Question about Frigidaire REMOTE CONTROL BOARD KIT Remote Control
I have the frigidaire faa086p7a5 air conditioner and the remote broke. so i'm considering a universal remote and checked different unversal code lists. i never see frigidaire. perhaps you can tell me the proper universal remote to purchase whereupon the included manual will have the code for my frigidaire, thanks
4 Suggested Answers
  • 230 Answers
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Posted on Jun 30, 2008
  • 251 Answers
SOURCE: MY frigidaire Air Conditioner model
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
Posted on Jun 07, 2011
  • 4736 Answers
SOURCE: The buttons on my air
I'm not sure there is a universal remote available for AC units. There may be, I just have not seen one. However, you can still operate the unit without the remote, if you do the following. I'm assuming you have changed the batteries in the remote and they were installed properly (i.e. Facing the right direction) and it still doesn't work or you lost the remote.
Turn the unit OFF and unplug it for 15 minutes. Once the time has elapsed, plug the unit back in and turn the ON/OFF switch to ON. The unit should have reverted back to the original factory setup settings. Which should now allow you to operate the unit without the remote, because the controls on the unit should now be activated.
I hope this helped you and thanks for choosing FixYa.
Posted on Aug 07, 2011
Hi I need the code for a YORK air conditioner for the K-100E universal a/c remote
If the remote is universal, you should be able to do a code search to find something applicable. If a search through all codes stored in the remote fails, you may have to try a different universal A/C remote.
Dec 09, 2016 | Heating & Cooling
What are the remote codews to program this unversal remote urc-10620
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Oct 01, 2015 | Universal Remote Control Televison & Video
I have a kt-9018e universal a/c remote can you tell me the code for a frigidaire
Thank you for your post, John!
Based off the information you have provided you need the code for a universal air conditioner remote. You may need to speak with manufacturer of the remote for that direct code. Best of luck! -Matt
Aug 10, 2015 | Frigidaire Heating & Cooling
LG air conditioner code for Universal K-218E remote
Your LG air conditioner may use unique codes.
Sep 22, 2014 | LG Heating & Cooling
Syncing universal remote to air conditioner
You will need the codes that came with the general remote to match the Hyundai. Hyundai air conditioners may run the same codes as LG, Sharp , Daewoo so try the codes for those as well if you don't have luck with the Hyundai code
Jul 26, 2013 | Hyundai Heating & Cooling
Need to get a unversal remote one for all to work
These are the setup codes for Symphonic with universal remote control.
0053 0189 0227 0456 0024
Buy one universal remote control, which has one among these setup codes. You can get details about codes, from the code list attached to the remote control. Brand isn't matter.
Apr 27, 2012 | Symphonic ST419E TV
The buttons on my air conditioner quit working. It will still turn on and off. It is now set to fan. Will a universal remote work with it? I don't want to spend $75 on a remote(replacement remote) that...
Aug 07, 2011 | Frigidaire FAM156R1A Wall/Window Air...
What is the code for a Telefunken TV in the ellies universal remote?
Hello
Four digit remote codes for Telifunken TV with Ellies unversal remote are:
1180 1200 1215
1197 1165 1258
1239 1198 1036
1194 1289 1331
1052 1217 1202
1158 1039 1160
1214 1285 1269
1301 1376 1157
1123 1232 1051
ok.
Jul 13, 2011 | Universal Remote Control Remote Control
I need the list of code for my air conditioner control "chunghop" K-2038E, can some vary help me, please. I dont speak english excusen my errors
As I understand it, you are wanting to program a different remote, aka universal remote, to control your air conditioner.
here is a link to the k-2088e model http://www.chunghop.com/pics/shuom_200791115556.jpg
I doubt they changed the code listing,
May 05, 2011 | Heating & Cooling
Televison & Video Logo
35 people viewed this question
Top Frigidaire Televison & Video Experts
Lawrence Oravetz
David Ellis Rhea
Are you a Frigidaire Televison and Video Expert? Answer questions, earn points and help others
