Question about Dell Precision Workstation T5400 Quad Core Intel Xeon Processor E5410 2.33... PC Desktop
Hello, When i start the computer its starts a
Hello, When i start the computer its starts a various patterns of beeps but I can't figure it out what pattern it is with the beep manual, all the fans start and the video card is not sending a signal to the monitor, the 1 and 3 LED on the front cover are on the hole time the computer is on. So the beep patterns go for about 15-20 sec and then the LED remain on but the comp does not boot or do anything else. I have taken out the videocard and put it on again, the memorys as well cleaned them up and the entier comp but it changes nothing. Thanks Andrew
    Scholar:
  • 161 Answers
Oh geez, you have some work ahead of you.
I would somehow acquire another video card (ask a friend :)). Put that in and see if your computer boots up. If that still doesn't work its either the CPU, or the Motherboard.
I would take apart the heatsink, remove the CPU, reseat it and see if it works.
Let me know! ill help
Posted on May 19, 2011
Slow start up and beeps a couple of times
The beep pattern tells you what is wrong. Search Google for the exact pattern...ie 2 short beeps, 2 long beeps, etc. Could be bad RAM chip or bad motherboard or video card, etc. The beep pattern will tell you what needs to be fixed.
Mar 25, 2014 | HP Compaq Presario R4000 Notebook
My HP pavilion will turn on but not start up
Have you tried connecting your PC to another monitor? I'm not seeing the monitor getting any signal. Also, is the computer making any clear internal beeping patterns? Like 2 quick beeps or long beeps etc?
Jul 29, 2013 | Computers & Internet
Hp compaq d530 make five beep and red light. ichange ram but no result. i change powersuply but sam beep
Diagnosing problems with your computer can be difficult, especially if you do not have any visual cues to guide you.
Fortunately, computer makers, like Hewlett Packard, make the job easier by using beep codes that computer owners can use to determine the source of the problem.
By carefully listening to these beeps, computer owners can find the malfunctioning piece of hardware and resolve the issue.
Look for the user guide that came with your computer.
Having the user guide available will make it easier to track the meaning of the beep codes.
Most HP user guides have a section covering the various beeping patterns and what each one means.
Start your computer and carefully listen to the beeping.
HP computers use both long and short beeps, so listen carefully to determine whether each beep is short or long.
Shut down your computer and restart it.
Listen again to the beep codes to be sure which pattern you are hearing.
Write down the beep pattern and compare it to the beeping patterns listed in your HP user guide.
Restart your computer again and look for any messages on the screen.
Depending on the nature of your problem you might see visual clues, or the screen might remain blank.
Check the status of the LED lights on the front of your HP computer as it is starting up and giving its beep codes.
For instance, a red LED light often indicates a faulty memory module or an overheating processor.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
make sure that your RAM modules and Cmos battery are securely seated
on some motherboards Cmos batteries are soldered in
Test all power and data leads that attach from motherboard to your hard drive IDE SATA
make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat 40 pin ide it will be the first to fail
check the graphics card is seated properly with no dust in the socket you might have to remove it to check for dust reinstall it
restart your computer the found new hardware wizard should activate
a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function
make sure all leads that are attached to your drives dvd\cd and floppy drive have secure make sure the connections and are not faulty or just replace them they could be faulty
a computer needs all electric current and computer data to travel to and through every working device and have an end to work properly so any faulty leads will end up with a computer error
also check the keyboard for secure dust free connection ps2 and or usb
also check the CPU central processing unit for secure dust free seating and thermal paste
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
hope this helps
Oct 30, 2012 | HP Compaq d530 SFF PC Desktop
My computer beeps when I start it up how do I stop it
The beeps you hear are BIOS Beep Codes. The computer's method of telling you something is wrong, and an area to look into for it.
It is a pattern. A series of beeps, then a pause, then a repeat.
It is a Code.
http://www.pchell.com/hardware/beepcodes.shtml
Listen to the beep code. Post it back in a Comment.
Regards,
joecoolvette
Mar 18, 2012 | Acer Aspire 5050 5430 Laptop
Hello im trying to upgade the PCs memory. I inserted "DDR400 1GB CL3" to the memory slot ,with no other memorys prsent. the computer does not start. only peeps a few times. I checked the...
Remove the "new" stick of RAM, and re-insert your "old" stick of RAM, and start it.
If it still beeps, how many times does it beep, and is it a "short-long-short" type of pattern?
The number of beeps is important.
Does the manual for the motherboard indicate that it supports a maximum of 256MB per stick?
512MB per stick? 1024MB per stick? What's the size of the "old" stick of RAM?
Check that the video-card is properly "seated" into its slot, because an improperly-seated card (knocked loose when you changed the RAM) could cause the beeping.
Jan 05, 2011 | Computers & Internet
If a computer keeps beeping when i try to start it up , is that the hard drive?
Hello, and thanks for using FixYa.
No, often its memory or video card. The beeping pattern tells of the problem.
I would remove the memory modules from the machine, turn on again without memory, it will beep, turn off, unplug and reinsert one of the memory modules into the computer and turn on, it should work, if it doesn't repeat with another memory module.
if the problem is not solved count the beeps and are they long or short? and I'll know more.
Thanks
Oct 19, 2010 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
My poweredge emits a contiual beep and don't turn on . thanks
If your PowerEdge will not boot but only beeps on start, there are a number of things that could be the issue. One thing that can be done is to document the beep pattern and use that to look up the issue or post the beep pattern here.
Feb 22, 2010 | Dell PowerEdge 1800 Server
Can't turn off beeping noise for various functions -
Disable system "beep" on Windows XP: Control Panel -> Administrative Tools -> Computer Management -> Device Manager -> Show Hidden Devices -> Non Plug-and-Play Drivers -> Beep (Stop and Disable) -> restart
Dec 27, 2008 | Dell Latitude D600 Notebook
System does not start
The beeps are error codes and if you listen carfully you will hear a pattern of short and long beeps. If you can identify the pattern we can help you figure out whats going on....
Feb 14, 2007 | Dell OptiPlex GX110 PC Desktop
My computer (emachines T5212) beeps at me
These are called beep codes and there should be a pattern of long and/or short beeps which will repeat. Once you identify the pattern we can help figure this out for you.
Jan 11, 2007 | E-Machines eMachines Desktop PC
Dell Precision Workstation T5400 Quad Core Intel Xeon Processor E5410 2.33... PC Desktop Logo
203 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
