashing, but i can't figure out what's wrong
According to the documentation for your printer.
Red probsolv.6.3.11.jpg paper and probsolv.6.3.12.jpg ink lights flash alternately Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. If the lights are still on, contact your dealer or Epson as described in Where To Get Help.
Dec 16, 2010 | Epson Stylus C86 InkJet Printer
I replaced the blue catridge and now both red
If the red lights are flashing simultaneously, it means that there is something blocking the printhead from moving. check if all inks are installed properly and the ink carriage cover is closed tight. If both red lights are flashing alternately,it means that the waste ink pad is full and needs to be replaced. This part is not user replaceable so you need to take in the printer for service.
Apr 11, 2010 | Epson Stylus C88 InkJet Photo Printer
R200 both red lights flashing
if both red lights are flashing alternately your printer has been locked this is due to full waste ink pads. you need to have them replaced either at your local service centre or do it yourself then you need a scss reset utility to reset your printer you can get a free one of these on the net
If your lights are flashing continuously look to see if you have any outstanding documents in your print queue and delete them
Mar 30, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I am having trouble changing the cartridge on the printer. The
im so sorry for the inconvineince that your having on this printer but let me help you.
if :
Red paper.jpg paper and red inkout1.jpg ink light flash alternately and green power.jpg power light is off possible problem: Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. If the lights are still on, that means the printer is having a hardware issue if: Green power.jpg power light is off; red paper.jpg paper and inkout1.jpg ink lights flash (quickly) possible problem: The printer may have an internal error. Turn off the printer, wait a few seconds, and turn it on again. If the lights are still flashing , that means the printer is having a hardware issue
Feb 10, 2010 | Epson Stylus C88 InkJet Photo Printer
Alternate flashing red lights on epson stylus photo 900
Flashing alternately? Need reset waste ink. SSc ver 4.3 support this model. Find at indoreset.blogspot.com.
Jun 26, 2009 | Epson Stylus Photo 900 InkJet Printer
Flash feed paper & ink light my epson r1800 printer
Do you mean that the paper light flashes at the same time as the ink light or do they flash alternately (ie: paper on, ink off -> paper off, ink on)?
If so the waste ink pads are full and you need to do the following:
1. Reset the waste ink counter:
Grab the tool linked from the wasteink.co.uk site (see bottom).
2. Redirect your waste ink into an external tank OR replace your waste ink pads.. (external tank is easier).
Instructions for the R1800 are available from this site
If the lights are doing something different, please post again with detailed information about how they flash and I can what else it might mean.
Hope that helps.
Mar 10, 2009 | Epson Stylus Photo R1800 InkJet Printer
Flashing red lights
this means your printer wast pad is full but your printer can be reset let me no and i will send you the info on now to reset your printer
Feb 18, 2009 | Epson Stylus Photo R260 InkJet Printer
Repairing
I have a epson stylus c65 printer. My printer is keep flashing the two red light. The out of paper and the out of ink. what do I have to do to stop the problem. The two red light is keep on flashing alternately
Jan 19, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
648 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
